Go Back   ADVrider > Riding > Trip Planning
Old 04-23-2013, 02:42 AM   #1
pauldelft OP
Oddometer: 5
Suitable smallish bike for a tall rider for RTW travel
Hi guys,
The more i read forums like adv and hubb, the more i'm convinced a small bike (250cc-450cc) is better for rtw travel (blend in with the locals, better mileage, easier to handle, cheaper carnet etc etc).
I however have a problem - i'm a tall guy (198/6' 6").
What is a suitable bike or easy to adapt bike in this category for a tall guy like me? Eventual plan is to drive from Europe to SA.
Paul
pauldelft is offline   Reply With Quote
Old 04-23-2013, 06:27 AM   #2
willys
willys's Avatar
Oddometer: 2,904
I have a KLR650 but have sat on a KLR250 and it wasn't much lower than the 650 in hieght. It is a simple engine and bike, so repairs wouldn't be an issue. I'm sure there are more modern bikes out there in a higher cc range with better horse power ratios. But if you want to fit in, an older more reliable bike in the smaller cc range like you have stated is probably your best bet. Any bke will take you RTW if you look after it.....it's all personal preferance....nothing else.
willys is offline   Reply With Quote
Old 04-23-2013, 07:15 AM   #3
Stu
Buffo Maximus
Oddometer: 930
The Eternal Quest
Paul,
You pose a question that has bedeviled many on this site. What bike is reliable, cheap to operate and has adequate comfort for very extended trips. Unlike Willy, I do think there are bikes you should definitely avoid (British singles come to mind as well as some contemporary Chinese bikes -- mechanical companions of very questionable reliability). There are bikes that are known for their RTW qualities (BMW & KTM dual sport singles, KLR 650 & 650 DRs are examples). I would look to one of these since they are built with this sort of extended travel in mind. Anything smaller than 500 c.c. will put more stress on the engine traveling at higher speeds for long distances. You can do it if you are less risk adverse than some people. My cousin bought a used and abused Zundapp 175 c.c. two stroke in India and rode it to the outskirts of Berlin before it finally had a terminal melt down.
I doubt that you, at 6'6", and on a packed motorcycle, would really blend in with the locals. Perhaps. Are you considering making your gear look like crates of chickens, wearing flip flops, torn cheap pants and a worn out Harley T-shirt?
Stu
Stu is offline   Reply With Quote
Old 04-23-2013, 07:33 AM   #4
Spiritwalker2222
Oddometer: 112
I'm 6'5", I feel your pain. But for a RTW bike, I'd just buy a DRZ400S, put a tall seat, tall handle bars and risers on the bike. I could be biased as I have a DRZ.
Spiritwalker2222 is offline   Reply With Quote
Old 04-23-2013, 09:13 AM   #5
holckster
dougholck
Oddometer: 825
DR650se
No radiator
No valve shims
No fuel Injection
Huge availabilty of aftermarket stuff to set it up your way.
http://www.procycle.us/bikepages/dr650.html
BTW
There is No Sizuki warranty outside of USA if that matters.
If starting with a newer machine, would be wise to check warranty coverage area of the manufacture you are considering.
Doug Holck
Lodi, CA
3 Continents - 7 Countries - 50 States
04 BMW 1150GS Adventure
08 DR650
02 BMW K1200LTe
05 Yamaha TW200
BMW MOA 109760
AMA Charter Life Member 518333
International Fellowship of Motorcycling Rotarians
HDDC POSSE
holckster is offline   Reply With Quote
Old 04-23-2013, 10:54 AM   #6
Spiritwalker2222
Oddometer: 112
DR650, KLR650 and KLX250, those are all small bikes. Good if you 5' 3". Better to start off with a bigger bike.
Edit: when I say bigger, I meant bigger ergonomics.
Spiritwalker2222 screwed with this post 04-23-2013 at 11:38 AM
Old 04-23-2013, 12:07 PM   #7
MacNoob
MacNoob's Avatar
Oddometer: 1,584
6'+ here. Have KLR650 with tall seat. Sat on new Suzi DR650 the other day. It seemed like a tiny little dirt bike compared to KLR. Seat was like sitting on a 2x4 but that's easily fixed.
"Ignorance, you see, can be out thought. Arrogance can be outmaneuvered. But ignorance and arrogance combined are unassailable."
82 Honda C70, 71 Honda CL175, 08 Kawasaki KLR650, 85 Honda GL1200 Goldwing
MacNoob is offline   Reply With Quote
Old 04-25-2013, 02:33 PM   #8
BlueLghtning
Riding is my passion
BlueLghtning's Avatar
Oddometer: 5,000
Wr250r
Have you looked at the WR250R? This is a tall bike and I have to say for small FI 250, I'm pretty impressed. I'm 6'4/250lbs by the way. The great thing about the WRR is its 26k mile valve check and 350w stator. That's unheard of on DS bikes. So not only are valve checks far and few between, you can run some pretty decent heated gear on it. IMOP, the WR250R would make a great RTW traveler. For comparison, we have the 2013 Honda CRF250L in our garage and I've spent time on the KLX250S. The WRR has the most powerful motor of these 3 and the FI is top notch, and for a tall guy, its the best fit of the 3 by far. The Honda is probably the most cramped of the 3. The seat to peg height on the Honda feels more like a sport bike than a dual sport, but it works for my wife who only has a 29" inseam.
I've got the Renazco seat on my and setup for me as a tall person and I'm very comfy on it. I actually own a DR650 and my biggest complaint is its so much more cramped compared to the WRR.
