Old 04-19-2013, 05:05 PM   #1
Nailhead OP
Free at last!
Nailhead's Avatar
Oddometer: 6,188
Had any Luck with Tyre Pliers?
I bought these from an inmate some time back because they looked like a good idea:
I'm having misgivings about that notion: I've been cranking on them for the last 45 minutes at various points around the back wheel off the 990 and have accomplished nothing other than breaking a sweat, scarring the tire, and actually heating up the tool. I'm one post away from consigning these to the hopper, so has anyone used these successfully, and if so, what were your methods?
No emergency here-- I'm just familiarizing myself with various tire-changing tools in my basement.
-Chris
'7? Benelli 650S, '80 BMW R100 RS, '93 Ducati 900 SS, '07 KTM 990 Adventure
Nailhead is offline   Reply With Quote
Old 04-19-2013, 05:29 PM   #2
Motomedic
Motomedic's Avatar
Oddometer: 2,481
No doubt Jeremy's words (from your sig line) were running through your head when you started the process....
On my 950, I machined off one of the "safety beads" on the inside of the rim, and it's still a PITA to do in the field. I have the Motion Pro BeadPro tools, and they won't do it. I simply use the sidestand.
And yes, you can use the sidestand of your bike WHILE it's on the centerstand with the rear wheel off. Just make sure you secure the centerstand in it's deployed position with a strap.
Feike
I don't have to agree with you to like you or respect you. -Anthony Bourdain
Motomedic is online now   Reply With Quote
Old 04-19-2013, 05:31 PM   #3
HapHazard
Waiting for Gudenov
HapHazard's Avatar
Oddometer: 2,258
No, don't know if you've seen it, but there's a brief demo at 2:14 here:
Looks interesting, but the jaws seem small, compared to the car & truck versions - they comment in the beginning about making sure the jaws press on the bead, not the sidewall or tire damage can result.
Good luck!
HapHazard is offline   Reply With Quote
Old 04-19-2013, 06:59 PM   #4
ericrat
Oddometer: 1,188
Good luck!
I'll bet the inside edge of the jaws need to be 1/8 to no more than 1/4 of an inch from the edge of the rim.
Have you visited ride reports lately ?. click HERE
ericrat is offline   Reply With Quote
Old 04-19-2013, 07:25 PM   #5
griffo1962
griffo1962's Avatar
Oddometer: 1,505
a lot of guys down here use them, never heard any of them say this.......
griffo1962 is offline   Reply With Quote
Old 04-19-2013, 07:39 PM   #6
Nailhead OP
Free at last!
Nailhead's Avatar
Oddometer: 6,188
I tried repeatedly to hold the jaws on the bead, but they just take the path of least resistance & end up halfway up the sidewall.
They look like such a great idea. What a disappointment. I'm glad I tried them out before realizing they didn't work when I really needed them.
-Chris
Old 04-19-2013, 07:46 PM   #7
Daryl_Stamp
Daryl_Stamp's Avatar
Oddometer: 791
Does that thing mount on the inside of the rim during use?
Is it common or helpful to put a spacer between the rim & device to keep it from creeping onto the sidewall?
The concept of the device seems good, but sounds like in practice may not be so great.
I've used the side stand technique on my GS, but it's not my method of choice.
A beer and a laugh can ease the aggravation, ....
Live while you're alive.
Daryl_Stamp is offline   Reply With Quote
Old 04-19-2013, 07:52 PM   #8
HapHazard
Waiting for Gudenov
HapHazard's Avatar
Oddometer: 2,258
The car & truck versions seem to use a combination "squeeze and push" action that presses down on the side wall and pushes down the bead simultaneously. It's used on one bead at a time. The bike version seems to just work like a large C-clamp with a better jaw arrangement but it squeezes both beads.
However when I've used a c-clamp to break beads, I've always had to use a piece of wood to put half the clamp on the rim because just squeezing both beads never worked for me, so I can see why Nailhead isn't having much luck.
Why wouldn't the truck version (or extended car version) work (better) on a bike tire than the bike version?
I guess the bike version is "packable", but so's a c-clamp (which is also more KLR-friendly (cheaper).
I really do like the car & truck versions (and Australia), though...
Old 04-20-2013, 11:15 AM   #9
Beezer
Oddometer: 5,740
ya, if you get a tough one a backing plate helps. heres my clamp & plate setup...
Beezer is offline   Reply With Quote
Old 04-20-2013, 12:12 PM   #10
Nailhead OP
Free at last!
Nailhead's Avatar
Oddometer: 6,188
That's kind of the idea I'm toying with: some sort of retrofit to increase the effectiveness of those narrow jaws.
-Chris
Old 04-20-2013, 09:36 PM   #11
RVDan
RVDan's Avatar
Oddometer: 2,600
I use the automotive version regularly and they're great. I don't see the motorcycle version being that great though with no way to force it down into the bead.
Sometimes wheelies happen
Originally Posted by RedRocker
You can never have too much hook.
RVDan is online now   Reply With Quote
Old 04-20-2013, 10:23 PM   #12
QSrider
QSrider's Avatar
Oddometer: 48
Are you sliding them on from the outside of the tire?
I'm asking because you're saying that you're scarring your tire...
Try slidling them on from the inside (rim side), that way it will slide into the bead and do its job. Slide it on like the C-clamp on the pic:
I hope I'm understanding your problem... They just seem like they would work great.
I'm curious to see/hear what you figured out now.
Good luck,
Eric.
_____________________
2001 BMW F650GS Dakar
2003 BMW R1150RT
QSrider is offline   Reply With Quote
Old 04-21-2013, 11:07 AM   #13
DC2wheels
Castle Anthrax troll
DC2wheels's Avatar
Oddometer: 2,544
Been using this for a few years. Works on tires up to 160 wide.
'92 K100RS
'12 DRZ400
sugarhillctd on the world-wide K11OG forum
I got my MotoMatters calendar, did you?
DC2wheels is online now   Reply With Quote
Old 04-22-2013, 07:05 PM   #14
Nailhead OP
Free at last!
Nailhead's Avatar
Oddometer: 6,188
I have only used them from the inside of the rim per the instructions. Maybe a spacer block of some sort would be a solution.
I think RVdan's post pretty much encpsulates it-- bad design.
-Chris
Old 04-22-2013, 07:57 PM   #15
Yellow Pig
Allergic to Asphalt!
Yellow Pig's Avatar
Oddometer: 7,475
Keep in mind that 950/990 tires have a safety bead on the inside of the rim. Many people have 3-5" of the safety bead ground off to ease trail side repairs.
Yellow Pig is online now   Reply With Quote
Times are GMT -7.   It's 02:08 PM.
