Old 05-06-2013, 04:30 PM   #1
Fe Man OP
I am Iron Moran!
Fe Man's Avatar
Oddometer: 8,442
06 Tiger: Neutral Indicator Issues, not starting
2006 Triumph Tiger
Some of you guys know I had my engine out to replace a valve. Well I have it all back together and it won't start!
It's in neutral but not getting a neutral light on the cluster and the starter is not engaging. The solenoid is clicking when the start button is pressed. The neutral switch appears be functional based on my multimeter measurements. I have checked the wire as far as the main connector and all is good.
Battery: good
Fuses: good
Any ideas?
Physics, gravity, and law enforcement are the only things that prevent me from operating at my full potential
Fe Man is offline   Reply With Quote
Old 05-06-2013, 05:45 PM   #2
Fe Man OP
I am Iron Moran!
Fe Man's Avatar
Oddometer: 8,442
boy am I ever lucky to have my friend Ducky come over and help me with this mess. It is running!!!!
Old 05-07-2013, 07:45 AM   #3
mustang
Lurker Extraordinaire
mustang's Avatar
Oddometer: 644
what was it?
mustang is offline   Reply With Quote
Old 05-07-2013, 01:21 PM   #4
brad1098
/\ dumb
Oddometer: 845
Starter issue?
brad1098 is offline   Reply With Quote
Old 05-07-2013, 01:34 PM   #5
Fe Man OP
I am Iron Moran!
Fe Man's Avatar
Oddometer: 8,442
Bad chassis ground!
Gauge cluster and cockpit were grounded through the harness but everything that was looking to be grounded through the engine and frame were seeing nothing. That is why instrumentation, lights, horn, clutch safety worked but neutral safety, kickstand and starter were inop!
Old 05-07-2013, 04:22 PM   #6
mustang
mustang's Avatar
Oddometer: 644
it's always something simple 99% of the time
Times are GMT -7.   It's 03:47 AM.
