Old 04-28-2013, 04:18 PM   #1
sevenpointsixtwo OP
Newb Extraordinaire
sevenpointsixtwo's Avatar
Oddometer: 199
Built racks and panniers for the Steamer!
With the exception of a rare second-hand set of Hepco-Becker or Givis, I couldn't find any pannier racks for my Steamer; even then, they were massively expensive. I knew I wanted to run hard cases on this bike, so I was going to need a custom setup.
I sourced some Seahorse 720 waterproof cases on the recommendation of a fellow inmate, and enlisted a few friends to help me with fabrication and assembly.
In progress:
My welder's ADV salute. Get back to work!
We used 1/2" EMT galvanized tubing for the hoops, and higher-strength 3/4" 16 gauge mild steel for the struts. Two struts tie to the OEM aluminum top rack bolts, (which I'm not using, as it's massively heavy) one to the passenger footpeg brackets, and a removable support bar across the back.
And mounted the boxes:
I'm going to have to remember that they are, in fact, 3" wider than my handlebars and not get myself into any tight squeezes!
Here's the mount setup. L brackets at the top and bottom, clamps to the hoop with a knob. The top bracket will have a lock-plate that bends over the bracket to hold the box in position. The "pucks" themselves are a plastic building material, bolted on with t-nuts and fender washers on the inside.
All they need now are some stickers!
-Sevenpointsixtwo
1998 Tiger 900
2000 DRZ400E
sevenpointsixtwo is offline   Reply With Quote
Old 04-28-2013, 04:27 PM   #2
Gallowbraid
Gallowbraid's Avatar
Oddometer: 832
Very nice setup. I used a packrat rack and mounted a pair of 720's to my KLR almost a year ago now and they've held up fantastically. Plenty of storage space, durable as heck and most importantly: plenty of surface area for stickers!
You might be a KLR owner if:
You think mud is a good paint protector
Winterizing just means putting a tarp over it till tomorrow
You hit Home Depot and Tractor Supply for parts before you go to the motorcycle shop.
Every time you look at anything square shaped you think "Could that be a pannier?"
You like humvees and hate H2's
You've gone into an Army Surplus store to look for riding gear.
Gallowbraid is offline   Reply With Quote
Old 04-28-2013, 04:28 PM   #3
slowgoer
Oddometer: 10
Slick, Great workmanship.
slowgoer is offline   Reply With Quote
Old 04-28-2013, 05:28 PM   #4
sevenpointsixtwo OP
Newb Extraordinaire
Oddometer: 199
Thanks! The first stickers will probably be reflective ones, as the boxes hide the tail reflectors in profile.
-Sevenpointsixtwo
1998 Tiger 900
2000 DRZ400E
Old 04-28-2013, 07:14 PM   #5
markbvt
Location: Georgia, Vermont (that's one town, not two states)
Oddometer: 2,738
I'm still amazed how well these racks turned out. Building them was an interesting project; tubing benders are cool. I was pretty sure as we were making the parts that the resulting racks would be good, but the end result exceeded my expectations. Can't wait to see how they hold up on our next trip!
Good thing I already have racks for my Tiger 800 or I'd be tempted to embark on Rack Project #2...
--mark
'11 Triumph Tiger 800 XC / '03 Honda XR650L / '01 Triumph Bonneville cafe
My ride reports: Missile silos, Labrador, twisties, and more
Bennington Triumph Bash, May 29-31, 2015
markbvt is offline   Reply With Quote
Old 04-28-2013, 08:23 PM   #6
villageidiot
Oddometer: 1,835
ive built racks for my last 3 bikes.
its kind of a sickness. i built a set of racks and alloy panniers on my bmw r80 too which turned out great, but a lot more work.
soft bag standoffs and tail rack for my 2005 vstrom
and racks and seahorse cases for my triumph bonneville
i just got a new vstrom 650 last week and look forward to starting racks soon.
FWIW i usually use 1/2" 16ga tubing for the racks, and simply bolt the racks and bags together. i used happy trails mount kit for the bmw, but found myself never taking them off, so for the triumph i used nuts n bolts.
villageidiot is offline   Reply With Quote
Old 04-28-2013, 09:47 PM   #7
sevenpointsixtwo OP
Newb Extraordinaire
Oddometer: 199
Nice work! I had considered a more permanent bolt-on system, but theoretically I'd like to be able to pack the bags flat, then mount them to the bike, to minimize the drawbacks of a side-loader box.
I think these hoops would work well if I ever want to run soft bags too, like a set of Wolfman dry luggage.
-Sevenpointsixtwo
1998 Tiger 900
2000 DRZ400E
Old 04-28-2013, 09:56 PM   #8
sevenpointsixtwo OP
Newb Extraordinaire
Oddometer: 199
Also, a (rough) calculation of total cost:
Seahorse cases: $105
EMT/tube/flat steel: ~$25
Hardware, paint, etc: ~$20
Beer for my buddy with a MIG: ~$15
Total cost: ~$165 plus or minus.
Plus many hours tinkering. The joys of academia and marginal employment!
-Sevenpointsixtwo
1998 Tiger 900
2000 DRZ400E
Old 04-29-2013, 06:09 AM   #9
villageidiot
Oddometer: 1,835
I use bag liners. Pack the bag liner on the table/bed wherever and it simply goes right in the case. I only have one bag liner, for clothes/toiletries etc. the other case gets food and cooking equipment. I pack my tent and sleeping gear in a kayaking dry bag I rok strap to my back seat or rack.
Old 04-30-2013, 06:41 AM   #10
sevenpointsixtwo OP
Newb Extraordinaire
Oddometer: 199
Ah, that is a great idea. I will have to look for some liners that fit those boxes. Any recommendations?
-Sevenpointsixtwo
1998 Tiger 900
2000 DRZ400E
Old 04-30-2013, 07:20 AM   #11
villageidiot
Oddometer: 1,835
yessir!!
in the vendors section here in the fleamarket.
http://advrider.com/forums/showthread.php?t=487221
this dude is awesome. made me a liner, a tool roll, a bag for my jetboil.
all very reasonable. made in usa
Old 04-30-2013, 02:52 PM   #12
sevenpointsixtwo OP
Newb Extraordinaire
Oddometer: 199
yessir!!
Thanks! I will definitely be looking into 1 or 2 of the box liners. Going to (hopefully, if they fit) add a couple tool tubes inboard of the racks, so a tool roll or bag might be nice for those too!
-Sevenpointsixtwo
1998 Tiger 900
2000 DRZ400E
Old 05-01-2013, 03:53 PM   #13
sevenpointsixtwo OP
Newb Extraordinaire
Oddometer: 199
Added some tool tubes (sorry to whoever was selling them on here; it looked like the group buy was over so I got the ebay ones...). They're just ziptied on for now, but it seems pretty secure. I've heard p-clamps break and I've had bolts rattle loose, so zips might be the permanent solution!
-Sevenpointsixtwo
1998 Tiger 900
2000 DRZ400E
Times are GMT -7.   It's 06:11 AM.
