Thread Tools Search this Thread Rating: Thread Rating: 9 votes, 5.00 average. Display Modes
Old 06-05-2013, 08:01 AM   #91
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,309
Software Update Available!
That last bulleted item might be relevant to this thread. Time will tell.
The notes:
zumo 350 (GCD File)
(43.29 MB)
Change History
Changes made from version 2.50 to 2.60:
  • Added the option to display a clock on the map page.
  • Added the ability to enter location coordinates using European coordinate systems.
  • Improved address entry functionality.
  • Fixed the display of speed limits that are enforced only at certain hours of the day.
  • Fixed an issue that caused audible traffic alerts to repeat.
  • Fixed an issue that caused the device to shut down when used with some 3rd-party GPI files.
  • Fixed several search issues.
  • Fixed several map-drawing issues.
  • Fixed several display formatting issues.
  • Improved software stability.
Old 06-06-2013, 05:31 AM   #92
Kincop
Kincop's Avatar
Oddometer: 12
Anyone had a chance to try this update yet?
With/witout fuelconsumtion and/or carmode?
Kincop
Kincop is offline   Reply With Quote
Old 06-06-2013, 01:34 PM   #93
Jantan
Oddometer: 6
Now I have tested about 600km and here are the results! My 350LM worked nicely without any problems!
and the settings are:
Motocycle MODE
Fuel consumption OFF
Vesion 2.60
Jantan is offline   Reply With Quote
Old 06-06-2013, 04:00 PM   #94
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,309
Motocycle MODE
Vesion 2.60
Is 600km a long enough test?
Old 06-06-2013, 05:16 PM   #95
Meff
half way there...
Meff's Avatar
Oddometer: 57
Motocycle MODE
Vesion 2.60
So the question is, was it the 2.60 update, or turning the fuel consumption off that did the trick ?
Would the 2.60 have done it on it's own ?
Meff is offline   Reply With Quote
Old 06-06-2013, 05:50 PM   #96
Travex OP
Lost is found
Travex's Avatar
Oddometer: 144
Good to hear of your success Jantan.
Spoke with Garmin earlier today and was told that "the latest release probably fixed the freezing problem".
Won't be riding for a few days but will post results when I have some.
"Rider assumes full responsibility"
2012 Super Tenere For Sale in "The Flea Market"
Travex is offline   Reply With Quote
Old 06-07-2013, 10:09 AM   #97
Flying GS
Flying GS's Avatar
Oddometer: 12
After an horrible journey to the Isle of Mann with the Zumo freezing many times, it behaved absolutely fine for days of local rides with only two notable differences:
- one of the motorcycle mount spring loaded gold plated contacts was stuck down and I freed that
- the plastic bit between the contacts broke away (one of the recommended fixes in this thread)
Could the issue be related to handling multiple short power interruptions?
Returning the unit for exchange as previously arranged anyway, but I guess it's not much use as pointed out by others!
Flying GS is offline   Reply With Quote
Old 06-07-2013, 10:35 AM   #98
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,309
Did you see the last few posts about the software update?
Old 06-08-2013, 12:46 AM   #99
Flying GS
Flying GS's Avatar
Oddometer: 12
No, update wasn't applied as I was on the road, but again no freezing over 4 days of continuous use. Can't wait to see the thread die down after this update is applied by posters affected!
Old 06-08-2013, 01:54 AM   #100
Kincop
Kincop's Avatar
Oddometer: 12
Can anyone try out the Fuelconsumtion after this new update?
BMW R1200GSA/Zumo 350LM
Kincop
Old 06-08-2013, 06:10 AM   #101
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,309
Let's just hope this really fixed it. Too many people have had too many problems with this unit.
Old 06-09-2013, 09:18 AM   #102
ducouple
Oddometer: 2
hello,
Tested it yesterday on 700km.
Firmware version 2.6
Mode use : bike only
If you enable fuel consumption the GPS still freeze
If you disable fuel consumption it works flawlessly : zero freeze on 700 km !
Hope this help & and hope Garmin will fix that asap.
ducouple is offline   Reply With Quote
Old 06-09-2013, 04:05 PM   #103
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,309
Originally Posted by ducouple View Post
hello,
Automobile mode or Motorcycle mode?
Old 06-10-2013, 12:54 AM   #104
ducouple
Oddometer: 2
as i said, i have only used motorcycle mode.
The freeze issue appears ONLY if you use the comsuption with bike mode.
DISABLE it and all is ok and wait (for eternity ?) that Garmin fix it
Old 06-10-2013, 03:07 AM   #105
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,309
Ok. Gotcha. Maybe Garmin needs to hear from you on this?
Times are GMT -7.   It's 08:19 AM.
