Old 04-09-2013, 02:44 AM   #1
AppFan OP
Oddometer: 362
Shop lighting?
I finally ran electric out to the shed in the backyard. Any recommendations for lighting? It's 12x16 with no windows and will be primarily used for woodworking projects and storage.
AppFan is offline   Reply With Quote
Old 04-09-2013, 03:26 AM   #2
Maggot12
U'mmmm yeaah!!
Maggot12's Avatar
Oddometer: 5,128
One of those dual 4ft tube housings.... the actual name of it escapes me now.
Maggot
Don't sweat the petty things; Pet the sweaty things !!!
Maggot12 is offline   Reply With Quote
Old 04-09-2013, 04:47 AM   #3
AppFan OP
Oddometer: 362
Fluorescents? That's what I was thinking but I'm seeing T5 and T8 etc. and all kinds of price ranges. I'd rather spend the right amount up front and get something that works, just not sure what that is.
Old 04-09-2013, 04:58 AM   #4
Stkmkt1
Stkmkt1's Avatar
Oddometer: 257
Unless you're hanging the fixtures about 20 feet high, go with the T8 bulbs. Each provides 32 watts of light. A T5 bulb is 54 watts and is intended to be hung higher in the air. You can just hang a few twin tube T8 fixtures with reflectors to shoot the light down and you'll be fine.
2013 BMW 700GS, 2009 BMW 1200GS Adventure,
2009 Vstar 950, 2009 Honda Rebel,
2000 Goldwing SE, 1977 CB750A,
Needs: new garage (in planning) Need more room for more bikes.
Stkmkt1 is offline   Reply With Quote
Old 04-09-2013, 05:36 AM   #5
kantuckid
Oddometer: 3,079
You get what you pay for applies with these lights-the ballasts are crappy on the low ends choices & the reflectors not so good either. Shop around.
"If I had my life to live over,I'd dare to make more mistakes next time...I'd relax,I'd limber up.I'd be sillier than this trip, take fewer things seriously, I would take more chances... take more trips...climb more mountains...swim more rivers...eat more ice cream." Jorge Luis Borges, at age 85
kantuckid is offline   Reply With Quote
Old 04-09-2013, 08:40 AM   #6
Bronco638
Nobody Home
Bronco638's Avatar
Oddometer: 3,887
The large home improvement stores sell a cheap fluorescent fixture (~$30), with two T8 bulbs, that are supposedly rated to work in cold weather.
I have two in my (heated) garage (50+ year 'round). One fixture would burn out bulbs or have the ballast fail and other other just "keeps on truckin'". I just replaced the fluorescent bulbs with LEDs (fixture needs rewiring to work with LED) in the problematic fixture. The difference is pretty amazing.
Granted, the bulbs are not cheap (~$50 ea.). But, now I don't have to worry abut ballasts burning out or bulbs that don't work in the (relative) cold. They're mounted about 12' off of the floor and two fixtures easily illuminate a 20' x 18' garage.
There are some simple thruths......and dogs know what they are - Joseph Duemer
Andy holds the lead. And he will, all the way to the Highway. Today is his day.
Bronco638 is offline   Reply With Quote
Old 04-09-2013, 08:51 AM   #7
30Bones
30Bones's Avatar
Oddometer: 4,635
So did you keep the same housings and convert those to LED? Pics, links would be helpful. Same sized garage and high ceilings make it tougher to light well and I hate having lights hang 3' from the ceiling when winds pick up with the door open.
30Bones is offline   Reply With Quote
Old 04-09-2013, 10:51 AM   #8
chollo9
Screwed the Pooch
chollo9's Avatar
Oddometer: 1,576
Quality T8s are worth the money. Cheap ones are noisy and don't work well when it's cold. Two 8' bulbs throw more light than four 4' bulbs so install those if you can. If you buy fixtures without bulbs, then you have choices of the color/spectrum of light to get. I like what they recommend for kitchen installations (sorry, can't remember which that is) for shop use.
My two cents, of course.
Interesting info, Bronco, I'll have to check that out. No matter what fluorescents you buy, you will be replacing bulbs and ballasts down the road . . ..
"It's not that I don't like people...I just find I am happier when they're not around"
chollo9 is offline   Reply With Quote
Old 04-09-2013, 11:00 AM   #9
bomber60015
Anatomically Correct
bomber60015's Avatar
Oddometer: 13,106
Make certain the ballasts will work in cold weather . . . .
Also, give as much thought to task lighting as overall lighting . . .given the size of your shed, it's gonna be hard to recreated open area sunlight in there . . . . difficult to make sure that you can't throw a shadow on your workpiece or tools . . . . . .
painting the inside with white paint will increase the light levels and eveness a great deal, way out of proportion of the cost of the paint.
