Old 04-18-2013, 04:41 PM   #1
R-dubb OP
Dubbious Adventurer
R-dubb's Avatar
Oddometer: 4,829
4-shoe Brake Adjustment?
It's been a few years since I've fiddle with this and can't remember the sequence.
Any tips on how to go at it?
I vaguely remember you back off one side, get the lead and trailing shoes synced on one side. Do the same on the other side, then bring the two sides into harmony.
Any tips on how to set lead vs trail. Not sure if they are both meant to bind equally or if I favor one vs the other??
R-dubb is offline   Reply With Quote
Old 04-18-2013, 05:03 PM   #2
nick949eldo
Oddometer: 955
4ls brake adjustment
Greg Bender's web site has the rider's manual for the V7 Sport with a description of how to adjust the 4LS brake. You can download it from here:
http://www.thisoldtractor.com/gtbend...ok_v7sport.pdf
Good luck
Nick
nick949eldo is offline   Reply With Quote
Old 04-18-2013, 05:14 PM   #3
R-dubb OP
Dubbious Adventurer
R-dubb's Avatar
Oddometer: 4,829
Thanks for the reference, however incomplete. It gets about as far as I decribed, but says nothing about how to set-up the link arm on each side. That's the real trick to making these things work. You can't just assume the original set-up will keep them together. I supose, given enough time in one relationship, they will settle into equalibrium as the tighter pad wears faster than the weak one. I'd like to do a little better...
cheers
Old 04-18-2013, 05:21 PM   #4
nick949eldo
Oddometer: 955
Sorry - didn't read it closely - just remembered the source. Yep, its not much use.
Old 04-18-2013, 07:48 PM   #5
MZRider
Neo-Luddite
Oddometer: 704
The second section by Greg Field should be what you seek:
http://thisoldtractor.com/gtbender/m...ake_adjustment
Charlie
http://www.AntietamClassicCycle.com
'69 Guzzi Ambassador,'77 Yamaha XT500,
'88 Ducati Paso, '91 ATK 604
'94 MZ Silver Star, '96 CCM 350
MZRider is offline   Reply With Quote
Old 04-18-2013, 08:58 PM   #6
R-dubb OP
Dubbious Adventurer
R-dubb's Avatar
Oddometer: 4,829
Yupp, that's it. Thanks a bunch!
Old 04-19-2013, 12:57 AM   #7
jbcaddy
Oddometer: 1,211
I'll add my thanks also, even tho I am doing a Suzuki 4shoe.
jbcaddy is offline   Reply With Quote
Old 04-28-2013, 08:03 PM   #8
R-dubb OP
Dubbious Adventurer
R-dubb's Avatar
Oddometer: 4,829
I used the Greg Field method today. Worked like a champ!
The key is figuring out where the "double grip" point is reached.
Syncing front and rear shoes independently on each side is fairly simple since there is little give and take with the arm linkage. Side to side is harder because the cables stretch and bind, and the duplex cable perch tends to tilt in an effort to compensate. I found using the cable stretch as an indicator helped find the center.
Thank goodness I did this on a lift. It would be rough trying to do it on the ground.
Old 04-28-2013, 08:33 PM   #9
anonny
What could go wrong?
anonny's Avatar
Oddometer: 5,581
There's a good tutorial in the Laverda Green Book if you can find a copy.
Kawasaki H1 build thread
71- 450 Honda CL re & re
anonny is offline   Reply With Quote
Old 04-30-2013, 12:45 PM   #10
huub
Oddometer: 137
just dont expect too much from one of those guzzi 4LS,
even when new they were described as adequate.
now, 40 years later , with all the cars equipped with ABS a drum braked guzzi is pretty lethal.
( i've owned a drum braked V7sport for the last 30 years, in those years i spent more time working on the front drum brake than on the engine)
cheers,
Hubert
huub is offline   Reply With Quote
Old 05-01-2013, 09:17 PM   #11
R-dubb OP
Dubbious Adventurer
R-dubb's Avatar
Oddometer: 4,829
cheers,
Hubert
I've had the bike for about five years. This is the third time through on the front brake. I just leave a little more distance. When adjusted, it doesn't bother me much. The bike is kind of a Sunday special.
Old 05-02-2013, 09:38 PM   #12
anonny
anonny's Avatar
Oddometer: 5,581
I will try to remember to scan those pages from my Green Book and send it to you, remind me if you don't hear from me soon.
I have a great memory it's just really short.
Times are GMT -7.   It's 03:47 PM.
