Old 05-02-2013, 05:42 AM   #31
foxtrapper
Oddometer: 906
But, for a bike in factory tune, run what the manufacturer recommends. Period.
And run only the manufacturers recommended tire size, at the manufacturers recommended pressure. Period.
Oil too. Manufacturers recommendations only. Period.
Do not ever evaluate for yourself alternatives to the manufacturers recommendations.
foxtrapper is offline   Reply With Quote
Old 05-02-2013, 02:09 PM   #32
BikeMan OP
smoke, drink, screw, ride
BikeMan's Avatar
Oddometer: 304
Originally Posted by DesmoDog View Post
Dual plugs cause the mixture to burn faster..
the fuel charge once lit will only burn so fast. it doesnt matter how many spark plugs u used to lit it. of course dual plugs help guard against misfire but that is beside the point. dual plugs help disipate internal cylinder heat which in turn reduces internal cylinder pressure .
fuelly: http://www.fuelly.com/driver/jbw/dl1000[/FONT]
BikeMan is offline   Reply With Quote
Old 05-02-2013, 03:36 PM   #33
joexr
Oddometer: 3,773
If you look at the timing specs , a dual plug head uses less ignition advance.
Old 05-02-2013, 04:54 PM   #34
BikeMan OP
BikeMan's Avatar
Oddometer: 304
maybe but i doubt it. ya just be losing HP. not sayn u wrong. dont matter to me . i'm running stock timing 4*BTDC. and its fixed. i cant change with out buying mod..
BikeMan screwed with this post 05-03-2013 at 06:06 AM
Old 05-02-2013, 05:21 PM   #35
joexr
Oddometer: 3,773
maybe but i doubt it. ya just be losing HP. not sayn u wrong. dont matter to me . i'm running stock timing 4*BDC. and its fixed. i cant change with out buying mod..
You have two ignition points in the combustion chamber leading to quicker burn , so less advance is needed. I didn't make this up , it's fact.
Old 05-02-2013, 05:42 PM   #36
RxZ
Legal Drug Dealer
RxZ's Avatar
Oddometer: 1,899
RxZ is online now   Reply With Quote
Old 05-02-2013, 06:08 PM   #37
foxtrapper
Oddometer: 906
One spark plug, right in the center of a 10" cylinder head. The flame front moves at 1" a second. This scenario would take 5 seconds to cover the cylinder, radiating out from the center spark plug.
Two spark plugs, equidistant in that same 10" cylinder head. The flame fronts again moves at 1" a second. This scenario would take just over 3 seconds to cover the cylinder, with two flame fronts radiating out from the two separated spark plugs.
Follow?
Old 05-02-2013, 09:31 PM   #38
DesmoDog
Desmo's my dog
DesmoDog's Avatar
Oddometer: 736
Originally Posted by hexnut View Post
You are kidding right. At just 5000 RPM, thats revolutions per minute and only 60 seconds in a minute, how many seconds do you think each power stroke last.
I'm guessing he was trying to explain a concept using simple terms, not describe the event using accurate numbers. Concept being two plugs make the mixture burn faster.
DesmoDog is online now   Reply With Quote
Old 05-02-2013, 10:24 PM   #39
Tripped1
Likely Lost.
Tripped1's Avatar
Oddometer: 8,108
I doubt highly that he was suggesting that the flamefront moves at an inch pre second.
Originally Posted by RottenScummyTroll View Post
Show folks something with a clutch and carburetor, and it's like teaching a baboon to use a Macbook.
Tripped1 is offline   Reply With Quote
Old 05-02-2013, 11:39 PM   #40
opmike
Choosing to be here.
opmike's Avatar
Oddometer: 344
[citation needed]
Dual spark plugs are for redundancy (primarily in aviation) and burn efficiency (flame fronts, fuel burn, etc.). You're the first person I've ever heard try to argue against this.
"you want to fix the Pledge of Allegiance, put a disclaimer at the end: with liberty and justice for all...must be 18, void where prohibited, some restrictions may apply, not available in all states."
opmike is offline   Reply With Quote
Old 05-02-2013, 11:55 PM   #41
Tripped1
Likely Lost.
Tripped1's Avatar
Oddometer: 8,108
Originally Posted by opmike View Post
[citation needed]
http://rennsportsystems.com/letstalk...twin-ignition/
Porsche has used twin-ignition in their air-cooled racing engines since the 4-cam Carrera engines. The high-domed pistons necessary for high compression ratios requires another spark plug to start another flame front on the other side of the piston dome. The best place for the spark plug is the middle of the combustion chamber. From the center, the flame front will have the least distance to travel for complete ignition. This reduces the need for as much ignition advance to start and finish the combustion process ...
Either way he is right. I remember flashing chips for camaros and such in high school, you started 15* before TDC with the ignition and bumped it up by degree, the couple dual plug bikes I've plutzed with (a Ducati and a Harley) were both running like 3* degrees before TDC on timing at full tilt.
Old 05-03-2013, 01:26 AM   #42
opmike
opmike's Avatar
Oddometer: 344
Good stuff on that Rennsport page. Thanks for the link.
Old 05-03-2013, 03:26 AM   #43
foxtrapper
Oddometer: 906
I'm guessing he was trying to explain a concept using simple terms...
I would have thought it was glaringly obvious.
foxtrapper screwed with this post 05-03-2013 at 05:00 AM
Old 05-03-2013, 07:27 AM   #44
BikeMan OP
BikeMan's Avatar
Oddometer: 304
its a more complete burn is the truth of the matter. hence the reduced timing required. but its not a quicker burn. even with dual plugs and domed pistons the burn is still not as complete or quicker as u call it, as a single plug located in the middle of the cylinder using flat top pistons. per rennsport link. IMHO, the big advantage of dual plugs is internal cylinder heat dissipation.
BikeMan screwed with this post 05-03-2013 at 07:33 AM
Old 05-03-2013, 02:57 PM   #45
joexr
Oddometer: 3,773
I'm not interchanging more complete and quicker dumbass. It was in Rennsports writing. If the plug isn't in the middle two IS a QUICKER burn than one.Hence , less ignition advance is needed to accomplish almost the same thing.So what's your next thread going to be , what oil do you use?
Times are GMT -7.   It's 06:02 AM.
