Old 05-06-2013, 07:10 AM   #1
GoGoGavin41 OP
Isn't this that guy?
GoGoGavin41's Avatar
Oddometer: 827
07 990 Brakes-No Bueno
So, I went and picked an 07 990a up yesterday from an inmate in San Fran. Very happy with the bike, the ride definitely sucked back to San Diego (ridiculous cross winds, dust storms, LA traffic, etc). I believe the bike has been sitting a while and thought maybe these brake issues would clear up after I had ridden a while but they're persisting.
Front brake: Pull is a little squishy the first 2-3 pulls, then gets firm to what I would think is the right pressure. Now don't get me wrong, the thing still stops HARD with the front discs, but the first pull or two (while sitting still) you can get the lever almost all the way to the bar.
Rear Brake: Well, there just isn't much. Putting "emergency" level pressure (as hard as I can push down on it) seems to provide about as much stopping power as the rear drum on my 1980 Tomos Moped. I noticed this when I tried to engage the ABS and the brake won't provide enough friction to break grip.
Both sight glasses show plenty of nice, clear fluid, the bike only has 11k miles, and all the wear parts still have lots of life on them (pads, rotors). I'm thinking the front may just need to be bled, and maybe the rear got glazed over or something and the pads might need sanded and re-broken in. I've read stuff about people not putting the brakes back together correctly before, but this doesn't seem to be the case to me.
Thoughts?
GoGoGavin41 is offline   Reply With Quote
Old 05-06-2013, 07:22 AM   #2
FakeName
Wile E Coyote SuperGenius
FakeName's Avatar
Oddometer: 1,811
I'd start by bleeding them both. The front almost 100%- anytime they'll pump up, it's air in the system.
I find the rear brake on my bike a little annoying in its travel when compared to my RFS bike. It still locks up nicely with the ABS off.
Are the results the same with the ABS off on yours?
2011 White 990 Adv S
2014 500EXC Black
FakeName is online now   Reply With Quote
Old 05-06-2013, 06:23 PM   #3
Nailhead
Free at last!
Nailhead's Avatar
Oddometer: 6,201
Mine did that for an entire summer.
I bled the front system, with no improvement. I posted a thread about it, and someone suggested pushing on the shifter-side caliper with a knee to slide it back, or something like that. You might search for it, because the procedure did work-- albeit, temporarily.
Next summer, the problem was gone, and it has not reappeared since.
-Chris
'7? Benelli 650S, '80 BMW R100 RS, '93 Ducati 900 SS, '07 KTM 990 Adventure
Nailhead is offline   Reply With Quote
Old 05-06-2013, 06:29 PM   #4
FakeName
FakeName's Avatar
Oddometer: 1,811
another suggestion- use a tie-down to firmly apply the brake while parked in the garage. Turn the bars to the left so the MC is high.
Wait overnight.
Come back the next morning and evaluate. I've done this on my RFS bike with great success- the bubbles travel up the lines.
2014 500EXC Black
Old 05-06-2013, 07:39 PM   #5
Mr_Snips
Husky BRAAAAAAAAP!
Mr_Snips's Avatar
Oddometer: 352
I've found even with good fluid and pads the brakes are a little underpowered for aggresive street riding. they will fade. however when they are freshly bled and your on knobby tires you only need 1 finger to lock that front tire up.
Originally Posted by Reprobate
Familiar. My stock response: "Most people die in bed. So, where do you sleep?"
Mr_Snips is offline   Reply With Quote
Old 05-06-2013, 08:25 PM   #6
David37
David37's Avatar
Oddometer: 400
I have an 07 KTM 950 SE and was never really impressed with the rear brake. I bleed the brake, sanded the brake pads to rough up the surface, cleaned the caliper and used fine steel wool to rempve any glaze on the rotor. Stopping power was good but not great.
I just purchase a vacuum brake pump from Cycle Gear (on sale for $39.99) and was able to remove all the air from the brake line and caliper. Rear and front brakes work great.
David37 is offline   Reply With Quote
Old 05-06-2013, 08:53 PM   #7
DSM8
Where fun goes to die....
DSM8's Avatar
Oddometer: 3,855
Fully flush the system, if it has been sitting or such then the fluid might also be a little old, it does absorb moisture over time.
Fully drain the fluid, then reverse bleed them forcing the fluid from the calipers up to the master cyln.
I have done this on both ABS and non ABS bikes with great success, since the fluid is moving up the lines it is allowing the air in the fluid and lines to move in the direction it wants to travel. Up.
The tying the level back to the bars overnight is also another really good suggestion.
Hope this helps.
DSM8 - A different kind of mean
SQL > SELECT finger FROM hand WHERE id=3
http://share.findmespot.com/shared/f...d5LbKWMz6cHxaH
DSM8 is offline   Reply With Quote
Times are GMT -7.   It's 07:18 AM.
