Old 04-29-2013, 09:55 PM   #1
nerdtastic_89 OP
awkward hippy
nerdtastic_89's Avatar
Oddometer: 15
Removing bad kreem job/ fuel repair shop NE GA
Being the noob that I am, I have no real idea where to start finding a trusted fuel repair shop that works on motorcycles willing to tackle the mess that is my tank. Besides the obvious rust in there, a botched kreem job was done and I wanted to try and see if it can be saved so I don't have to buy a new tank. Wanted yalls opinion before I tried to yellow page it. I live in Athens Ga, 30606 willing to travel up to an hour or so out of my area.
Any help is greatly appreciated! Thanks!
Having awkward profanity laced conversations with myself since 1989!
nerdtastic_89 is offline   Reply With Quote
Old 04-29-2013, 10:09 PM   #2
troidus
Oddometer: 15,702
I'm pretty sure acetone will remove Kreem. Once that's all out, get a POR-15 kit and re-coat it. Don't get any of the chemicals on the outside of the tank.
troidus is offline   Reply With Quote
Old 04-29-2013, 10:12 PM   #3
nerdtastic_89 OP
awkward hippy
Oddometer: 15
Gotta find somebody to do that for me. Because I have NOOOO idea what I'm doing.
Old 04-29-2013, 10:28 PM   #4
JGBrown
JGBrown's Avatar
Oddometer: 248
It's like putting gas in the tank, only you use acetone instead.
If you've gone for a ride and filled the tank, you've got half of the job covered already.
Maybe find someone local to help you, so you learn how to do it? Somebody showed me the first time, and it was pretty easy to follow.
Though we used some other steps to dissolve the rust after. And shook the tank a lot.
Canada to Panama on a 79 CX500: http://www.advrider.com/forums/showthread.php?t=62962
Logbook for
motorcycle travelers I'm developing, draft now available for review.
http://www.advrider.com/forums/showthread.php?t=739193
JGBrown is offline   Reply With Quote
Old 04-30-2013, 09:05 AM   #5
achtung3
achtung3's Avatar
Oddometer: 988
Go and buy a kreem kit from the motorcycle shop or elsewhere that you can find it and read the instructions it is pretty straight forward, there is solution in the kit that you use to paint the outside of the tank to avoid messing up your paint, and you can call kreem and ask them the removal part of it.
I have a mechanic who just called me about my tank being rust removed, and I will pick it up in the next hour, he is using electrolysis to remove the rust, this has been just over 3 weeks.
Picked up my tank and it is awesome, the tank looks almost good as new, all the rust is pretty much gone.
The prior onwer of this bike had poured muriatic acid inside and then done nothing and it was sitting in a car port rusting away for almost 30yrs when I got it.
achtung3 screwed with this post 05-03-2013 at 07:29 PM
achtung3 is offline   Reply With Quote
Old 04-30-2013, 12:55 PM   #6
Gallowbraid
Gallowbraid's Avatar
Oddometer: 832
If you find a shop that works on radiators they can usually dip the tank and get it all cleaned up for you, often times preserving the paint on the exterior was well (don't ask me how.)
If you're willing to travel a bit there's a radiator shop on Airport Road between Baldwin and Cornelia (about 35 minutes north of Athens) that cleaned up a tank for a buddy of mine one time:
Williams Radiator
1047 Airport Rd Cornelia, GA 30531
(706) 778-6141
You might be a KLR owner if:
You think mud is a good paint protector
Winterizing just means putting a tarp over it till tomorrow
You hit Home Depot and Tractor Supply for parts before you go to the motorcycle shop.
Every time you look at anything square shaped you think "Could that be a pannier?"
You like humvees and hate H2's
You've gone into an Army Surplus store to look for riding gear.
Gallowbraid is offline   Reply With Quote
Old 04-30-2013, 01:09 PM   #7
ttpete
Oddometer: 6,039
Kreem is obsolete. It's not resistant to today's gas. About the only two liners that will work today are POR-15 or Caswell.
Old 04-30-2013, 02:09 PM   #8
achtung3
achtung3's Avatar
Oddometer: 988
I still have a new kit in my garage!!!!!!
Old 04-30-2013, 04:35 PM   #9
bwringer
Gimpy, Yet Alacritous
bwringer's Avatar
Oddometer: 2,228
Agreed. Kreem is krap.
I've seen people get excellent results with the POR15 and Caswell kits. I think I might have heard once of a Kreem job that didn't quickly fail, but I was mistaken.
POR15 even sells a version of their motorcycle tank kit that includes a solvent that will remove a failed Kreem liner. If you can read and follow simple instructions to the letter, you can do it.
1983 Suzuki GS850G, Cosmic Blue
2002 Suzuki Vstrom DL1000, Midnight Blue
2005 Kawasaki KLR685 - Turd II.2, The ReReTurdening
"Do not crinkle your food wrappers loudly. Be considerate to others, or I will bite your torso and give you a disease."
bwringer is offline   Reply With Quote
Old 04-30-2013, 05:27 PM   #10
ttpete
Oddometer: 6,039
From what I've been hearing, POR-15 isn't recommended for plastic tanks, but Caswell is.
Old 05-01-2013, 10:37 AM   #11
nerdtastic_89 OP
awkward hippy
Oddometer: 15
Williams Radiator
(706) 778-6141
You sir, are absolutely awesome! I've traveled further to stare at lakes and eat ice cream. So this is a piece of cake.
Old 05-01-2013, 10:48 AM   #12
nerdtastic_89 OP
awkward hippy
Oddometer: 15
Pissed
At this point, I really just want to punch Kreem in the face. And whomever did this half-assed job of it. I'm over Kreem and rust. Out of my tank they must go!
Old 05-01-2013, 12:42 PM   #13
LarryDawg
trials nut
LarryDawg's Avatar
Location: Nickerson/Hutchinson Kansas=Cesspool of the World
Oddometer: 74
Mek
Methyl Ethyl Ketone is what is used to disolve Kreem, I have it in the tank of my old honda Trialer...
Larry
"you dont quit riding Cuz' ya got Old!!! Ya get Old Cuz' ya quit riding!!!
1976 Honda TL 250 (Dozer!)
LarryDawg is offline   Reply With Quote
Old 05-01-2013, 01:03 PM   #14
ttpete
Oddometer: 6,039
If I have a tank I'm going to repaint, it goes to a commercial paint stripping company. It comes back bright steel, no paint, no rust. They also do a great job on home heat registers with many coats of old paint.
Old 05-01-2013, 07:25 PM   #15
bwringer
bwringer's Avatar
Oddometer: 2,228
Who said anything about a plastic tank?
Anything that would dissolve Kreem (we seem to have votes for both acetone and MEK here; dunno which is better or correct) would also run the risk of damaging a plastic tank, so you'd need to consult a polymer chemist...
But yeah, I know the POR15 stuff is rock-hard when it sets up, so it would be a pretty bad idea with a plastic tank for that reason alone. I haven't seen a sample of the cured Caswell stuff.
Times are GMT -7.   It's 02:14 AM.
