Old 04-20-2013, 09:12 AM   #1
wbbnm OP
wbbnm's Avatar
Oddometer: 2,111
Basecamp Mapsource elevation profile problem
I have been trying to plot elevation profiles for a track I have thru the mountains in southern Utah.
Neither Mapsource or Basecamp give an accurate profile. Mapsource is closer to reality than Basecamp.
When I manually look at elevations in the track I can see where it goes over 10k ft in places.
Basecamp shows it going from 6500 to 7500 ft with basically two flat lines.
I have tried viewing the profile with 3 mapsets - Topo West, Topo 24k, and even City Navigator all with the same results.
Any suggestions about what might be the problem?
Edit: I found the problem. There is virtually no elevation data in the track. I created most of it from a route using WinGDB3. I must have spliced in a small section of a real track with elevation data. But Basecamp spread this elevation data out over the entire track in creating the graph.
When I create a route in Basecamp, I get a good elevation plot.
wbbnm screwed with this post 04-20-2013 at 09:17 AM
wbbnm is offline   Reply With Quote
Old 04-21-2013, 05:12 AM   #2
9Dave
Bazinga!
9Dave's Avatar
Oddometer: 13,021
Track elevation data comes from information that you record along with the track.
So as you found, if you draw one on the computer, it will not be present.
dunno.....
Old 04-21-2013, 09:20 AM   #3
wbbnm OP
wbbnm's Avatar
Oddometer: 2,111
I found that if I created a route using Topo24k and then convert that to a track in Basecamp, I do get elevation information.
I suspect it would also work in Topo West, but one would have to manually put in all the points since autorouting isn't supported.
I normally create routes using City Navigator, but it doesn't have elevation info. So none gets put in the tracks.
Times are GMT -7.   It's 05:56 PM.
