Old 04-19-2013, 07:36 AM   #1
Attico OP
Wrong way 'round
Attico's Avatar
Oddometer: 1,954
Removing paint without harming the original finish on a brake caliper
I'm a bonehead or blind; you pick
I used some duplicolor brush on caliper paint on my rotor hats to get rid of the rusty look. I accidentally dragged the brush against the brake caliper which has some sort of black finish. This is on a new touareg (yes it's a TDI)
The black finish may be powder coat, I'm not sure, and I'd like to remove that caliper paint. It's been on there for 2 weeks; I just never noticed it.
Any ideas before I get at it with a bit of fine sandpaper?
“If you think adventure is dangerous, try routine; it is lethal.” (Coelho)
Attico is offline   Reply With Quote
Old 04-19-2013, 07:43 AM   #2
Bronco638
Nobody Home
Bronco638's Avatar
Oddometer: 4,075
I don't think I'd use sandpaper. You might try some mineral spirits or turpentine first. The problem is that the calipers get hot which means the paint not only has dried but, most likely, cured (and quite well, at that). You may be in for a frustrating series of events.
There are some simple thruths......and dogs know what they are - Joseph Duemer
Andy holds the lead. And he will, all the way to the Highway. Today is his day.
Bronco638 is offline   Reply With Quote
Old 04-19-2013, 09:45 AM   #3
bomber60015
Anatomically Correct
bomber60015's Avatar
Oddometer: 14,614
see above . . . . .. . .
powder coating IS tough stuff, but many things that remove paint will also remove powder coating . . . or try hard enough to fubar up the finish.
it MAY be possible to ease the point of a razor knife or exacto blade between the paint and poweder coat and pop it off . . . . I will likely try that first
"Here is your country. Cherish these natural wonders, cherish the natural resources, cherish the history and romance as a sacred heritage, for your children and your children's children. Do not let selfish men or greedy interests skin your country of its beauty, its riches or its romance.” T.R.
Old 04-19-2013, 11:10 AM   #4
wmako
bored in NJ
Oddometer: 656
Polishing compound - won't do anything to the original finish but make it shinier, but it more abrasive than you might think.
wmako
RRMC
1979 CX500
1990 DR350
Ride Reports
Wmako's moped army rides from Jersey to Una-F'n-dilla (August 2010)
wmako is offline   Reply With Quote
Old 04-19-2013, 11:56 AM   #5
LuciferMutt
Rides slow bike slow
LuciferMutt's Avatar
Oddometer: 11,394
If it took you two weeks to notice, is it really worth removing?
You couldn't hear a dump truck driving through a nitro glycerin plant!
Badasses might screw with another badass. Nobody screws with a nut job. -- Plaka
LuciferMutt is offline   Reply With Quote
Old 04-19-2013, 12:23 PM   #6
Ricardo Kuhn
a.k.a. Mr Rico Suave
Ricardo Kuhn's Avatar
Oddometer: 12,403
Sorry if I sound stupid but what about brake fluid...?
The caliper finish most be inmune to it but the new paint will fall right off..
Wanted: worn, ugly, cheap motorcycle cover for a big GS 1200
Ricardo Kuhn is offline   Reply With Quote
Old 04-19-2013, 02:14 PM   #7
Attico OP
Wrong way 'round
Attico's Avatar
Oddometer: 1,954
I know... Blind or dumb, or maybe both..
I was actually able to remove the paint. You know when they say prep is the most important step, well for once that worked in my favor...i was able to chip the paint off with a plastic scraper. There is only one part of the caliper where is didn't come off perfectly, thats where is isn't machined. Not too bad afterall.
Thanks for the suggestions.
Times are GMT -7.   It's 12:39 PM.
