Old 05-05-2013, 06:08 AM   #61
BikeMan OP
smoke, drink, screw, ride
BikeMan's Avatar
Oddometer: 299
its a new record
yesterday on a ride to WV i got a all time high of 54.3 mpg . and on the way home i got 54.0 mpg. so i know it wasnt a math error. using regular automotive grade fuel (93 octane) with sta-bil marine formula ethanol treatment. see fuelly link for more info..
fuelly: http://www.fuelly.com/driver/jbw/dl1000[/FONT]
BikeMan is offline   Reply With Quote
Old 05-05-2013, 06:19 AM   #62
kamikazekyle
Oddometer: 140
I use the lowest I can get away with. Regular (87) around here is often 20 cents less than mid (89) and 50-80 cents less than premium (93). Sea level and mandated 10% ethanol in all fuel stations in the region by law. The only place that did sell ethanol free was at a small air port which banned vehicles from going near the pumps after people got wind of it.
The Setaro is specced for 87 so I use that. My Ninja calls for 90+ yet is only 11.2:1 compression or some such. I usually run 89 or 87. Damned if I can tell if the engine knocks since the Ninja's engine at idle sounds like a tractor thanks to the autotensioner for the timing chain. Though sometimes on 87 it seems to loose some umph or throttle response -- might just be in my head.
As for the Guzzi V7 Stone, it calls for 91+. It's air cooled and I think 9.5:1 or 10.5:1 compression, which I hear is high for a purely air cooled motor. I ran 89 during the winter and didn't run into any problems; have yet to run it during the warmer months, though.
Oh, and for storage I use either Seafoam or StarTron. I've had both keep gas in the shed for a year and my carbed mower and pressure washer hum along just as good as fresh gas. This includes storing both with fuel in the tanks and lines over the winter. Been doing this for years without refurbing or cleaning the carbs and no issues yet. I stopped using Stabil, though. That stuff made everything run rough and killed gas mileage, even when put and used directly in a vehicle.
kamikazekyle is offline   Reply With Quote
Old 05-05-2013, 08:34 AM   #63
LuciferMutt
Rides slow bike slow
LuciferMutt's Avatar
Oddometer: 11,265
Your experience is similar to mine. I used Stabil for a long time. Results were alwyas so-so...the bikes would start hard and run rough after sitting for a long time, even if I had drained the carbs, but an "Italian Tune Up" would cure it after a while.
Then on a whim I started using Sea Foam as a stabilizer. The first bike sat four months with it, and drained carbs. Started up and ran like the day I put it away. Also, adding sea foam to the fuel of a bike that is running a bit rough otherwise seems to help it out pretty quickly. I'm a believer and have used the stuff since.
You couldn't hear a dump truck driving through a nitro glycerin plant!
Badasses might screw with another badass. Nobody screws with a nut job. -- Plaka
LuciferMutt is offline   Reply With Quote
Old 05-05-2013, 10:20 PM   #64
NONo443
NONo443's Avatar
Oddometer: 157
87 or 89, I don't really feel a difference between the both of them.
NONo443 is offline   Reply With Quote
Old 05-06-2013, 06:08 AM   #65
BikeMan OP
BikeMan's Avatar
Oddometer: 299
check your mpg over 3 tanks of each octane 87 89 93. which every one gives you the best mpg is the best fuel for your bike. that what i did. i found my bike gets a couple more mpg's with the 93 octane vs 87.
Old 05-06-2013, 07:21 AM   #66
davidbeinct
davidbeinct's Avatar
Oddometer: 539
Originally Posted by Tripped1 View Post
http://rennsportsystems.com/letstalk...twin-ignition/
Either way he is right. I remember flashing chips for camaros and such in high school, you started 15* before TDC with the ignition and bumped it up by degree, the couple dual plug bikes I've plutzed with (a Ducati and a Harley) were both running like 3* degrees before TDC on timing at full tilt.
I was reading this, and said to myself "BS, Camaros didn't have chips in high school," then I realized, "shit, I'm old."
That's my only contribution to this discussion.
