Old 04-14-2013, 09:20 PM   #1
FlySniper OP
Bleh...
FlySniper's Avatar
Oddometer: 1,662
Welding up a clutch basket asking for trouble?
This is pretty much a repost of what I posted in the Ninja 250 thread.
My wife's 250 started making bad noises... the rubber buffers in the basket disintegrated. I bought a used basket off of Ebay, it's a little better, but I doubt it'll hold up for long.
There's a plate on the backside of the basket that has pins that pass through the main drive gear. The gear floats while the plate and pins are solid to the basket. The plate and gear actually contact and it looks like a good welder could run a bead to make the whole thing solid without stressing the base metals much.
But, what would a solid basket do to the rest of the drive line? I know that almost all clutch assemblies have some means of dampening shock loads... this would remove that ability from this clutch.
A feeling of having made the same mistake before: Deja Foobar.
"Think about how stupid the average person is. Now, realise that half of them are dumber than that." - George Carlin
FlySniper is offline   Reply With Quote
Old 04-14-2013, 10:03 PM   #2
anonny
What could go wrong?
anonny's Avatar
Oddometer: 5,582
My take is most clutch baskets are cast aluminum which doesn't lend to welding anyways.
Kawasaki H1 build thread
71- 450 Honda CL re & re
anonny is offline   Reply With Quote
Old 04-15-2013, 06:39 AM   #3
LuciferMutt
Rides slow bike slow
LuciferMutt's Avatar
Oddometer: 11,224
I think you just answered your own question. I suspect, even if you could weld the basket, it would be a short term recipe for destroying the transmission.
You couldn't hear a dump truck driving through a nitro glycerin plant!
Badasses might screw with another badass. Nobody screws with a nut job. -- Plaka
LuciferMutt is offline   Reply With Quote
Old 04-15-2013, 06:48 AM   #4
Switchblade315
Switchblade315's Avatar
Oddometer: 5,571
yeah that's there to keep it from destroying the trans. can you not just buy new rubber bumpers from bikebandit.com?
When I die bury me upside down so the whole world can kiss my ass.
"My mind jumped off the high dive into the deep end of the gutter and took scuba gear with it" Me.
Switchblade315 is offline   Reply With Quote
Old 04-15-2013, 10:03 AM   #5
victor441
victor441's Avatar
Oddometer: 928
Looks like it would not be possible in any case, it appears that one part is aluminum and the other steel so welding them together would not be an option...
from http://faq.ninja250.org/wiki/What%27..._the_clutch%3F
victor441 is offline   Reply With Quote
Old 04-15-2013, 10:37 AM   #6
FlySniper OP
Bleh...
FlySniper's Avatar
Oddometer: 1,662
The left basket; the red mark is one of the pins, the lighter grey metal around it is the plate and it's steel, the darker gear underneath it is also steel. Those are the parts I was considering welding up as those two parts are where the bushings are located (between the pins and the gear).
But, I know that would kill the transmission in time. I was just hoping someone would come along and tell me they have done it plenty of times without trouble.
A new basket is almost $300, the bike is worth fixing, but I was looking to replace it this summer and would like to avoid spending that much on it... guess I'll have to anyway!
Old 04-15-2013, 11:08 AM   #7
Beezer
Oddometer: 5,746
soooooooo........ the rubber bits are inside the 2 plates & they are riveted? a desperate guy could grind or drill off the rivets, install new rubber, & then bolt it back together
Beezer is offline   Reply With Quote
Old 04-15-2013, 08:25 PM   #8
FlySniper OP
Bleh...
FlySniper's Avatar
Oddometer: 1,662
It's been done before. There's a writeup on one of the 250 forums where a guy used a certain rubber from a tube and formed his own. I have an extra basket, but I'm not sure how tough the pins need to be. The cost of a new basket vs. the cost of replacing the engine should a cheap repair fail.... eh, I'll just bite it and buy a new basket.
Old 04-16-2013, 06:54 AM   #9
LuciferMutt
Oddometer: 11,224
That guy wasn't Skippii was it?
Old 04-16-2013, 02:54 PM   #10
FlySniper OP
Bleh...
FlySniper's Avatar
Oddometer: 1,662
Skippii? Oh,... errr, uhm, yeah... Speaking of Skippii, maybe I should tread lightly when considering ghetto repairs.
But no, it wasn't. At least not to my knowledge.
Old 04-16-2013, 10:04 PM   #11
Beezer
Oddometer: 5,746
the pins are mostly loaded in shear with little tensile load on them. keep the original pins... mill off the shop heads, drill down the center of the pins & thread 'em for bolts
Old 04-17-2013, 02:45 AM   #12
Skippii
Hookers, my lad.
Skippii's Avatar
Oddometer: 6,506
No, I would have welded it.
"Umm be careful what you say, this is Skippii....
You may get it delivered in the form of a shake or some interperative dance routine that involves nakedness, pizza and a stuffed raccoon..." -DCrider
Skippii is offline   Reply With Quote
Old 04-18-2013, 09:15 PM   #13
FlySniper OP
Bleh...
FlySniper's Avatar
Oddometer: 1,662
Scary thing is I was thinking the exact same thing.
That or just knocking out a set of custom pins on the CNC lathe. I have been considering something using external clips... it would be pretty easy to do, but I already have way too many parts to run as it is.
Times are GMT -7.   It's 07:54 PM.
