Old 04-18-2013, 09:32 AM   #1
MaestroPNW OP
Me!
MaestroPNW's Avatar
Oddometer: 95
HF Tire Changer alternative
I was about to get myself an HF tire changer only to discover that it is discontinued.
What is my next cheapest alternative? Ebay is full of HF replicas, but I'm somewhat confused, as some of them list tire size up to 16.5'' while very similarly looking units claim to go all the way up to 25;;.
For instance - http://www.ebay.com/itm/Motorcycle-P...893cb4&vxp=mtr - claims 25''
http://www.ebay.com/itm/2-in-1-Motor...997249&vxp=mtr - claims 16'' looks pretty much the same.
Besides ebay, what can I get without going into ~$500 range?
I'm sure this has been beaten to death, please kindly recycle electrons :)
MaestroPNW is offline   Reply With Quote
Old 04-18-2013, 10:42 AM   #2
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 53,801
Those are the HF tire changers, but not ready for MC tires. They would need an additional $150 woth of stuff to make them useful without damaging the wheels.
There are other options out there that are made for MC wheels that are about $250-300. The No Marr low line, which I can't remember the name of, has some options.
Jim
Old 04-18-2013, 11:25 AM   #3
jad3675
Oddometer: 128
Jim
Cycle Hill, though it has crept up in price to about $450 or so.
http://www.nomartirechanger.com/prod...20standard.htm
John
'01 Aprilia Falco - '98 Ducati 916
jad3675 is offline   Reply With Quote
Old 04-18-2013, 11:57 AM   #4
Unstable Rider
Moto Fotografist
Unstable Rider's Avatar
Oddometer: 2,629
Dang, saw some really neat ones at the bike show weeks ago. Forget the brand though.
Never do anything you would be uncomfortable explaining to the paramedics...
Unstable Rider is offline   Reply With Quote
Old 04-18-2013, 04:36 PM   #5
MaestroPNW OP
Me!
MaestroPNW's Avatar
Oddometer: 95
Jim
Given that nomar starts at about 450, spending some on the HF still seems reasonable - why would they damage wheels?
Old 04-18-2013, 04:41 PM   #6
troidus
Oddometer: 15,708
Northern Tool now carries what looks like the HF changer.
http://www.northerntool.com/shop/too...ct_18863_18863
You still need the MC adapter, though.
troidus is offline   Reply With Quote
Old 04-18-2013, 04:43 PM   #7
MaestroPNW OP
Me!
MaestroPNW's Avatar
Oddometer: 95
HF still has the basic tire changer, it's the adapter that they no longer sell.
Old 04-18-2013, 05:23 PM   #8
troidus
Oddometer: 15,708
Ah. They quit carrying it for awhile. I didn't know they had started carrying it again.
Old 04-18-2013, 05:32 PM   #9
BlueLghtning
Riding is my passion
BlueLghtning's Avatar
Oddometer: 5,332
The first link is just for the top part only. Their title even says "no base" which means the bottom portion isn't included in that auction. That's why the bottom half of the tire changer is sort of greyed out because you aren't buying that part, although you do need it to be able to use the top part. They are 2 separate pieces, but both are required for MC tires. That also explains why you see a difference in description on what they can do.
The 2nd link appears to be the full combo with both parts of the tire changer which you need to do motorcycle tires. The bottom part is only good up to about 16" or so and then the top portion which I know can do 21" tires, and probably 23" tires. In the 2nd link, their main description is mostly about the lower half of the tire change which changes like trailer type tires and maybe small car tires. The top half is explained in the side margin under this.
Overall both top parts look the same and exactly like the HF tire changer, so they should work.
X5101 - The Motorcycle Tire Changer Attachment
7-1/2 Diameter x 3/16 Thick Wheel Rest Plate
(4) 1/2 predrilled holes for mounting
15-3/8 x 18-1/2 Base
BTW, I owned a HF Tire changer for 10+ years. I finally sold it late last year when I upgraded to the No-Mar Tire changer; The classic or what ever the lowest model is. I actually bought it at the IMS show in Atlanta. The HF gets the job done, but the No Mar is super nice.
BlueLghtning - Follow me on my SPOT Messenger
Mine: KTM 650 ADV (Katuki), 09 DL650, 08 Husky TE610, 08 WR250R
Hers: 07 Ninja 650R, 13 CRF250L
Smugmug Pics - Save $5 <-- Click Here
BlueLghtning screwed with this post 04-18-2013 at 05:42 PM
BlueLghtning is offline   Reply With Quote
Old 04-18-2013, 05:39 PM   #10
BlueLghtning
Oddometer: 5,332
BTW, I have a tutorial I put together several years ago on using the HF tire changer and what tricks I had learned on how not to damage your rims and stuff and how to make the process much easier. I could do two tires ind under 20mins from start to finish.
- http://bluelghtning.smugmug.com/Moto...6303251_BKsc4b
Just a few pics from my tutorial
Old 04-18-2013, 05:46 PM   #11
BlueLghtning
Oddometer: 5,332
Jim
As long as you have both the base and the motorcycle attachment, that's really all you technically need. Even though the clamps are metal, I never found that they really marked up the rims that bad. However, you definitely need some sort of rim protector because that red bar will mark the hell out of your rims if you don't have something between it and the rim. I showed above that I used cut up shampoo bottles which seemed to work really well.
Old 04-18-2013, 08:17 PM   #12
ChromeSux
Plated and screwed
ChromeSux's Avatar
Oddometer: 1,543
I have the Harbor freight tire changer with the motorcycle tire adapter, when used in conjunction with the mojo adapters and mojo bar from Preston Drake it is pretty darn good.
http://home.comcast.net/~prestondrake/mojoblocks.htm
A buddy of mine gave me the tire changer with adapter, so i just had to buy the bar and blocks from Preston.
ChromeSux is offline   Reply With Quote
Old 04-18-2013, 08:29 PM   #13
JimVonBaden
"Cool" Aid!
Oddometer: 53,801
The lips on the stock changer are just sharp edged metal. You need to add some protection. See this: http://www.jimvonbaden.com/Tire_Change.html
Jim
Old 04-19-2013, 03:00 PM   #14
Trander
PORTLY ADVENTURER
Trander's Avatar
Oddometer: 281
I have the exact same combination and it works good for me as well.
2008 Suzuki DL650
2002 Suzuki DR650
2001 Yamaha XT225
1986 Yamaha TT225
1982 Yamaha XJ650RJ SECA
1978 Yamaha XS11
AMA Charter Life Member
Trander is offline   Reply With Quote
Old 04-20-2013, 05:42 AM   #15
Cataract2
Where to?
Cataract2's Avatar
Oddometer: 1,829
Has anyone tried this one?
People who get made because they're old, haven't lived.
Cataract2 is offline   Reply With Quote
Times are GMT -7.   It's 01:12 PM.
