Old 04-10-2013, 12:33 PM   #1
Couch_ninja OP
Oddometer: 46
Tiger 800 XC oil weeping from pan or oil gallery
I got back from a long (250 mi) ride the other day and noticed that either the oil pan is weeping oil or the oil gallery allen bolts are leaking a little. Does anyone have the torque specs for these? The allen bolts are the large gold ones on the side of the engine above the oil pan. I was able to snug up the bolts for the drain pan, but the allen bolts seem to be tight already. I don't want to crank on any of these bolts for fear of causing any damage, so if anyone knows the torque values I'd really appreciate it!
Couch_ninja is offline   Reply With Quote
Old 04-10-2013, 12:56 PM   #2
KingOfFleece
SplitWeight(tm)
Oddometer: 822
Not a big deal. Just snug them up. SNUG is all. Lots of us have had to do this. One time only.
KingOfFleece is offline   Reply With Quote
Old 04-10-2013, 01:22 PM   #3
Couch_ninja OP
Oddometer: 46
I was able to snug up the bolts to the oil pan (used a small 8mm open ended wrench and was able to tighten 2 of them up a little - none were loose), but the 2 allen bolts are the ones I'm concerned about over-torqueing. I put an Allen socket on them and they seemed snug, but I didn't force them. Should I loosen them up and then re-snug them? It's not a lot of oil, but any oil is too much as far as I'm concerned....
Old 04-10-2013, 01:51 PM   #4
Dubl-A
SuckerDucker
Dubl-A's Avatar
Oddometer: 1,808
If it is still under warranty, take it to the dealer. My case wept in numerous places, same as you described too. I made them fix it each time and havent seen a drip since.
Keep your $0.02 if it ain't going towards the bill
Dubl-A is offline   Reply With Quote
Old 04-10-2013, 02:27 PM   #5
Couch_ninja OP
Oddometer: 46
That's probably what I'll end up doing. Just a PITA to get to the dealer...
Old 04-11-2013, 08:13 AM   #6
Dubl-A
SuckerDucker
Dubl-A's Avatar
Oddometer: 1,808
I hear ya, I live on the exact opposite end of the valley from my dealer. Never really convenient for me but I'd rather get it done FOC. Wrench on it after it's warranty has expired.
Old 04-11-2013, 02:27 PM   #7
dduelin
Oh boy that was close
Oddometer: 1,494
Why does a new bike leak oil in 2013? I have heard of this on the 1050 motor but does the 800 do the same?
Triumph Tiger 800
Honda ST1300
Honda CH80
Dave
dduelin is offline   Reply With Quote
Old 04-11-2013, 02:52 PM   #8
cug
Oddometer: 4,878
Because some lazy bastard didn't tighten the bolts properly and it wasn't caught in quality control.
cug is offline   Reply With Quote
Old 04-11-2013, 09:23 PM   #9
cold comfort
cold comfort's Avatar
Oddometer: 108
No oil leaks from my 2011. Did have a leaking fork seal but drowning it in rivers and jumping culverts two up probably didn't do it any favours. Keep forgetting its not my KTM.
cold comfort is offline   Reply With Quote
Old 04-12-2013, 06:04 AM   #10
Kawidad
Kawidad's Avatar
Oddometer: 4,849
Same problem here. The dealer told me mine was their third Tiger 8 with the oil gallery plug leak. For me the pan bolts loosened up after I already tightened them upon delivery. As per the dealer: The oil gallery plug needs to be removed and thread sealer applied to the bolt.
Quis custodiet ipsos custodes? - Juvenal
(Who watches the watchers)
Kawidad is offline   Reply With Quote
Times are GMT -7.   It's 12:48 AM.