"Here is your country. Cherish these natural wonders, cherish the natural resources, cherish the history and romance as a sacred heritage, for your children and your children's children. Do not let selfish men or greedy interests skin your country of its beauty, its riches or its romance. T.R.
Old 04-09-2013, 11:42 AM   #10
ADW
'tard bike restos
ADW's Avatar
Oddometer: 557
NEVER too much light
Agreed. Painted my shop a light beige for that reason, reflectivity. Couldn't go with white as it was just too stark.
A 12x16 shop sounds to me like room for 3 banks of 4 lights each. Put one right in the center and then with the outer two banks hedge them closer to the wall than an "even spacing" would give you...that way things closer to the wall will also get good light. I have a 17x18 shop and a 22x18 garage and each have 4 banks of 4 lights (w/2 bulbs in each, so 32 total), with one switch operating the center 2 rows and another switch for the outer two rows. So I can just throw on the two middle ones if I don't really need to do anything in particular, but can go "full Hiroshima" by flipping on the outer two banks if I really need to light it up. In my case having the outer banks closer to the walls both illuminates the tools nestled up against the walls (drill press, grinder, etc.) and also will help light up the outer sides of a car. With the lights "centered" the roof of the car would block a lot of the light, that's why I put the outer ones waaay outboard, almost against the outer walls.
You can NEVER have too much light in a workshop. Ever. (Especially as your eyes get older). Yeah, it costs more, but you'll be so much happier with it!
08 KLR, 06 KLR w/Sputnik sidecar, 09 WR250R, 72 CB350F
ADW screwed with this post 04-09-2013 at 11:51 AM
ADW is offline   Reply With Quote
Old 04-09-2013, 06:10 PM   #11
the_gr8t_waldo
Oddometer: 2,114
A lot depends on what hight you'll be hanging these new fixtures. For my money its t8's at 6-8ft above the floor. As an example of how over board a guy can go, in my 20x20garage. I have 128linear foot of t8's ( 6-8' aff) have to say working under thoes conditions, is a shear joy!!!
the_gr8t_waldo is offline   Reply With Quote
Old 04-09-2013, 06:19 PM   #12
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 52,929
4 Walmart LOA fixtures going for about a year and a half now. I paid about $11 each, and $20 for the 8 T-8 bulbs.
How I installed mine:
Jim
Old 04-09-2013, 06:59 PM   #13
Hoodcounty
Oddometer: 87
I use converted 4 foot twin tube units in my shop.
Since I like a LOT of light, I went to LED bulbs in the 7000 kelvin range.
They are expensive, but I have 10 of them in the bike area which measures
24 X 24. There are no shadows and I can find all those things that seem to fall on the floor when they should be in my hand.
You can get 4 foot T8 bulbs in the same kelvin rating and have more light than you might imagine and still use a cheap wally word fixture.
With traditional bulbs you'll loose 30% light in the 1st 18 months and need to re-lamp 4x and replace ballasts 2x before my led units requiire replacement.
For the car/truck area I use Par 38 7000K LED floods. Easy to wall and ceiling mount in par holders and places light in the wheel wells and engine compartments where it's needed.
Best part of the deal is that with the doors open, LED produces no UV, which means no bugs.
Hoodcounty is offline   Reply With Quote
Old 04-10-2013, 04:53 AM   #14
kantuckid
Oddometer: 3,079
Interesting comment on bugs & I can just hear the sketers plotting against you!
As for cold start lighting-it only takes a few minutes to get them rolling & bright so not a big issue there. You must gauge the number of fixtures and type of light to the type of work you will be doing. My largest "mistake" when I built my shop was to build 6 skylights into the roof as I do a lot of wood working & like natural light. The plastics available at that time in the 1970's simply don't last and I covered them up when I roofed the shop last time as they had hazed up and too expensive to do them right 23nd time around. I still have lots of windows that make for poor insulation but lots of good "free" light. Look in a school classroom if you want to see plenty of light & the number of fixtures it takes to make that happen. Read about the various types of tubes being sold and their purpose.
Old 04-10-2013, 06:09 AM   #15
cablebandit
Web Adventurer
cablebandit's Avatar
Oddometer: 704
Figure out how much light you need, then double it. My garage looks like an operating theater. Remember as you age you'll also need more light also. Might as well make it look like the surface of the sun from the get go.
IBA #33260
cablebandit is offline   Reply With Quote
Times are GMT -7.   It's 08:52 PM.