David B.
davidbeinct is offline   Reply With Quote
Old 05-06-2013, 07:32 AM   #67
Tripped1
Likely Lost.
Tripped1's Avatar
Oddometer: 7,899
Originally Posted by k-moe View Post
I believe he's referencing the spark advance, not time spent burning.
Spark advance directly correlates with the time of the burn. This is one ideally the entire burn would happen at TDC. You can't make an ICE run at TDC you would need an instantaneous ignition.
You burn faster as both pressure increases and mixture decreases (toward lean), this is why bikes have such crazy static CRs and relatively short advances and they go from relatively mild with a long stroke twin to flat out insane look at the Pangiale's engine specs, they are impressively race bred.
Burn to soon and you knock, burn to late and the exhaust valves open with an active flamefront.
Here is a quick and dirty without trying to read someone's Master's thesis. (MEs, gearheads with math skills) http://www.innovatemotorsports.com/resources/myths.php
Originally Posted by RottenScummyTroll View Post
Show folks something with a clutch and carburetor, and it's like teaching a baboon to use a Macbook.
Tripped1 is offline   Reply With Quote
Old 05-06-2013, 07:51 AM   #68
skysailor
Rat Rider
skysailor's Avatar
Oddometer: 3,519
Ethanol is pure political BULL SHIT! It reduces mpg by 10%.
Lyle
skysailor is offline   Reply With Quote
Old 05-06-2013, 08:46 PM   #69
leakypetcock
leakypetcock's Avatar
Oddometer: 579
I stopped for gas the other day and found this:
Y'all can fill up with some of each, or make your own custom blend.
Anybody need 88.33 octane?
Most likely two tanks in the ground, low octane and high octane. Blend a percentage of each to tailor the octane rating of each.
Don't sweat the petty things-pet the sweaty things
leakypetcock is offline   Reply With Quote
Old 05-06-2013, 09:04 PM   #70
Tripped1
Likely Lost.
Tripped1's Avatar
Oddometer: 7,899
David B.
The chips actually went away my Sophomore year FU OBDII
Old 05-07-2013, 01:20 PM   #71
leakypetcock
Oddometer: 579
Originally Posted by fast4d View Post
E10 rated at 91 "motor' octane is still 91 octane. the amount of ethanol does not matter.
Most refineries don't blend 91 octane. They blend a 90 octane super-subgrade. They then blend in up to 10% ethanol to make the 91 octane. Subgrade gasoline is blended at 84 octane to be bumped to 87 with ethanol. "Motor" octane on a 91 "road" octane is actually somewhere around 86. You average that with the "research" octane (95ish) to get a mid 90, then add ethanol to get your 91. If you can find a 91 octane "motor" you're a lucky guy. That's going to be a 94 or better, add in some ethanol and you have something only a high compression race engine can make use of.
Old 05-07-2013, 02:03 PM   #72
leakypetcock
Oddometer: 579
Originally Posted by nbsdave View Post
it does not in the real world, only in textbook situations (on paper and before moisture absorbtion)
the attraction of moisture by the ethanol actually lowers the octane rating in real world usage (in your tank)
This is correct, but probably not why you think so. If if ethanol, (alcohol) absorbs water (it does) then it will drop out into an aquaeous layer in the bottom of the tank; then the original gasoline will be ethanol deficient and lower octane.
Old 05-07-2013, 07:39 PM   #73
leakypetcock
Oddometer: 579
Originally Posted by M3-SRT8 View Post
Running higher octane gas than what the owner's manual is just a waste of money, and causes deposits to form in the engine.
An engine rated for 87 octane will make LESS power on higher octane gas.
100% correct!
Old 05-07-2013, 07:41 PM   #74
leakypetcock
Oddometer: 579
Originally Posted by joexr View Post
Ethanol also makes you run leaner than non-ethanol.
Really?
Old 05-09-2013, 06:09 AM   #75
BikeMan OP
BikeMan's Avatar
Oddometer: 299
to have it and not need it, wont hurt. OTOH, to need it and not have it, may hurt the engine.
Times are GMT -7.   It's 06:28 PM.
