Old 05-07-2013, 03:17 PM   #1
Heloflights OP
Heloflights's Avatar
Oddometer: 178
Bluhduh Any electricians in the house?
This is a real puzzler...
...yesterday we lost a "circuit" in the house. I say "circuit" since the affected items are all over the place:
2nd floor - hall lights
1st floor - front hall lights, living room outlets, outside lights
basement - some overhead lights
...all no longer worky.
I checked the main panel, all breakers OK. To be sure I reset each breaker (off then on) several times, no help.
Next I checked each breaker to see exactly what was connected to it (since the legend printed on the panel was a little cryptic), in an attempt to determine which breaker is controlling the affected circuit. Each breaker was verified working properly (stuff went out and came back on as each breaker was toggled). After completing this exercise I still have no clue to which breaker(s) the affected circuit is linked to. FYI - My panel has no GFI breakers installed.
All house appliances are working normally...no dimmed lights or other weirdness. The house was built in 1973, has modern wiring and one panel box. In my past experience electrical issues were always pretty simple to solve, this one has me stumped.
What am I missing?
Cheers,
Heloflights
2008 R1200GSA
Heloflights is offline   Reply With Quote
Old 05-07-2013, 03:23 PM   #2
Al Tuna
PUI... Deal with it
Al Tuna's Avatar
Oddometer: 13,783
What am I missing?
Call the power co, tell them you you may have lost a phase. Will the oven elements heat up?
Al Tuna is offline   Reply With Quote
Old 05-07-2013, 03:25 PM   #3
rapidoxidationman
Easily trainable
rapidoxidationman's Avatar
Oddometer: 8,764
Sounds like you lost one leg of your 220V in.
If you have a voltmeter and the knowledge to use it without getting thrown across the room, check for 220V at either a 220V outlet or inside the circuit breaker box.
Patrick:
I know I'm feeling badly when I have no interest in speeding
rapidoxidationman is offline   Reply With Quote
Old 05-07-2013, 05:04 PM   #4
Jayrod1318
Poster
Jayrod1318's Avatar
Oddometer: 1,641
If you did lose a leg, if you have any appliances like a electric hot water heater you will see some voltage on the dead leg causing untold head scratching and cursing. Damhik
And in the mean time unplug everything! This can damage electronics.
Jayrod1318 is offline   Reply With Quote
Old 05-07-2013, 05:06 PM   #5
Al Tuna
PUI... Deal with it
Al Tuna's Avatar
Oddometer: 13,783
And cause a fire.
Old 05-07-2013, 05:19 PM   #6
Garbln
Oddometer: 450
Try resetting the main breaker on your breaker box, one phase may have popped. Sometimes shutting them completely off than on again will do the trick. If that doesn't do it call the power Co NOW! Don't ask me how I know how much damage a gopher can cause when you have underground service!
Garbln is offline   Reply With Quote
Old 05-07-2013, 07:03 PM   #7
D.T.
Difficult but useful
D.T.'s Avatar
Oddometer: 11,339
Burned wire or bad connection to outlets?
Originally posted by burgerking So?
Holland is about the most expensive country in Europe when it comes to bikes and fuel..Stop whining and go riding It's just money and you only live once...
D.T. is online now   Reply With Quote
Old 05-07-2013, 08:57 PM   #8
Twilight Error
Going nowhere slowly
Twilight Error's Avatar
Oddometer: 22,743
You may be able to determine a dropped phase by looking at the circuits that don't work. A panel is set up so the phases alternate A/B/A/B/A... down each side. If every other circuit works, you do indeed have a dropped phase and it needs to get sorted ASAP.
Twilight Error is offline   Reply With Quote
Old 05-08-2013, 07:20 AM   #9
River
Gee
Oddometer: 217
It's not because I'm an electrician, but call an electrician
Everyone has their own rhythm....so find it and lets jam
River is offline   Reply With Quote
Old 05-08-2013, 07:28 AM   #10
River
Gee
Oddometer: 217
There is a possibility that there is a GFI receptacle in the circuit. They can be configured in such a way that everything downstream of the receptacle is protected by the GFI. This would not normally be done with the interior and exterior devices, but I have seen some goofy configurations in the past. You would simply have to reset the recptacle. Other than any obvious conditions, there could be loose connections(common with older aluminum wiring) that have burnt off in a junction box somewhere. These loose connections are the common cause of electrical fires.
Whatever you do, respect the voltage
Old 05-08-2013, 07:33 AM   #11
Dr. John
Oddometer: 73
First buy,or borrow a cheap voltage tester and check the outgoing side of each breaker. If you have 110 at all your single breakers, then test your double pole breakers for 220. A lot of people (electricians included) will use the quick wire plug in feature on outlets and switches ,that when overheated multiple times will allow the pushed in wire to either back out slightly ,or cause the spring brass that held tension on the conductor to lose it's grip. So it's possibly a circuit that starts out fine and goes to hell in a downstream plug or switch. Now the fun begins. Start at the first light or outlet not working,and closest proximity to your panel take it out of the wall and use your tester to check for voltage on both sides. It's a pain in the ass search for things like this,but if it's not a breaker,or a lost leg coming in (doubtful too many things working in the house) it's a good way to learn your house,and cheaper than hiring someone who will do the same.By the way,if you can find a non digital tester for this job you'll be happier with the results as digitals can give phantom voltage readings that will drive you nuts. Be careful,proceed slowly,and good luck.
Dr. John is offline   Reply With Quote
Old 05-08-2013, 01:30 PM   #12
rgoers
Oddometer: 372
My thoughts exactly! The Bozo that wired my house put the outside outlets, the garage, and the outlet over my water heater in my utility room all on the same GFI. It justs happens that my internet feed is in the utility room too, so when something pops the garage GFI, my internet goes out. He also wired all the bathrooms on one GFI, so when the powder room pops, I have to reset it on the opposite end of the house, in the master bathroom. Idiot...
2009 KLX 250S
If it ain't broke, take it apart and find out why!
rgoers is offline   Reply With Quote
Old 05-08-2013, 02:03 PM   #13
Jayrod1318
Poster
Jayrod1318's Avatar
Oddometer: 1,641
The house must have burnt to the ground. No response from the OP.
Old 05-08-2013, 03:11 PM   #14
Heloflights OP
Oddometer: 178
Bluhduh Interesting...
Power Co was just here, both 120V phases and neutral checked out fine.
Turns out several of the affected circuits appear to be suffering from low voltage (~80-100) which explains why bulbs are not lighting up. Power co tech was of the opinion that perhaps the main panel breaker may be crapping out/acting flaky, electrician on call for tomorrow....
...never a dull minute....
Cheers,
Heloflights
2008 R1200GSA
Old 05-08-2013, 04:13 PM   #15
River
Gee
Oddometer: 217
Times are GMT -7.   It's 09:05 PM.
