Old 04-14-2013, 01:28 PM   #31
AppFan OP
Oddometer: 343
Thanks all. Great suggestions in here. I wound up putting in 4 fluorescents that hold 4 4ft t8 tubes about 8 ft high. After I build my benches I'll add some spots but liking it so far.
AppFan is offline   Reply With Quote
Old 04-14-2013, 11:01 PM   #32
freax
freax's Avatar
Oddometer: 72
Originally Posted by BeeCeeGS View Post
Can you post a pic of the reflectors you mention in your post? Thanks.
They're basically a ceiling lamp shade.
Yamaha 1977 XT500. Single. Macgyver fan. Computer freak. Mechanic Novice. Tall guy (6ft6in) Self-Taught Electrician. Survivalist enthusiast.
freax screwed with this post 04-14-2013 at 11:20 PM
freax is offline   Reply With Quote
Old 04-15-2013, 11:39 AM   #33
chollo9
Screwed the Pooch
chollo9's Avatar
Oddometer: 1,543
Originally Posted by aftCG View Post
Quite by accident I've discovered that side lighting is more important than lighting from above
Yep, go in an auto body shop sometime, the fluorescent lights are mounted vertically on the walls.
"It's not that I don't like people...I just find I am happier when they're not around"
chollo9 is offline   Reply With Quote
Old 04-15-2013, 06:24 PM   #34
Guano11
Trending (downward)
Guano11's Avatar
Oddometer: 1,299
Interesting. Is there a "classy" way of mounting such fixtures, or do you just screw 'em into the walls?
Any issues with the weight of the tubes resting on the "bottom" (which was designed to be an "end")?
Guano11
Time flies like an arrow.
Fruit flies like a banana.
Guano11 is offline   Reply With Quote
Old 04-16-2013, 07:05 AM   #35
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 52,243
IMHO Get the flush mount lights then cover them with an alternate plastic like polycarbonate to protect them from damage. They make them that will fit between 16" on center studs.
Jim
Old 04-18-2013, 09:02 PM   #36
scooteraug02
Dog Rancher
scooteraug02's Avatar
Oddometer: 4,521
scooteraug02 is offline   Reply With Quote
Old 04-20-2013, 06:29 PM   #37
drm
drm's Avatar
Oddometer: 446
Cool2
I used 9 edison bases with 80w (350w equiv) cfls to light my 30x30 garage. Ceiling height ranges from 11ft to 15ft. I painted the ceiling and walls white.
It is a cheap basic lighting solution. I use supplemental side lighting when needed.
http://www.1000bulbs.com/product/3816/FC85-81181.html
2007 KLX250S
drm is offline   Reply With Quote
Times are GMT -7.   It's 10:53 PM.
