Old 04-13-2013, 09:39 AM   #1
scootertrog OP
Oddometer: 310
Dial Indicator Reading Help Please
Testing my rotors for warpage (I'm getting a nasty brake pulse/grabbing when rolling up to a stop sign), I purchased the Clamp-On Dial Indicator from Harbor Freight Tools. I normally don't buy "precision tools" from H-F, but this particular item seems to get pretty good reviews. Anyhow, am I reading this correctly at .0055"?
The rotor service limit spec on my bike is 0.3mm, or .012". Looks like I am OK here, right?
scootertrog is offline   Reply With Quote
Old 04-13-2013, 09:52 AM   #2
joexr
Oddometer: 3,773
Looks like .055 so you're out of spec.
Old 04-13-2013, 10:02 AM   #3
LuciferMutt
Rides slow bike slow
LuciferMutt's Avatar
Oddometer: 11,318
If anything, that reading would be .1055" because of the additional .100" showing on the smaller dial-- but it ALL depends where the OP set "0" by how much probe engagement there was initially, and where the dial bezel was rotated. In any case, a deflection of .055" or .1055" would render the brakes useless, not just create a slight vibration
OP, if you are seeing the needle swing between the 0 and the position it's at now, yes you are correct that it's .0055" or five and a half "thou."
You couldn't hear a dump truck driving through a nitro glycerin plant!
Badasses might screw with another badass. Nobody screws with a nut job. -- Plaka
LuciferMutt is offline   Reply With Quote
Old 04-13-2013, 10:07 AM   #4
joexr
Oddometer: 3,773
I don't think he started with the center dial on O. If it was out .1055 he would'nt need a dial indicater to see the run out. Oh and that's 1.055 by the way.
Old 04-13-2013, 10:11 AM   #5
scootertrog OP
Oddometer: 310
Originally Posted by LuciferMutt View Post
..OP, if you are seeing the needle swing between the 0 and the position it's at now, yes you are correct that it's .0055" or five and a half "thou."
I zeroed the dial at the lowest point, I really did not pay much attention to the smaller dial. Just finished the RH rotor, it was at .013, that would be out of spec if I'm doing this correctly, and would def explain the pulsation.
scootertrog screwed with this post 04-13-2013 at 10:18 AM
Old 04-13-2013, 10:17 AM   #6
joexr
Oddometer: 3,773
May as well do new pads too. Stay away from EBC pads. Real hard on rotors. I like Galfer.
Old 04-13-2013, 10:33 AM   #7
D.T.
Difficult but useful
D.T.'s Avatar
Oddometer: 11,306
If he zero'd it at 0 and each gap || is .001" I'd say .0055" is right. Ten revolutions for 1" of measurement.
Or one revolution is 1"? One inch of travel? Or one revolution is .1"?
Then fuck if I know.
Originally posted by burgerking So?
Holland is about the most expensive country in Europe when it comes to bikes and fuel..Stop whining and go riding It's just money and you only live once...
D.T. is online now   Reply With Quote
Old 04-13-2013, 10:36 AM   #8
scootertrog OP
Oddometer: 310
Well, I just put a new set of pads on about 2,000 miles ago, Galfer Kevlars. I also have a new set of SBS StreetExcell pads. Visually, I could not see any warpage, but obviously it's there. I really don't notice it except for slow-rolling up to a stop sign, then it grabs and let goes every couple of feet. Hard stopping or at speed is not affected. Guess I'll start shopping for rotors...
Old 04-13-2013, 10:37 AM   #9
scootertrog OP
Oddometer: 310
One revolution is 1" correct? One inch of travel? Or one revolution is .1"?
Yes - all dial movement was between the 0 an the 6 tick mark.
Old 04-13-2013, 10:41 AM   #10
D.T.
D.T.'s Avatar
Oddometer: 11,306
I'd try removing the pads and rotors. Re scuffing them if the discs don't have warpage. Possibly contamination of one or both?
Old 04-13-2013, 10:42 AM   #11
trc.rhubarb
trc.rhubarb's Avatar
Oddometer: 1,998
Each 10/20/30 is .01/.02/.03
Each | | is.001 .002 .003
Each full rotation of the dial ticks the little dial .1/.2/.3
10 full rotations is 1"
so... dunno what the small read but the big dial is showing .0055 (roughly) or .1055 if the small was at 0
2007 BMW GS Adventure / 2000 Ducati 900ss / 2010 Harley Ultra Limited / 1975 BMW R90/6 / 2006 DRZ400S
Follow me here
trc.rhubarb is online now   Reply With Quote
Old 04-13-2013, 10:46 AM   #12
Beezer
Oddometer: 5,836
ya, the .1 is just the cushion caused during the setup. since all the movement was between the 0 and the .006 marks you have about 5 and 1/2 thou runout
Beezer is offline   Reply With Quote
Old 04-13-2013, 10:51 AM   #13
scootertrog OP
Oddometer: 310
Yeah, the LH side is OK - unfortunately the RH side is .013", which is .001" over spec. It grabs like crazy when rolling up to a stop sign. I've bled, and re-bled, cleaned the rotors, bobbins and pads, lol.
Old 04-13-2013, 11:05 AM   #14
GAS GUY
MILE EATER
GAS GUY's Avatar
Oddometer: 3,460
Right on, or 55 ten thousandths to be exact.
2008 KLR 705-2004 ST1300-2001 FZ1
2001 GAS GAS 321
IBA # 23,716
http://gasguysadventures.blogspot.com/
GAS GUY is online now   Reply With Quote
Old 04-13-2013, 11:08 AM   #15
GAS GUY
MILE EATER
GAS GUY's Avatar
Oddometer: 3,460
Wrong.
2001 GAS GAS 321
IBA # 23,716
Times are GMT -7.   It's 10:58 AM.
