Go Back   ADVrider > Riding > Mapping & Navigation
Old 04-25-2013, 11:32 AM   #1
mcnut OP
Oddometer: 1,384
Question Montana Topo Contour Line Question
With TOPO loaded can the contour line detail be controlled other the just the normal "detail level" global control.
I ask because BaseCamp "Profiles" has an option for no/off and wonder if this has been duplicated with the profile settings on the Montana itself?
If so is it just on/off, show/hide or something more.
Used to have a Garmin V which allowed total control of when and which contours lines were displayed, a great feature which has sadly been dropped.
Bruce
mcnut screwed with this post 04-25-2013 at 01:31 PM
mcnut is offline   Reply With Quote
Old 04-25-2013, 03:15 PM   #2
DRTBYK
Long Haul Adventurer
DRTBYK's Avatar
Oddometer: 6,142
Bruce
No. You can not "no-show" the Topo contour lines on the Montana. Send the Montana Team a Feature Request.
Dan - All Things GPS
Reviews at www.GlobeRiders.com
DRTBYK is offline   Reply With Quote
Old 04-25-2013, 04:23 PM   #3
mcnut OP
Oddometer: 1,384
Thanks, funny Garmin sees value in this option for the computer (BaseCamp) but not for the GPS.
I will make a request asking for user control of showing minor and major contour lines at differing zoom levels similar to what the "V" was capable of.
Bruce
Old 08-22-2014, 11:14 PM   #4
mudbreeder
mudbreeder's Avatar
Oddometer: 50
this is the reason i still use my 278 it is almost 12 years old, the only thing that makes me look at other devices is the expandable memory
mudbreeder is offline   Reply With Quote
Old 08-23-2014, 08:57 AM   #5
Yellow Pig
Allergic to Asphalt!
Yellow Pig's Avatar
Oddometer: 7,623
I've found that turning of the shading helps a lot with legibility of the map.
On the Montana adjusting the detail level helps show more info when you are zoomed out for a bigger picture.
Not sure if this helps.
Times are GMT -7.   It's 01:16 AM.
