Old 04-29-2013, 02:35 PM   #1
hendikaf OP
hendikaf's Avatar
Oddometer: 520
DL650 clearance ,dream checked
Hi guys ,
I am curious to see if many of you checked the real ground clearance on your bike , after 40000 miles and a trip to Hushuaia and back I changed my shock for the oem one ( I drove with one from sasquach and it did the trip OK but not in great shape) Today I checked my bike and was surprise to see only 5 Inches ground clearance without anyone on it .This my only negative comments about the bike .
Hendi Kaf
www.HendiKaf.com
hendikaf is offline   Reply With Quote
Old 04-29-2013, 09:13 PM   #2
XCRider803
Loftin' the wheel
XCRider803's Avatar
Oddometer: 878
Originally Posted by hendikaf View Post
Hi guys ,
Stock clearance is about 6.5 so after 40k you're not much off.
2013 Triumph Tiger 800 XC
2013 Husky TE 449
XCRider803 is offline   Reply With Quote
Old 04-30-2013, 08:27 AM   #3
Kawidad
Kawidad's Avatar
Oddometer: 4,803
So how many miles are on the stock shock and spring? You said the bike had 40k, and you changed the shock for an OEM unit, but didn't say how many miles are on it. The OEM shock on the wee is totally bargain bin stuff, so if the bike is sitting 1 1/2" too low, it may be sacked out and done.
Quis custodiet ipsos custodes? - Juvenal
(Who watches the watchers)
Kawidad is offline   Reply With Quote
Old 04-30-2013, 11:25 AM   #4
hendikaf OP
hendikaf's Avatar
Oddometer: 520
clearance
the stock shock has no more than 5000 miles , the fork have progressive springs and longer spacer inside . the set was pretty good for 25000 2 up loaded with gears and doing some seriously bad road in SA. I may buy sp,e shorter dog bome or longer shock and do the DR650 fork mod to get a better clearance for the next trip , love the motor , 650 is plenty for me
Hendi Kaf
www.HendiKaf.com
Old 04-30-2013, 11:44 AM   #5
ezrdr55
ezrdr55's Avatar
Oddometer: 334
On my DL650, I put 30mm long spacers under the damping rods in the fork and 1" raising links with a DL1K shock out back. I still need a stiffer spring to get the rear sag right, but just 30mm increase in ground clearance made a big difference.
Disclaimer: The opinions expressed herein are mine, and do not represent that of any other humanoid past, present or future on this or any other planet.
'95 H-D FXDWG '06 Honda CRF250X '04 KTM 450EXC '97 Honda XR-600R (Sold) '04K1200LT(SOLD) '07 K1200GT (SOLD) '09 Wee-Strom DL-650ABS '14WR250R
ezrdr55 is offline   Reply With Quote
Old 04-30-2013, 01:03 PM   #6
pjm204
Oddometer: 1,993
I'll have to measure mine. I'm nearing 40k, I just installed raising links in the back and progressive springs up front. I'd guess my rear shock is getting tired. I attempted to ride down some stairs before the raising links and the skid plate bottomed out on the top stair (already committed at that point).
Current bikes:2006 DL650
Past bikes: 2008 WR250R, XT225, TTR125, '04 CRF50 '74 DT125,'70 TS250,'85 v45, '89 zx600c, '78 GS400x, '99 GS500E, '01 GS500E '05 Z750s, '77 GS400e, '82 GS1100ez, '97 GSX600, '07 VFR800, '03 KLR650, '03 FJR1300, '06 DL1000, '00 KLR650, '99 WR360, '08 DL650, '05 DR650, '08 EX650r, '96 CR500, '82 GS450T, '06 Ural
pjm204 is offline   Reply With Quote
Old 04-30-2013, 01:15 PM   #7
hendikaf OP
hendikaf's Avatar
Oddometer: 520
clearance
its good and I did see online some raising dog bone for cheap , raising up to 1 1/2 inch , what can be the draw back
Hendi Kaf
www.HendiKaf.com
Times are GMT -7.   It's 02:46 PM.
