Thread Tools Search this Thread Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Old 05-09-2013, 04:45 AM   #31
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,009
What would be interesting is if someone had backed up all the files from a "bad" 350, made the exchange, and then was able to compare those with the files from a new "good" 350 and see where there are differences.
Old 05-09-2013, 09:33 AM   #32
Travex OP
Lost is found
Travex's Avatar
Oddometer: 141
Interesting perhaps, but I won't be the the one to tinker with possible success.
"Rider assumes full responsibility"
2012 Super Tenere For Sale in "The Flea Market"
Travex is offline   Reply With Quote
Old 05-09-2013, 10:58 AM   #33
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,009
I would not tinker with something that works, either.
I was imagining an electronic comparison of files, a "diff" we sometimes call it in IT, that would be performed in a separate test area, as opposed to doing anything in the unit itself.
Old 05-09-2013, 11:02 AM   #34
flabombarda
Oddometer: 8
How could we extract these files from the unit ?
Are they all available when we plug it on the USB ?
I meant, are all the files visible ?
If yes, that in theory is something pretty easy to do.
a simple script calling an CHECKSUM function to see if there is any difference at the binary level could work.
flabombarda is offline   Reply With Quote
Old 05-09-2013, 11:23 AM   #35
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,009
Yes, I think they are.
Old 05-09-2013, 02:44 PM   #36
VMSfan
Oddometer: 9
A follow up to my previous one. Followed directions for doing a hard reset, did a full web updater update, got all current map and software updates. about 1000 miles later, not showing any issues so far.
When mine froze, it was just following my progress. I did not have an address or anything set. I did change things from stock configuration to fit what I like to see in layers and layout, but nothing too drastic as I don't like seeing too many things all at once.
After the reset, the only thing different was that I chose a different "view".
I use my GPS not only for directions, but during every day use, it serves as my speedometer and clock.
VMSfan is offline   Reply With Quote
Old 05-09-2013, 04:48 PM   #37
Travex OP
Lost is found
Travex's Avatar
Oddometer: 141
Of course your suggestion is a good one and could/would be helpful.
Old 05-10-2013, 06:09 PM   #38
doughnut
doughnut's Avatar
Oddometer: 8
I just got a new 350LM and it has been working fine in map view. Today was the first time I'd used it to find a location. It froze while en route. Did the reset/calibrate dance. Froze again on the way home.
Map in 3D view. Current firmware and maps via Express. Regular voice. X-Wing fighter icon. I did load a bunch of POI files (which don't appear on the device, but to which I can navigate). It was paired to a Sena SMH10.
Hoping I'm not going to have to do the exhange as well. Have a long NorCal trip coming up.
Go that way really fast. If something gets in your way, turn.
doughnut is offline   Reply With Quote
Old 05-10-2013, 11:00 PM   #39
Travex OP
Lost is found
Travex's Avatar
Oddometer: 141
Good accounting of your circumstance and too bad you got the problem. I failed to say that mine failed during either "Go Home" or simply following the map. Mine's paired to an SMH10-R with a vanilla setup plus poi's. It will get a look-see on a 5k ride soon. Good luck.
Old 05-11-2013, 04:39 AM   #40
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,009
I would contact Garmin now.
Old 05-11-2013, 10:42 AM   #41
Lion BR
I'd rather be riding
Lion BR's Avatar
Oddometer: 3,821
I second that. For the selfish reason that I'm waiting for Garmin to solve this issue before I commit to a purchase. I have the Oregon 450, so I'm not looking for the Montana (which seems to have problems of its own).
Whenever we are riding, we are an ambassador to our sport
I'd rather be riding!
Lion BR is offline   Reply With Quote
Old 05-13-2013, 10:07 PM   #42
doughnut
doughnut's Avatar
Oddometer: 8
I was told by Garmin CS that the only thing that would cause freezing is corrupt software. However, the only solution I was offered was a hard reset, which I've already done (to no avail). I was given the option to exchange but I'd have to send mine back first (paid by me) and wait for the replacement. I went to my original seller, ordered a brand new one and will exchange the receiver when it arrives and get a refund (and won't have to pay shipping for the new one or return). Hopefully it won't suffer the same problem.
Old 05-14-2013, 04:24 AM   #43
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,009
Did you try what I put in post 15?
Old 05-14-2013, 09:41 PM   #44
Travex OP
Lost is found
Travex's Avatar
Oddometer: 141
Went 250 miles today with the new replacement unit and had no problems. Everything was as it should be.
One note I failed to mention and would be interested to hear if others with the freezing problem have experienced this also... But leading up to the freezing I recall a 'reluctance' of the 350 to autozoom correctly. Meaning it would not zoom in as it it should. It would rather stay far out or barely zoom in.
Just an observation.
Old 05-15-2013, 04:53 AM   #45
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,009
Was the unit they sent brand new? I know you had some concerns about that.
Times are GMT -7.   It's 04:52 PM.