If you haven't checked it out, Mark at BigDogAdventures has a pretty good write up on his WRR bulid and he took his to AK and back and basically for the same reasons decided it was a good small light weight adventure bike. - http://bigdogadventures.com/WR250R.htm
IMS makes a 4.75 gallon tank for it too which gives you a nice range. Safari makes a 3.7gal tank.
This is a recent pic of my wife and I next to the CRF & the WRR. She's 5'4" and I'm 6'4". That's the Seat Concepts seat on my WRR in this picture. I was borrowing it from a friend and wasn't that impressed with it. I like my Renazco better.
BlueLghtning - Follow me on my SPOT Messenger
Mine: 09 DL650, 08 WR250R,
Hers: 07 Ninja 650R, 13 CRF250L,
Smugmug Pics - Save $5 <-- Click Here
BlueLghtning screwed with this post 04-25-2013 at 02:39 PM
BlueLghtning is offline   Reply With Quote
Old 05-03-2013, 01:54 PM   #9
sea2sum
Oddometer: 11
I'm 6'7" and fir perfectly on my 640 adventure. I have raised bars, and had the suspension correctly built by Race Tech. I'd do a RTW with it no problem. I've ridden it all over the US and Mexico, and I think it's the perfect balance of a great dirtbike, but the comfort and range of a bigger bike.
Not cheap though:(
sea2sum is offline   Reply With Quote
Old 05-03-2013, 05:28 PM   #10
Lone Rider
Registered User
Oddometer: 25,130
Small and light is relative.
IMO, the 650ish bikes are above that, being mid weight/size.
125's are light weight...
Then you get into the 250-400 size bikes.
I'm a huge fan of air-cooled bikes. Mas simple.
If you've never looked at a DR350SE, do so. The best year models were the last two - '98-99, with dirt forks.
Just find any bike that fits your needs.
Then load and go...
Lone Rider is offline   Reply With Quote
Old 05-04-2013, 04:00 AM   #11
Pecha72
Oddometer: 3,888
Air-cooling is basically more simple. But also more primitive. There are reasons, why almost every modern car and motorcycle has water-cooling.
But yeah, some will always prefer to also have carburetors, contact breakers and drum brakes. Just keep in mind, as the bike gets older, everything wears more and more. I'm not so sure that's an advantage for RTW, when spare parts are not easily available, and you'll do most maintenance and fixing yourself.
Pecha72 is offline   Reply With Quote
Old 05-04-2013, 05:07 PM   #12
Lone Rider
Registered User
Oddometer: 25,130
Originally Posted by Pecha72 View Post
....There are reasons, why almost every modern car and motorcycle has water-cooling.......
What would those reasons be, in your opinion, and how they relate to rtw moto travel?
Old 05-05-2013, 09:12 AM   #13
Pecha72
Oddometer: 3,888
In short, water-cooling allows to build engines with smaller tolerances, because heat expansion is more controlled.
For RTW, it's not decisive either way, there are proven overlanders with both types of cooling. But nowadays it's getting harder to find new air-cooled machines, and the age of the bike you choose, could be something to think about. How big an issue it is, of course depends on your mechanic skills as well, and if you'll make a total stripdown before the trip, then an older bike could be an ok choice. If you get a newer bike, then that may not be necessary.
Old 05-05-2013, 08:06 PM   #14
thetourist
Just passing thru
Oddometer: 4,160
Good for you picking a small bike. I've always liked 350 size and notice some "big bike" riders are starting to get the message.
I'm 6'1 and have a big butt, so I sit tall. My DR350SE fits me without modification. I sit at the back of the seat and that gives me plenty of arm and leg room. When I stand the bars are at the limit of my reach. You might need a seat and handlebar raise.
I have the big tank and am going for a better seat soon. Going to raise the front a bit and widen the back, then all will be good.
It is a proven round the world bike. Under 300 lbs, 6 speed, thrifty, reliable. Nice clean examples at $2000
KLR/KLX/SuperSherpa 250 seems to be popular, also
DRZ400 would be my choice if it had a 6-speed. That 6th gear is a miracle, on long trips.
thetourist
The gate guard glares at me. "It's after curfew." He looks me up and down, "What do you think you are, some kind of ****** tourist?" ..Phu Loi 1969
My Idaho =7893
thetourist is offline   Reply With Quote
Old 05-30-2013, 04:46 AM   #15
XRman
XRman's Avatar
Oddometer: 2,759
wide ratio DRZ
THe DRZ400 ( mine is an E model) is tall in the seat . Add an extra inch and add bar raisers and it should suit your body.
Other mods I have done
1) 28 L fuel tank Safari tank ( 500 km range)
2) heavier springs and plush valving.
3) ACT wide ratio gear box or Nova gear box ratios give standard first with an over drive fifth. Much more versatile!
4) Ralle-moto steering damper
5) moto-racks rear and side luggage racks to carry gear in soft pannier bags.
6) 40 cm windshield
7) bark buster lever protection
8) Force radiator and sump guards
9) engine side cover armour ( B&B engineering in Oz)
Much as I like the Yamaha WR250R ( I owned a WR250 F and loved it) for its handling and 6 speed box, the biggest drawback I can see for touring is the fuel tank size. The biggest tank Safari make for this bike is 14L. which is not enough for longer rides. EFI is a great idea and is efficient and altitude change friendly, but if it fails and you are in a third world country, it might be hard to fix. I know FCR carbies are not that easy to fix either , but probably more repairable in a low tech workshop.
XRman is offline   Reply With Quote
Times are GMT -7.   It's 11:56 PM.
