Old 04-16-2013, 09:56 PM   #16
team ftb OP
Befuddled Adventurer
Oddometer: 1,757
awesome replies guys thanks for the responses. looks like it will be a timesert. now just to figure out how to to drill the hole straight with one arm and hand in a cast.
Cheers,
Team FTB
Team "Fingering The Bean"
team ftb is offline   Reply With Quote
Old 04-16-2013, 10:15 PM   #17
villageidiot
Oddometer: 1,835
For a temporary/permanent fix, why not just use a longer bolt and put a nut on the backside? If you don't have the time sert kit, they can be anywhere from 40-300 dollar ( the latter a big sert kit for spark plugs)
Good luck
villageidiot is offline   Reply With Quote
Old 04-16-2013, 10:40 PM   #18
Plaka
Brevis illi vita est
Oddometer: 4,609
Originally Posted by team ftb View Post
just stripped a m6 screw that holds on my ktm muffler. I obviously need to redo the threads to enable another m6 bolt to be utilized. easiest way is a helicoil. however on the muffler that will be removed a few times per year is the helicoil reliable enough?
another option is a nutsert. trouble is I don't own the tool. can I install these nutserts with a rivet gun?
give me insight into what would be the best solution given my situation.
thanks heaps. apologies for no caps and not a wealth of info but the arm is in a cast and only have one finger typing at the moment.
There are threaded inserts for sheetmetal that install with an ordinary pop rivit gun. They tend to be the smaller sizes. The bigger ones need The Tool---looks like a pop riviter but has a threaded pull rod. Metric would be a special item.
Timesert kits cost a lot more than Helicoil. They have some advantages (strength) and disadvantages (you can't stack them easily). You want the Timesert drill, it does a special hole (it's counterbored)
Old 04-17-2013, 04:52 AM   #19
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 53,388
If you are drilling out a stripped hole, drilling straight is a non-issue unless you are really uncoordinated. The original hole will guide you prefectly. I have done about a hundred stripped valve cover threads on aluminum before and never used any kind of guide. The hole is the guide.
Jim
JimVonBaden is online now   Reply With Quote
Old 04-17-2013, 04:55 AM   #20
JRose
JRose's Avatar
Oddometer: 629
Originally Posted by mcma111 View Post
+ 1 on Timeserts.
These are hands down the best if the easy options that I have used.
JRose is offline   Reply With Quote
Old 04-17-2013, 08:09 AM   #21
showkey
Oddometer: 1,955
Originally Posted by JRose View Post
+ 1 on Timeserts.
+2. ^^^^^^^^^^^^^^^^^^^^^^^^^
No wonder I do not like flying ..........the plane is held together with helicoils
Time to get aviation on the time-sert band wagon.
1982 CX500 Turbo ,2006 ST1300, 2012 NC700X
1971 CT90,1981 C70, 1986 TRX 250,
1993 TRX300 4X4, 2001 TRX500 4x4, 1987 XR250L
showkey is online now   Reply With Quote
Old 04-17-2013, 02:14 PM   #22
Anorak
Woolf Barnato
Anorak's Avatar
Oddometer: 34,133
Perhaps there is a reason they use helical inserts?
'Gonna get me a six pack...push people off the highway!'
"they live off the carrion of our mutual distrust and bribe us with symbols that equate hatred with manhood."
"I mean at the end of the day, I was addicted to Starting Fluid for Christ's sake!"
"Yeah, that guy sure is terrible at touching moms"
Anorak is offline   Reply With Quote
Old 04-17-2013, 04:02 PM   #23
ttpete
Rectum Non Bustibus
Oddometer: 5,990
Helicoils work well as long as they are installed properly.
A helicoil must be installed below the surface. The top end has to be seated down in a full groove so it will lock itself in place. The installation tang has to be broken off and removed. Most helicoil problems occur because of faulty installation.
15 BMW RnineT
09 Kaw Versys
Old 04-17-2013, 07:39 PM   #24
ericrat
Oddometer: 1,212
Well for me...
I always install my Helicoils with Castrol Power RS 4T and ONLY on bikes running Michelin tires.
Have you visited ride reports lately ?. click HERE
ericrat is offline   Reply With Quote
Old 04-17-2013, 08:41 PM   #25
ttpete
Rectum Non Bustibus
Oddometer: 5,990
And?
15 BMW RnineT
09 Kaw Versys
Old 04-18-2013, 04:54 AM   #26
mcma111
mcma111's Avatar
Oddometer: 12,409
What air pressure are you running in those Michelin tires?
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 04-18-2013, 06:22 AM   #27
showkey
Oddometer: 1,955
Nitrogen and dyna beads...........
Old 04-18-2013, 06:47 AM   #28
ericrat
Oddometer: 1,212
Nitrogen is so last year, I have moved up to Argon. It has a covalent radius of 106pm... blah, blah, blah...
Point is, hopefully obviously, that here are many solutions to this problem and like tire and oil threads a lot of huff without much real result past the basic information.
Old 04-18-2013, 08:44 AM   #29
GreaseMonkey
Preshrunk & Cottony
GreaseMonkey's Avatar
Location: The only county in Illinois with no train tracks
Oddometer: 5,317
Another blasphemous suggestion is that 1/4" is 6.3mm, you may be able to get by with going with a 1/4" bolt and running a tap into your boogered threads as they are, your spacers may have that much extra clearance in them.
GreaseMonkey is offline   Reply With Quote
Old 04-20-2013, 06:16 AM   #30
kantuckid
Oddometer: 3,088
Helicoils are great. Fact remains that there are lots of brands of inserts and some mfgs make more than one style or material as it is only logical for the variety of situations for where they're used. You have to use what works for that situation. It might be one of several choices or one certain choice.
I chime in on these thread repair threads often & say the same things but my point is not opinion, just reality. Sometimes I choose based on what is available w/o buying a whole box or paying shipping on a tiny piece. I used "Thinserts" for my last repair. Some of the ebay sellers do smaller quantities.
Fact that your repairing a frame tube makes me wonder how the threads were built into the frame? Say/show more?
"If I had my life to live over,I'd dare to make more mistakes next time...I'd relax,I'd limber up.I'd be sillier than this trip, take fewer things seriously, I would take more chances... take more trips...climb more mountains...swim more rivers...eat more ice cream." Jorge Luis Borges, at age 85
kantuckid is offline   Reply With Quote
Times are GMT -7.   It's 08:17 PM.
