Old 04-17-2013, 01:37 PM   #1
lacofdfireman OP
Oddometer: 794
Is it ok to route my fuel line like this? Acerbis 6.3 on KTM 530 (Pictures inside)
I have a big 6.3 Gallon Acerbis tank and am trying to figure out the best way to run my fuel like and keep it off the header pipe on my KTM 530. It would make for a bad day if it touched the pip and then burnt a hole in it. I have it routed through some Radiator hose to keep it up and out of the way of the header pipe but it does run along the cylinder head even though it's not really touching it. Will this work or is this some better way? I though about maybe buying a larger diameter hose and putting it over the fuel line as maybe a little insulation but wasn't sure if it was necessary or not. Opinions wanted...
lacofdfireman is offline   Reply With Quote
Old 04-17-2013, 04:19 PM   #2
cardoctor1
cardoctor1's Avatar
Oddometer: 545
run a piece of steel fuel line and efi rubber hose for the connections.
IBA#35592
RIDE EVERY RIDE LIKE ITS YOUR LAST
00 R1150GS
cardoctor1 is offline   Reply With Quote
Old 04-17-2013, 04:30 PM   #3
MrPulldown
MrPulldown's Avatar
Oddometer: 3,361
section from the petcock to the radiator hose (?) seems fine. However the aft sections looks like it is touching the header. It look unnessarily low. Can you tighten it up or tie it up higher. I have a acerbis tank on my bike and the fuel line appears dangerously close to the header. I have run it this way (as have many others) for a couple of years without issue.
MrPulldown is online now   Reply With Quote
Times are GMT -7.   It's 11:34 AM.
