Old 04-28-2013, 07:57 PM   #1
DCmac OP
Oddometer: 22
Trouble loading routes to 276c
Trying to upload routes to my 276c I get a "Route Truncated" error message on the unit. I've recently updated the maps on the PC to City Navigator North America NT 2013.4. I was using City Navigator NA NT 2011 with no errors.
DCmac is offline   Reply With Quote
Old 04-29-2013, 04:13 AM   #2
9Dave
Bazinga!
9Dave's Avatar
Oddometer: 12,935
Do you have the same maps loaded on teh 276c? Normally you don't get that error until you try to navigate the route, but that will be a problem if you have not.
If you are exceeding the number of waypoints permitted in a route, you will have a problem.
dunno.....
Old 04-29-2013, 09:33 AM   #3
NorthernTraveler
Long time Adventurer
NorthernTraveler's Avatar
Oddometer: 435
Route point limits
If you are using 'Autorouting' routes, you are limited to 50 points.
If you are using 'Direct' routes on a 276C you are limited to 300 points.
Most of the other Garmin units are limited to 250 points on a 'Direct' route.
To change this setting in Mapsource (sorry, don't know Basecamp) go to Edit, Preferences, Routing and select your routing preference.
After you have changed the routing preference, go to the route in question and recalculate it by selecting it (left click), look at the options (right click), and select 'Recalculate Route'
NorthernTraveler is offline   Reply With Quote
Old 04-29-2013, 07:02 PM   #4
DCmac OP
Oddometer: 22
Thanks to both of you. Yes, I have the same maps on the GPS. I can send a direct route to the unit. I'm still working on autorouting.
Times are GMT -7.   It's 04:03 PM.
