Old 05-05-2013, 12:48 PM   #1
Yascher OP
Yascher's Avatar
Oddometer: 388
Valve check issues
I'm doing a valve adjustment now on the bike and having trouble to catch the real gap.
Initially, after bike been ridden and cooled down for a day I checked the gaps and these were almost good, except for a couple bit short.
After pulling the shims out for measurement and putting everything back together and remeasuring the gaps these became much tighter, the more I was trying to cycle the engine to seat the things properly, the tighter it was becoming....however I do not believe that cycling it would effect the gap and push oil out from between valve stem, shim and bucket and so on....anyway the new gaps are still much tighter than before disassembly. I'm experienced enough in this field and have not seen this happening before, all shims and buckets were taken out only as single pairs and there is no way these could be misplaced and so on. Additionally all shim pair were exactly same thickness from factory.
Checked the gaps at different lobe position of the cams, but same results
Any ideas or similar experience with 990?
Yascher is offline   Reply With Quote
Old 05-05-2013, 08:18 PM   #2
v8toilet
Nothing to see here.
v8toilet's Avatar
Oddometer: 1,735
Sillly question as you are saying your experienced but you did remember to install smaller shims to gain more clearance as opposed to installing larger ones? Sometimes for whatever reason folks get their wires crossed here, they want the gap bigger but somehow that translates in to thinking the shims should be bigger.
Also you should check the clearances with the cams at the specified locations.
Link here:
http://paochow.com/forum/index.php?topic=45.0
v8toilet is offline   Reply With Quote
Old 05-06-2013, 12:03 AM   #3
bigkuri
bigkuri's Avatar
Oddometer: 750
They do change a little. Are you cycling the engine anticlockwise? Not going past marks even by a little? Using a decent digital micrometre?
I generally measure once, cycle engine round, measure again. Write it all down. Reshim it, measure. I've found after reshim it changes to max of 0.05 from what it should be as calculated.
Current Bikes: 2006 Honda XR650R & 2007 KTM 950 SMR
bigkuri is offline   Reply With Quote
Old 05-06-2013, 02:01 AM   #4
Yascher OP
Yascher's Avatar
Oddometer: 388
I did not change shims, I used the original ones in original positions and 2nd, 3, 4, 5 ....measures after reassembly were getting tighter after cycling the engine anticlockwise than the first measure before removing the shims for measurement.
Until I can get a sure measurement of the gap, there is no point to get new shims there.
On all my other twin engines gap stays mostly constant after engine cycling, here it's floating and is becoming tighter....which is strange
Old 05-06-2013, 02:02 AM   #5
Yascher OP
Yascher's Avatar
Oddometer: 388
Link here:
I've read all this and it is standard procedure for any twin.
Ive checked clearance in all unloaded positions, it stays rather constant on the cam circumference, as it should be
Old 05-06-2013, 05:20 AM   #6
charlie264
charlie264's Avatar
Oddometer: 8,311
Installed, mixed around the pair of buckets?
Old 05-07-2013, 12:40 AM   #7
bigkuri
bigkuri's Avatar
Oddometer: 750
Ah, sorry I misread. Original shims, and bucket/shim the same to each valve, then you must be:
- turning the engine clockwise, even the smallest amount?
- not measured correctly the first time around. Maybe you were getting the feel of the slip of the gauge, or some oil under the bucket, etc..
Measure twice, rotating a cycle between, write everything down, and put it down to something unknown.
Old 05-07-2013, 01:23 AM   #8
Yascher OP
Yascher's Avatar
Oddometer: 388
Got a set of HD shims, playing with these until I get a proper final gap, still experiencing problem with getting the correct measure, probably it has something to do with difficult entry angle at least to the rear ex valves, which leads to some sticking of the feeler gauges, however the other measurement are not completely accurate, as calculated new shim sometimes gives a real overshoot, which means initial gap measurement was not correct!!! Question why it is not correct and has changed a lot after first measurement before removing the original shims and after reinstalling these back??? I've fully cleaned the mating areas and lubed everything, so no foreign material is getting in between and altering measurements.
Old 05-07-2013, 01:24 AM   #9
Yascher OP
Yascher's Avatar
Oddometer: 388
What difference engine rotation has on the valve clearance???
Same for exact cam position? As far as it in unloaded position, circumference should be of the same diameter, unless you have a bent cam
Old 05-07-2013, 01:25 AM   #10
Yascher OP
Yascher's Avatar
Oddometer: 388
nope
Old 05-07-2013, 04:15 AM   #11
charlie264
charlie264's Avatar
Oddometer: 8,311
nope
Strange. All you can do is re-shim to get the right gap..Button it up and do a few miles and recheck.
What torque setting are you using for the cam bridges, perhaps whoever put them on before you didn't torque them up correctly.
Old 05-07-2013, 01:49 PM   #12
MAXVERT
Rough Rider
MAXVERT's Avatar
Oddometer: 1,040
For checking the rear cylinders clearance I like to put a slight bend,
radius in the feeler gauges I'm using.
They should slide right in from the rear
Max
Da oggi la strada
senza limiti
MAXVERT is offline   Reply With Quote
Old 05-08-2013, 01:20 AM   #13
bigkuri
bigkuri's Avatar
Oddometer: 750
Hi, I think that you know this, as you have great sounding mechanical knowledge! :)
It is all about cam position, and as such the engine rotation is important simply to ensure the cams are in the same position. In the past I have had different gap readings from a tight cam-chain - it was slightly different on separate rotations as the cam chain had tight spots. It's the same reason that ANY clockwise movement when you are lining up the marks is bad - as a clockwise movement is unloading the cam chain, which may or may not move the lobes.
In terms of exact cam lobe position - well I just figure it is not a constant radius. Maybe the flat side is a constant radius, but better safe than sorry.
Old 05-08-2013, 04:27 AM   #14
roookie1
Oddometer: 114
For that to be possible you have to have play in Your camholder thingy , I hope not, that means your top ends are toast..Set the cams on the mark (dot, X) thats the point of measuring, for me at least..
Ktm 950 Adv S Go!! 2004 (Mathilda)
Ktm 530 Exc-r 2008
roookie1 is offline   Reply With Quote
Times are GMT -7.   It's 06:16 AM.
