Old 03-11-2013, 09:38 PM   #1
brycekauai OP
Oddometer: 74
GY6 Performance Parts CH150 Honda Elite
Will this fit on a ch150? Anyone got a link to some aftermarket clutches that would do the trick? Also, who has used performance parts or GY6 parts on there ch150. Please share! Thanks!
http://www.scrappydogscooters.com/12...rformance.html
brycekauai is offline   Reply With Quote
Old 03-12-2013, 06:00 AM   #2
MotoRandy123
MotoRandy123's Avatar
Oddometer: 135
I found this info on Motorscooterguide.com
"Aftermarket parts for this engine are pretty much non-existent. These scooters enjoyed strong popularity in the states, but their appeal was more limited international and in the Asian scene where aftermarket parts commonly originate. If you're looking to increase the performance of your Elite, there are some options for you. Aftermarket performance parts aren't available specifically for the Elite but some generic parts can be used and there are some modification you can make with basic skills. The most popular mods including swapping to a larger (26-28mm) flat slide carburator, opening up the exhaust and intake openings and tossing in a modified GY6 variator."
MotoRandy123 is offline   Reply With Quote
Old 03-12-2013, 08:07 AM   #3
Motovista
Parts is Parts
Motovista's Avatar
Oddometer: 507
What trick are you trying to do? What have you already done?
Discount OEM, replacement and performance parts for vespa, honda, bmw, yamaha, suzuki, genuine, kymco, piaggio, aprilia, SYM, tgb, tomos and other scooters at http://www.scooterpartsco.com
GT200, GT200, ET2, Italjet Velocifero, Italjet Torpedo, Eton Beamer 3, Genuine Buddy Pamplona 150, Kymco Vitality 50, Honda Elite 50
Motovista is offline   Reply With Quote
Old 03-12-2013, 12:59 PM   #4
brycekauai OP
Oddometer: 74
Hey guys, not really trying to pull off any tricks, but usually these parts are much cheaper then the OEM. I also saw that they were similar and I heard lots of 150 parts are possibly interchangeable. Thats why I showed the clutch because it looked like an easy swap if it fit. I don't care about the performance as much as the price. Old clutches for the ch150 still sell for over $100 on eBay. I wanted to try and get some people to start sharing if they had done any swaps with these new parts. Or even photos of what they have changed, especially carbs they have put in with results.
Old 03-12-2013, 10:07 PM   #5
fullmetalscooter
Let me take this duck off
fullmetalscooter's Avatar
Oddometer: 3,109
Google for it . Used advanced. Up top were it says more discussion . Also join up the yahoo ch150 group etc. Best way to find stuff. if someone done it , it ll be out there.
Life's journey is not to arrive at the grave safely in a well preserved body,but rather to skid in sideways totally worn out shouting WHAT A RUSH, WHAT A RIDE.
"Life is a tragedy when seen in close-up, but a comedy in long-shot." Charlie Chaplin
fullmetalscooter is offline   Reply With Quote
Old 03-13-2013, 10:09 AM   #6
Motovista
Parts is Parts
Motovista's Avatar
Oddometer: 507
If you take your clutch to someone who sells Chinese scooters, they might be able to compare it side by side with one from a GY6. I've heard of it working on the internet, and I've also replaced engine cases on a Honda Metropolitan because someone read on the internet that it would work and put a QMB139 clutch on a Metropolitan. It destroyed the case, seal and bearing before he realized something was wrong.
If the clutch is similar to the one on the SH150, you should be able to find a non-oem replacement. But the only way to be sure it is would be to have the two parts side by side.
You should be able to purchase a complete used clutch for a GY6 for a lot less than the "performance" shoes you are showing online. Most dealer/repair shops end up with a lot of terminal Chinese scooters and sell off the parts. But AND THIS IS IMPORTANT, take the part you are trying to replace with you and compare them side by side. Use a micrometer if you have to. Close but not quite can get expensive fast when you try to make it work.
Old 03-14-2013, 01:18 PM   #7
scootrboi
scootrboi's Avatar
Oddometer: 1,653
aftermarket parts
Sure, put in Chinese parts, then you can have more of a hobby. Seriously, stay away from GY6 stuff.
42 years on a Heinkel Tourist
scootrboi is offline   Reply With Quote
Old 03-14-2013, 01:47 PM   #8
snowhawk jockey
Slack Jaw Gaper
snowhawk jockey's Avatar
Location: The other Center of the Universe: Bend, Oregon
Oddometer: 1,124
Scooterworks.com will answer those questions!
snowhawk jockey is offline   Reply With Quote
Old 03-14-2013, 08:02 PM   #9
brycekauai OP
Oddometer: 74
Just sent them an email. We shall see. Thanks!
Old 05-02-2013, 06:19 PM   #10
Eliter85
Eliter85's Avatar
Oddometer: 310
Did you have any response?
Progress on eliter! - eliter85.tumblr.com
1985 CH150 Eliter | 2006 Yamaha Morphous
Eliter85 is offline   Reply With Quote
Old 05-04-2013, 03:56 PM   #11
brycekauai OP
Oddometer: 74
I wish. They didn't get back to me. I did use some gy6 blue clutch springs from them. They seem to be working good. I know that if you need some parts for yours look on scrappy dog scooters link below.
http://www.scrappydogscooters.com/CF...8MJ_Parts.html
There are quite a few interchangeable parts that they sell on here. I just ordered a belt and intake manifold today. I hear they crack easily and can throw your whole bike off if you don't fix them early on. And buy a few exhaust gaskets while your at it as well. They are the most failed part of this bike. Every time you take the exhaust off it should be replaced. Or thats what I have read on other posts about them.Best of luck. Aloha.
Old 05-04-2013, 04:00 PM   #12
brycekauai OP
Oddometer: 74
I've read on total ruckus that this air filter should fit right on and have no rejetting. No guarantee but thats what he wrote. Mine should be here this week so maybe look at this as an option if your looking for more aftermarket parts. Its gotta be the 42mm size. He said that this one worked good because of the short and small size.
http://www.ebay.com/itm/181038781759...84.m1497.l2649
Old 05-04-2013, 07:26 PM   #13
fullmetalscooter
Oddometer: 3,109
scrappy dogg good place but far to often busy and doesn't answer phone but does so with email. yahoo elite 150 groups. You ll need a yahoo email account to read it. http://groups.yahoo.com/group/hondaelite150/messages
I m guessing they might answer your questions.
Old 05-06-2013, 09:59 AM   #14
Eliter85
Eliter85's Avatar
Oddometer: 310
Something like this should work fine though no? Looks exactly the same but its 1/4 of the price i'd pay to get one from Honda.
Old 05-06-2013, 12:54 PM   #15
Eliter85
Eliter85's Avatar
Oddometer: 310
I really want to do this. But I'm somewhat deterred in case water gets up there. Are you not worried about splashing water up there somehow? I do live in BC though, and It rains a lot here and I drive my scooter in the rain quite often. So I might just be over thinking this.
Maybe get this and somehow build a cover for it to help keep water out but allow air in easily still?
Times are GMT -7.   It's 02:06 AM.
