Old 05-03-2013, 04:15 PM   #46
LuciferMutt
Rides slow bike slow
LuciferMutt's Avatar
Oddometer: 11,333
87 in both. The 250 has an engine that was designed in the early 80s...it's fine on the cheap swill. The VFR is pushing 18 years old herself...no reason to use the higher octane stuff in that either.
You couldn't hear a dump truck driving through a nitro glycerin plant!
Badasses might screw with another badass. Nobody screws with a nut job. -- Plaka
LuciferMutt is offline   Reply With Quote
Old 05-04-2013, 05:23 AM   #47
anotherguy
anotherguy's Avatar
Oddometer: 6,631
And to stir it up a bit high octane no longer has to mean a slow burn. Fuels are tailored to the application now including the need for a fast burn with high RPM large bore engines. And throw some heat management into the mix.
VP used (R.I.P. )to make a fuel called MR8 for high RPM 2 stroke GP bikes. It was 106 motor octane and evaporated fast and burned even faster. Better living through chemistry. You could throw tons of advance at it w/o any detonation. When you tune for X amount of deto events per mile as acceptable a good fuel is paramount to success.
And then there's squish action and MSV.
you don't see luggage racks on a hearse..........act accordingly
Old 05-04-2013, 07:03 AM   #48
bikefreak47
Oddometer: 81
Something not mentioned is elevation where vehicles are operated. I've always been led to believe that octane demand can be reduced by one point for every 2,000 feet of elevation. In my case, living at 7,200 feet I can safely knock off over three points of octane in my vehicles. Most run fine on 86 and in the higher compression vehicles I run 88 octane instead of 91.
bikefreak47 is offline   Reply With Quote
Old 05-04-2013, 09:16 AM   #49
Dust_
Adventure Dreamer
Dust_'s Avatar
Oddometer: 176
95, which is the lowest here in my country. We do have 98, but I don't even bother
Current bike:
Kawasaki Versys 2010
Dust_ is offline   Reply With Quote
Old 05-04-2013, 09:38 AM   #50
joexr
Oddometer: 3,773
Our octane ratings are different numerically. Your 98 is about the same as our 93.
Old 05-04-2013, 09:42 AM   #51
k-moe
Oddometer: 2,775
I stopped for gas the other day and found this:
Y'all can fill up with some of each, or make your own custom blend.
Anybody need 88.33 octane?
k-moe is offline   Reply With Quote
Old 05-04-2013, 09:48 AM   #52
Dust_
Adventure Dreamer
Dust_'s Avatar
Oddometer: 176
Hum... makes sense, so I guess I fuel up with 91?
Current bike:
Old 05-04-2013, 10:31 AM   #53
joexr
Oddometer: 3,773
The pumps at our 7-elevens are like this , but everywhere else it's 87,89 and 93.
Old 05-04-2013, 10:44 AM   #54
Firemanmike69
Firemanmike69's Avatar
Oddometer: 125
Enough said
Firemanmike69 is offline   Reply With Quote
Old 05-04-2013, 11:38 AM   #55
joexr
Oddometer: 3,773
Originally Posted by Firemanmike69 View Post
Enough said
There's a place here that sells 110 & maybe 100 or something , but it's not a road fuel so you aren't allowed to put it directly into a vehicle , you have to pump it into a container. Gulf used to have a leaded road fuel. It would crap up your sparkplugs though.
Old 05-04-2013, 01:01 PM   #56
vicmitch
vicmitch's Avatar
Oddometer: 279
87 in both bikes
2001 Victory Sport Cruiser
2012 Suzuki V-Strom 650
vicmitch is offline   Reply With Quote
Old 05-04-2013, 02:30 PM   #57
M3-SRT8
Oddometer: 268
Originally Posted by foxtrapper View Post
And run only the manufacturers recommended tire size, at the manufacturers recommended pressure. Period.
Oil too. Manufacturers recommendations only. Period.
Do not ever evaluate for yourself alternatives to the manufacturers recommendations.
I was speaking about the engine in stock tune only. Period. (LOL)
M3-SRT8 is offline   Reply With Quote
Old 05-04-2013, 07:29 PM   #58
DesmoDog
Desmo's my dog
DesmoDog's Avatar
Oddometer: 701
Originally Posted by BikeMan View Post
its a more complete burn is the truth of the matter. hence the reduced timing required. but its not a quicker burn.
More complete burn, in less amount of time.... but it's not quicker?
How do you more of something in less amount of time without doing it quicker?
even with dual plugs and domed pistons the burn is still not as complete or quicker as u call it, as a single plug located in the middle of the cylinder using flat top pistons. per rennsport link. IMHO, the big advantage of dual plugs is internal cylinder heat dissipation.
From Rennsport
"Porsche’s hemispherical air-cooled heads are well known for poor swirl characteristics and the bigger bore engines are quite detonation prone at 9.5:1 and above.
The water-cooled 4-valve heads used in the 996/997, Twin-Turbo/GT-3 and Boxster/Cayman engines have a centrally located spark plug that gives better and more thorough combustion with excellent swirl, without the need for twin-ignition."
From what I can tell they're comparing single plug heads in both cases here. And they've changed more than just plug location. Swirl is a big part of the equation.
Here's what I found in the Rennsport link about cooling:
"The offset-plug position on a 911 delays the combustion process. By installing two spark plugs per cylinder, you will increase the acceleration of the ignition sequence. This can reduce the required advance by 10 degrees or more thus lowering cylinder head temperatures. "
Nothing there about the plug dissipating heat. They attribute the lower cylinder head temps to timing. If heat dissipation was the biggest advantage to another plug, I would think they'd mention it somewhere?
DesmoDog screwed with this post 05-04-2013 at 08:08 PM
DesmoDog is offline   Reply With Quote
Old 05-04-2013, 09:20 PM   #59
k-moe
Oddometer: 2,775
I believe he's referencing the spark advance, not time spent burning.
Old 05-05-2013, 05:21 AM   #60
nbsdave
Oddometer: 306
Originally Posted by leakypetcock View Post
FYI
Ethanol raises octane
it does not in the real world, only in textbook situations (on paper and before moisture absorbtion)
the attraction of moisture by the ethanol actually lowers the octane rating in real world usage (in your tank)
nbsdave screwed with this post 05-05-2013 at 05:27 AM
nbsdave is offline   Reply With Quote
Times are GMT -7.   It's 12:03 AM.
