Old 05-07-2013, 12:07 PM   #1
ultrachrome OP
Poser
Oddometer: 274
oil pressure light - dealer finds no fault - next steps?
2011 KTM 990 SMT, 11k miles.
Riding home from work last week, my oil pressure light came on. I pulled over and called my dealer for advice. They said ride it home (~5 miles).
After continuing, I noticed it would go on and off, staying off for as long as a mile, and at one point, it flickered in time with bumpy pavement.
The coolant overflow tank level is unchanged and my oil change from a few months ago suggested no water pump issues. I looked at the sensor connector and was able to reach in and seat the connector about another 1/8".
Rode the bike 3/4 mile to the gas station with no light (yay!) but on the way back it started flickering again (boo!).
For obvious reasons, I've been afraid to ride it and so other than bumps, I've not figured out whether it's influenced by throttle opening or RPM.
I dropped it off at the dealer on Friday and today they called to inform that after riding it, they were unable to get the light to come on.
My warranty ends in a little over a month so if this is a serious issue I want to get it diagnosed ASAP. Any ideas?
ultrachrome is offline   Reply With Quote
Old 05-07-2013, 12:21 PM   #2
Mr_Snips
Husky BRAAAAAAAAP!
Mr_Snips's Avatar
Oddometer: 352
Oil level? And check valve
Originally Posted by Reprobate
Familiar. My stock response: "Most people die in bed. So, where do you sleep?"
Mr_Snips is offline   Reply With Quote
Old 05-07-2013, 12:23 PM   #3
ultrachrome OP
Poser
Oddometer: 274
Oil level is fine. More info on check valve?
Old 05-07-2013, 12:27 PM   #4
_cy_
Oddometer: 6,334
assuming you've already done basics like another new oil filter, clean screens if any, made sure oil pressure switch is not smashed, etc. etc.
unscrew your pressure switch, hook up a quality oil pressure gauge. verify actual oil pressures ...
_cy_ is online now   Reply With Quote
Old 05-07-2013, 01:06 PM   #5
ultrachrome OP
Poser
Oddometer: 274
We have a one-month-old child so my first priority was to get it to the dealer. Sourcing a "quality oil pressure gauge" is likely to chew up a lot of time that I don't have having never shopped for or fitted one before.
I certainly like the idea of an actual oil pressure gauge for the long term but I don't have the room to mount the typical 2" gauges I've seen so far.
I'm mainly looking for tactics to enable the dealer to find and correct the fault before my warranty expires.
Old 05-07-2013, 02:30 PM   #6
_cy_
Oddometer: 6,334
you asked what to do next ... installing a pressure gauge tells if there is actual oil pressure problems and/or a faulty switch. it's not meant to be permanent
Old 05-07-2013, 02:40 PM   #7
ultrachrome OP
Poser
Oddometer: 274
I understand, appreciate and agree with your original comment and I'm actively looking at gauges. However, I was trying to avoid tearing down the bike to that degree given my time constraints.
Old 05-07-2013, 03:04 PM   #8
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,003
The easiest way to diagnose a leaking water pump is checking your clutch cover.
If there is milky residue, this indicates wp failure. Next step is laying your bike on the side and removing oil filter. Wavy filter lines indicate wp failure with certainty. Also cluttering of the valves is a strong indication of obstructed oil circulation.
Cheers.
Old 05-07-2013, 03:26 PM   #9
ultrachrome OP
Poser
Oddometer: 274
Cheers.
I've not removed the clutch cover. Will I have to replace a gasket if I pull it?
Old 05-07-2013, 03:56 PM   #10
el queso
toda su base
el queso's Avatar
Oddometer: 710
Sounds like you're already going this route, but get it to the dealer before the warranty expires and they should be able to fix it. If not I would assume KTM would consider it a continuing issue which would be covered by the warranty.
With a newborn at home, you have better things to do...
el queso is offline   Reply With Quote
Old 05-07-2013, 06:27 PM   #11
Zuber
Zoob
Zuber's Avatar
Oddometer: 2,071
Could be a bad sender. A new one is very cheap, like under $15. Just swap it out.
A real pressure gage is a better idea though.
"Son, you can't do both"
Old 05-07-2013, 06:55 PM   #12
Apple Jam
Forest Flyer
Apple Jam's Avatar
Oddometer: 6,556
No. It's a reasonably robust rubber gasket.
Mine's been off thrice in 50k miles,...still looks new
"got no problem with keeping truly roadless areas as wild....
On the other hand, if it has been logged or mined and roads already exist,,
...then that land should be open for public use" (peterman)
Apple Jam is offline   Reply With Quote
Old 05-07-2013, 07:48 PM   #13
SRG
SRG
SRG's Avatar
Oddometer: 1,288
You should not have to diagnose the problem. The bike is under warranty. You have done what you should have by letting the dealer know there is a problem (within the warranty period). The dealer needs to figure it out.
Can you imagine your grandmother buying a new Ford, having the check engine light come on and the it being somehow her job to figure out what's the fault?
You have notified the dealer there is a problem within the warranty period - you are covered. If you don't trust them to take care of you that's a different problem.
Lazy Traveler
SRG is online now   Reply With Quote
Old 05-07-2013, 08:01 PM   #14
acejones
acejones's Avatar
Oddometer: 5,274
Keep your paperwork from that dealer visit. Hopefully they notated that they felt there is no problem. If not get them to do so.
I got tired of being here, so now I'm there
acejones is offline   Reply With Quote
Old 05-07-2013, 09:49 PM   #15
MOLAHS
Sisyphus
MOLAHS's Avatar
Oddometer: 1,646
Have you checked the oil filter ? My 990SD had the same symptoms and the cause was a non-oem oil filter. It had similar distortion as that caused by coolant in the oil. The KTM mechanic said he'd seen this occur a few times with non-oem oil filters. We put in an oem filter and problem went and didn't reoccur.
The Myth of Sisyphus
MOLAHS is offline   Reply With Quote
Times are GMT -7.   It's 12:38 PM.
