Thread Tools Search this Thread Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Old 05-15-2013, 01:00 PM   #46
Travex OP
Lost is found
Travex's Avatar
Oddometer: 144
Yes it is and it arrived quickly.
"Rider assumes full responsibility"
2012 Super Tenere For Sale in "The Flea Market"
Travex is offline   Reply With Quote
Old 05-17-2013, 06:31 AM   #47
Travex OP
Lost is found
Travex's Avatar
Oddometer: 144
The new unit failed with the freezing problem yesterday while being directed to a single destination. Twice in one hour during a 250mi ride. First freeze was 9 miles from home. Certainly I'm disappointed, both with the failure and the fact that Garmin will not acknowledge their problem. When I get home I'll address the issue once and only once with them. If they fail to correct the situation to my satisfaction (full refund), the matter will be referred to Governmental and civil consumer bureaus. Enough is enough.
Old 05-18-2013, 06:57 AM   #48
Lion BR
I'd rather be riding
Lion BR's Avatar
Oddometer: 4,049
If this is happening on several 350's, I'm sure you won't be alone on this "conversation" with Garmin.
Whenever we are riding, we are an ambassador to our sport
I'd rather be riding!
Lion BR is offline   Reply With Quote
Old 05-18-2013, 04:43 PM   #49
Travex OP
Lost is found
Travex's Avatar
Oddometer: 144
Twice in the first forty miles today.
Old 05-19-2013, 06:24 PM   #50
Travex OP
Lost is found
Travex's Avatar
Oddometer: 144
3 freezes in 30 miles today.
Old 05-19-2013, 06:31 PM   #51
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,172
Bummer.
Old 05-26-2013, 07:30 AM   #52
Lion BR
Lion BR's Avatar
Oddometer: 4,049
Just curious... Did you follow up (again) with Garmin on this?
Old 05-26-2013, 07:00 PM   #53
Travex OP
Lost is found
Travex's Avatar
Oddometer: 144
Been too busy and will soon. Will update with details.
Old 05-27-2013, 02:55 AM   #54
Flying GS
Flying GS's Avatar
Oddometer: 12
Same problem with 350ML in the UK. Freezes daily. Reset + updated to no avail, contacted support, told them what happened and what I did, and they told me to... Reset + update :-)
Next step according to them is exchange, but I think from what I see here that it's not the answer!
Flying GS is offline   Reply With Quote
Old 05-27-2013, 03:17 AM   #55
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,172
That depends on whether they have created some kind of fix yet or not on the newest ones, right? The thing I wonder is why some freeze and others don't.
Old 05-27-2013, 12:16 PM   #56
Jantan
Oddometer: 6
Hello from Finland! I got my Zumo 350LM last summer and it worked fine until this spring. During the winter I did not use it and during my first drive in april it got STUCK
I contacted Garmin Finland and they said I could have same map twice in the GPS, but I didn't have and I tried hard reset (put one finger on the right bottom corner of the screen and push start button) I did helped for awhile, but then it froze again.
Two weeks ago I took it to the Garmin Finland (my luck it is only 1km away) and they said they are going to replace it. Today I got a brand new 350LM I updated it and ran for a test drive and WHAT THE HELL! IT GOT STUCK after a 30km. I booted it on the fly and rest of the 150km test run it worked ok!
My trust in this machine is gone!
Jantan is offline   Reply With Quote
Old 05-27-2013, 01:15 PM   #57
Krono
Speed Junkie
Oddometer: 193
Someone (motocyclu) here http://www.sorcieremonique.com/t1278...ge-zumo-340-lm (maybe) have a cure :
translated ---> "remove (cut) with a cutter the small (rubber) separation between the contacts on the Zumo stand"
Worked for him : no more freezing since he did that.
btw, my 350 never freezes ... hope it lasts
L
SM510R
Krono is online now   Reply With Quote
Old 05-28-2013, 06:21 AM   #58
Lion BR
Lion BR's Avatar
Oddometer: 4,049
L
That's interesting.
Based on this it should be the case that if it freezes, it only happens on the motorcycle stand (assuming this is the stand they are talking about, my French is limited to a couple of swearing words).
On a car's dash board, connected differently, it should never freeze.
And if that is the case, Garmin should be sending new stands, not new Zumos to the people with the freezing problem.
Old 05-28-2013, 08:47 AM   #59
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,172
I would keep making Garmin replace the unit until I got one that did not freeze. I would not start modifying things to try to fix their problem. Doing so only enables Garmin to avoid creating a real solution. At least, that is my opinion and worth every penny you paid for it.
Old 05-28-2013, 09:31 PM   #60
Lion BR
Lion BR's Avatar
Oddometer: 4,049
But if the problem is really on the stand, sending new machines will not solve it either.
Times are GMT -7.   It's 07:11 AM.
