Old 05-08-2013, 04:18 AM   #1
MrBob OP
Certified Geezer
MrBob's Avatar
Oddometer: 7,563
Best Screwdriver?
I'd like to get a cordless screwdriver. I already have two cordless drills.
I"m back to working full time as a carpenter and have multiple uses for a compact cordless screwdriver I can slip into my tool belt.
Here's an example, though I'd need some convincing before I'd buy a B&D tool for commercial use.
http://www.toolbarn.com/blackdecker
What's worked well for you guys?
"When I was younger I was afraid I'd die riding now that I'm old and falling apart, I'm afraid I won't."
bwanacswan's dad
MrBob is offline   Reply With Quote
Old 05-08-2013, 05:49 AM   #2
thetable
thetable's Avatar
Oddometer: 1,446
For some reason, they keep buying the cordless screw drivers at work; we've been through a half dozen brands and they have all been junk. Slower and less torque than just pulling screws with a traditional screw driver. If I'm dealing with enough screws to want power, I'll grab a drill.
thetable is online now   Reply With Quote
Old 05-08-2013, 06:35 AM   #3
GreaseMonkey
Preshrunk & Cottony
GreaseMonkey's Avatar
Location: The only county in Illinois with no train tracks
Oddometer: 5,299
The best cordless screwdriver I had was a makita 4.8V cordless drill, if you are installing screws into pre drilled holes or machine screws into threaded fittings. As with the above poster, I have not had good experiences with any "cordless screwdriver", I have always found cordless drills to be stronger and faster. For things like drywall screws a regular drill or screwgun is about the best thing I have found, and if you are removing and reinstalling a zillion screws on access panels a small 3.6-7.2V drill is both handy and fast.
GreaseMonkey is offline   Reply With Quote
Old 05-08-2013, 07:30 AM   #4
MrBob OP
Certified Geezer
MrBob's Avatar
Oddometer: 7,563
I should add that I'd be using this tool to sink screws in pre-drilled holes, nothing real heavy duty.
bwanacswan's dad
Old 05-08-2013, 09:10 AM   #5
beewerks
Oddometer: 53
We have about 5 Bosch PS20 12 volt drivers here at work. They are all about 3 years old and get tons of abuse. The battery life is great, even after 3 years, lots of power, and they are very well built and light weight. I'd highly recommend them.
'04 BMW R1150GS Adventure
'81 Kawasaki KZ750 H1
'04 Honda Nighthawk 250
'08 Yamaha Zuma 50cc
beewerks is offline   Reply With Quote
Old 05-08-2013, 09:28 AM   #6
MrBob OP
Certified Geezer
MrBob's Avatar
Oddometer: 7,563
Looks like a nice unit:
http://www.cpotools.com/factory-reco...-drill-drivers
bwanacswan's dad
Old 05-08-2013, 01:22 PM   #7
rgoers
Oddometer: 372
Milwaukee M12 series!!! I've had one go off a 2-story roof onto pavement, and still come up working. Good power, lightweight, very long lasting, built-in battery readout so you know when it's time to recharge (before it dies).
2009 KLX 250S
If it ain't broke, take it apart and find out why!
rgoers is offline   Reply With Quote
Old 05-08-2013, 03:48 PM   #8
TeneRay
2>4
TeneRay's Avatar
Oddometer: 2,118
Grey Goose and Tropicana usually make a good Screwdriver....
TeneRay is offline   Reply With Quote
Old 05-08-2013, 04:38 PM   #9
ttpete
Rectum Non Bustibus
Oddometer: 5,940
I also own one, and use it extensively on motorcycles. Super tool. Using socket drivers, it does almost everything I used to do with T-handles.
http://www.amazon.com/Milwaukee-2401.../dp/B000WI9CIG
15 BMW RnineT
09 Kaw Versys
Old 05-08-2013, 05:16 PM   #10
MrBob OP
Certified Geezer
MrBob's Avatar
Oddometer: 7,563
Another missed deal:
http://www.cpomilwaukee.com/milwauke...efault,pd.html
bwanacswan's dad
Old 05-08-2013, 05:47 PM   #11
threadkiller
Semi-feral Pappy
threadkiller's Avatar
Oddometer: 1,782
Yankee screwdriver FTW!
threadkiller is offline   Reply With Quote
Old 05-08-2013, 09:01 PM   #12
redprimo
Oddometer: 460
+1 for the original cordless driver.
redprimo is offline   Reply With Quote
Old 05-10-2013, 05:42 PM   #13
MrBob OP
Certified Geezer
MrBob's Avatar
Oddometer: 7,563
I've had one for more than 35 years - BTDT.
bwanacswan's dad
Old 05-12-2013, 05:21 AM   #14
threadkiller
Semi-feral Pappy
Oddometer: 1,782
Well, you DO need to be smarter than the tool...
I've done thousands of electrical trimouts with a Klein yankee screwdriver. Nothing beats it.
Times are GMT -7.   It's 06:48 PM.
