Old 04-19-2013, 08:27 PM   #1
Red Dust OP
Oddometer: 463
XT1200 vibes?
Finally I put down a deposit on a 2nd hand XT1200 2010 model with 6500 km`s on the clock (4060 miles).
Been lurking to get one even before they were released and it took me awhile.
Many bikes I got problem not being smooth which means uncomfortable feeling in my hands even long time after the ride. Maybe the bike is to "new" and will get smoother after some time. Will put foam grips on.
It does have Pro Taper bars which might not be the best.
Heard about some kind of system that got rubber mounted handlebars, could be something?
Otherwise the XT1200 is an awesome bike and pretty sure it will easily replace my DL650. It also been approved by my ms which means a lot!
Was thinking about the new KTM1190 but could not justify more than double the price and go bush with a $25000 bike does not really go well in my book.
Some issues I should look at when purchasing a 2nd hand XT1200?
I`m quite excited to have this bike in my stable and keep the others company. It does come with Yamaha crash bars, sump guard and panniers/box all for under 1/2 price compared to the KTM1190, of course no warranty but that is the risk you take I guess.
Yamaha does have a good reliability history though so it all should be ok.
You will hear from me more in a near future!
Cheers.
Red Dust is offline   Reply With Quote
Old 04-19-2013, 08:44 PM   #2
Pete-NZ
Pete-NZ's Avatar
Oddometer: 739
Vibes.............. Try a XT660R....
Here.... my XR250 leaner side car build
http://www.advrider.com/forums/showthread.php?t=716993
Pete-NZ is offline   Reply With Quote
Old 04-19-2013, 10:25 PM   #3
Red Dust OP
Oddometer: 463
No thanks!
Just have to accept that we all getting older at least body wise.
Can not wait until I pick her up and take her in the bush.
Believe we will have a great time together.
Old 04-20-2013, 06:50 AM   #4
MotoChris521
MotoChris521's Avatar
Oddometer: 630
dreaming of moist soil
MotoChris521 is offline   Reply With Quote
Old 04-20-2013, 07:17 AM   #5
Blue Mule
Persistent Slacker
Blue Mule's Avatar
Oddometer: 2,041
"The darkest places in hell are reserved for those who maintain their neutrality in times of moral crisis." Dante Alighieri
Blue Mule is online now   Reply With Quote
Old 04-20-2013, 07:29 AM   #6
s-flow
Oddometer: 9
http://roxspeedfx.com/product/anti-v...ion-risers.htm
These are nice and soften the vibes a bit, rather expensive though.
Longer brake and clutch lines probably needed.
Add Progrip 714 grips and even less vibrations. :-)
s-flow screwed with this post 04-20-2013 at 07:34 AM
s-flow is offline   Reply With Quote
Old 04-20-2013, 08:40 AM   #7
Red Dust OP
Oddometer: 463
Also heard about precision handlebar mounts.
Will start with foam grip and take it from there, might get used to the vibes on this excellent machine.
Old 04-21-2013, 07:40 AM   #8
Greg the pole
Greg the pole's Avatar
Oddometer: 120
vibes
the pro taper will be a much better bar, than the stock.
I run bmw grips on mine (the old school ones, fat on one end, and thinner on the other) with rox 1.75" risers (non dampened)
no complaints, just came back from a 3000km spin around California. No issues.
enjoy the bike
oh yeah, trip write up here: http://thetenerist.wordpress.com/201...lifornia-2013/
Greg the pole is offline   Reply With Quote
Old 04-21-2013, 07:58 AM   #9
NomorBills
WesternExplorer
NomorBills's Avatar
Oddometer: 153
Does it vibe enough to shake the mirrows? Mine has minimal feel of vibes in the bars.
Maybe there is something wrong. Try another ST if you can.
This engine has two counter balance shafts and if it is off that my be your problem.
The bars should not be buzzy.
NomorBills is offline   Reply With Quote
Old 04-30-2013, 08:42 AM   #10
NonDairyCreamer
incomprehensible
NonDairyCreamer's Avatar
Oddometer: 95
You mentioned going bush and your XT has the Yammy sump guard? Get a Rumbux or RideOnADV to keep the oil inside the motor. I mention those two in particular because those are the only ones I'm aware of that mount to the frame without any motor contact, essential for proper protection.
As for vibration you should spend a bit of time here: http://www.yamahasupertenere.com/ THE BEST resource on the web.
And there are two huge threads in Beasts that cover the XT with many experienced owners willing to help. I think it has been mentioned the bike gets smoother in the 6000 mile range. Be sure proper tuning has been done to put aside out of balance fueling. I don't know if this has been mentioned or would be a problem for the XT but there are instances of vibration caused by improperly torqued motor mounts. Just a thought if no other solution is found.
Be sure to check your spokes although those should have bedded in long ago but worth the time. Other than the sump guard and maybe some protection for the fork seals to give them longer life I can't think of any reliability problems with the XT12Z.
http://www.advrider.com/forums/showthread.php?t=545850
http://www.advrider.com/forums/showthread.php?t=592384
"Which will you have: wise madness or foolish sanity?" Cervantes' Don Quixote
NonDairyCreamer is offline   Reply With Quote
Old 04-30-2013, 08:35 PM   #11
Red Dust OP
Oddometer: 463
Got my eyes on the ACD sump guard from Spain, looks good and tough!
I`m sure the vibe problems will disappear/become less the more I ride this amazing machine.
Need to find out how to put heavier bar end weights than the stock ones.
Put it on a couple of other bikes which did help to some degree.
Cheers!
Old 05-01-2013, 06:01 AM   #12
NonDairyCreamer
incomprehensible
Oddometer: 95
oops, I forgot about the ACD. Tested and proven by Juamev. It looks the best too.
Old 05-01-2013, 07:07 AM   #13
RED CAT
Bumpy Backroader
RED CAT's Avatar
Oddometer: 2,961
Vibes!
What vibes?
RED CAT is offline   Reply With Quote
Old 05-01-2013, 07:21 AM   #14
Whorepedo
Whorepedo's Avatar
Oddometer: 501
Thats exactly what I was gonna say.
After I take a ride on my 660 and my ST feels like a Cadillac. I had a 1200GS and 950ADV prior to owning my ST and the ST is no worse/better than either of those.
2000 Suzuki TLR; 2012 Yamaha Super Tenere; 2005 XT660R; 1993 TDM850; 1977 Kawi KE175
Whorepedo is offline   Reply With Quote
Old 05-01-2013, 03:02 PM   #15
Happy Snapper
GOMOB.
Happy Snapper's Avatar
Oddometer: 2,131
Cheers.
Mate I am at Clayfield.. PM me and we'll go for a coffee and I would be happy to give you some tips based on my 7K with the Super 10!
M
Happy Snapper
Never trust atoms.... they make up everything!
Read my Blog: http://snapshotsfrommark.blogspot.com.au
Happy Snapper is online now   Reply With Quote
Times are GMT -7.   It's 01:10 AM.
