Old 04-18-2013, 01:35 PM   #1
Fe Man OP
I am Iron Moran!
Fe Man's Avatar
Oddometer: 8,325
Honda Lawnmower Carb
I have a Honda HRB216HXA.
And so it appears that ethanol has claimed my fuel system; AGAIN. Last year I had the same issue and as I didn't want to dick with it, took it to small engine repair shop (aka Idiots). They claimed that the carb can't be completely disassembled for proper cleaning so they would replace it. That worked for a while but here we are again.
Questions:
1. Does anyone know if it can actually be cleaned out?
2. A new carb is $15-20; should I even try to clean the little bastard?
Thanks.
Next we will tackle my big Echo backpack blower, weed eater and Honda pressure washer.
Physics, gravity, and law enforcement are the only things that prevent me from operating at my full potential
Fe Man is online now   Reply With Quote
Old 04-18-2013, 01:55 PM   #2
emti
Oddometer: 257
Its a cheap lesson, its already not working,cant get any worse, pull it apart and see. The ethanol attacks any rubber bits and diaphraghms. good luck emti
emti is offline   Reply With Quote
Old 04-18-2013, 01:58 PM   #3
Fe Man OP
I am Iron Moran!
Fe Man's Avatar
Oddometer: 8,325
I went into it halfheartedly two years ago with that very thought in mind and was unable to rectify the problem. Even if it can't be fully stripped, there has to be a miracle carb soak compound out there somewhere.
Old 04-18-2013, 02:23 PM   #4
bisbonian
bisbonian's Avatar
Oddometer: 1,026
I found that Marine Clean from Por15 worked very well for carburetors.
http://www.por15.com/MARINE-CLEAN/productinfo/MCG/
Unfortunately it is a one-time use product.
I really miss the old Hydro-Seal; it would turn your skin colors and the smell never went away but boy would that stuff clean a carb, and it would last for years.
I've not had good luck with Pine-Sol.
My 2009 Alaska Adventure
bisbonian is offline   Reply With Quote
Old 04-18-2013, 02:32 PM   #5
ttpete
Rectum Non Bustibus
Oddometer: 5,942
You have to find the idle jet and mechanically clean it out. Carb cleaner won't touch it. I've had good luck using a bristle from a fine brass wire brush.
Basically, you have a new carburetor with clogged jets.
15 BMW RnineT
09 Kaw Versys
Old 04-18-2013, 02:41 PM   #6
Fe Man OP
I am Iron Moran!
Fe Man's Avatar
Oddometer: 8,325
And that may be the "part" you can't disassemble...
Old 04-18-2013, 03:00 PM   #7
Dave in Wi
Dave in Wi's Avatar
Location: Madison WI (40 Square Miles Surrounded By Reality)
Oddometer: 2,014
There are a couple of videos on YouTube on Honda mower carb cleaning. Check it out and see if they apply to your model.
Dave in WI
2002 ZRX1200R
1975 XL100
1988 DT50
"Daddy, it's five o'clock sometime!"
Dave in Wi is offline   Reply With Quote
Old 04-18-2013, 03:15 PM   #8
Stan_R80/7
Beastly Gnarly
Stan_R80/7's Avatar
Oddometer: 1,415
Personally, for $15-$20 and not much hassle I would just replace the carburetor. It's not hard to spend that much on parts for other lawnmower carbs. Get a separate gas container only for lawnmower gas, buy some Sta-Bil gas stabilizer - follow the directions and use it - and keep only stabilized gas in the lawnmower and the gas can. If you really like disassembling the carburetor for no good reason (and I am guilty of that), keep the current clogged one to tinker with. YMMV.
Stan_R80/7 is offline   Reply With Quote
Old 04-18-2013, 03:49 PM   #9
ttpete
Rectum Non Bustibus
Oddometer: 5,942
As long as you can poke a wire through the jet, that's all that's needed. I brought a little 600 watt Honda generator back to life this way. Once the carburetor's off, it's only another ten minutes to get it apart. The jet'll be brass, and I'm sure it'll be removable.
15 BMW RnineT
09 Kaw Versys
Old 04-18-2013, 10:13 PM   #10
Walterxr650l
Walterxr650l's Avatar
Oddometer: 1,262
Questions:
Thanks.
Depends on how much you value your time. The shop where I bought my mower won't even try cleaning those carbs. They would have more money tied up in the labor for cleaning than a new cab costs.
I shut the fuel valve on my mower off, and then let the mower run till it dies, when done mowing, every time I use it. This is my third season with thy mower and haven't had carb/fuel issues yet.
Walter
"How much a dunce
That has been set to roam
Excels a dunce
That has stayed at home."
Walterxr650l is offline   Reply With Quote
Old 04-18-2013, 10:17 PM   #11
markjenn
Oddometer: 10,441
Just FYI, but I have a mower with the same engine and it has seen nothing but E10 for the last five years or so. No problems. I do make sure I start the mower at least every month or so and keep reasonably fresh gas in it.
- Mark
Old 04-18-2013, 10:27 PM   #12
GreaseMonkey
Preshrunk & Cottony
GreaseMonkey's Avatar
Location: The only county in Illinois with no train tracks
Oddometer: 5,300
Does it run at all at the present time?
GreaseMonkey is offline   Reply With Quote
Old 04-19-2013, 04:12 AM   #13
Fe Man OP
I am Iron Moran!
Fe Man's Avatar
Oddometer: 8,325
Negative.
Old 04-19-2013, 05:18 AM   #14
Al Tuna
PUI... Deal with it
Al Tuna's Avatar
Oddometer: 13,557
Disassemble as much as possible then dip it in this for 20 min.
http://shop.advanceautoparts.com/web...zoneAssigned=1
Rinse with water then blow it out with compressed air.
EDIT: Had the wrong stuff in the pic. The Gunk is what I've been using.
Al Tuna screwed with this post 04-19-2013 at 06:05 AM
Al Tuna is offline   Reply With Quote
Old 04-19-2013, 06:57 AM   #15
ttpete
Rectum Non Bustibus
Oddometer: 5,942
I've cleaned a lot of carburetors over the years, and there's nothing except manual cleaning that will take care of a varnished idle jet. Not even the old type carburetor cleaner I still have and use. You have to poke the crap out with a wire.
15 BMW RnineT
09 Kaw Versys
Times are GMT -7.   It's 06:24 PM.
