Old 05-08-2013, 06:23 AM   #1
XCgeek OP
Oddometer: 58
My Bike Build
Hi. Welcome to my bike build thread and first ever post on ADV.
I’m building my own bike largely because I think that I can. Na, I know I can. I am a mechanical engineer by trade which means I can crunch numbers, work computers, inspect workmanship bla bla bla bla. What is does not mean is that I can weld, turn assemble or any other craft type skills. Much of this I will be learning and increasing my skills in as I go. That is not to say that I can’t weld, just that it is not something that I ever do for my job or have ever done any significant training for or qualifications for.
So, what to build?
Well, 8 or 9 years ago, I had a really interesting job in a very small design firm in Christchurch, New Zealand. One of the more interesting projects we did was an ultra light motorcycle. It weighed in at about 55kg (about 120lbs), was fitted with a pit bike engine (angled up to increase clearances), Down Hill mountain front forks, pit bike air rear shock. My job was to design a frame, swing arm and subframe to tie all these items together within design parameters (shape, form, construction method) prescribed by the client. I also designed the fuel tank and rear hub.
You can check them out and even buy one if you want from here:
www.fxbikes.com
Ever since then, I have wanted to make one for myself but with my design parameters.
First off, some things that this bike will NOT be!
An adventure-touring bike suitable for long multi day rides,
A motocross race bike set to take on Suzuki, Honda, KTM etc,
A trials bike that Toni Boa will want to compete on,
Your ideal bike!
Now, here is what I want the bike to be:
Light! The goal is 50kg, anything lighter than 55kg will be acceptable,
Air cooled. I don’t want to deal with radiators during the build or riding,
4-Stroke. I want to run straight gas,
Tuneable. I want to be able to use engines that very from mild to wild (well, to less mild),
Sized to fit an adult of about my size (176cm),
Make-able. I don’t have a mill or presses to create monocoque frames etc,
Fun! To both build and ride.
The idea for the bike is sort of an ideal recon bike. Light enough to lift over a fence or carry across a water crossing. Fast enough to have fun on while trail riding with mates and will hold its’ own when ridden with friends on typical dirt bikes. The bike is designed with heavy-duty bicycle components where possible to keep the weight down.
So here are some of the bits that will be used:
Honda XR 100 engine (6hp wu hu!),
Kitaco 145 engine kit (18-22hp! That is in the realm of a stock XR 250),
Marzocchi Monster T 8” travel forks,
Fox air rear shock,
CR 125 seat,
Bicycle front wheel,
Home-made rear hub laced into a motorcycle rim,
Formula disk brakes,
Home-build cromoly tubular frame and swing-arm,
Home-build aluminium fuel tank and air box,
A Clake.
www.clake.com.au to operate the rear brake and clutch in one unit,
I still have a couple of the FX Bike parts such as the rear fender so I’ll use those also.
See you next time when we get into the design in the CAD system
XCgeek screwed with this post 05-25-2013 at 05:04 AM
XCgeek is offline   Reply With Quote
Old 05-08-2013, 07:04 AM   #2
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,689
Nice, very interested to see this happen. Cool parameters too
We're not out here to rough it. We're here to smooth it. Things are rough enough in town.
Nessmuk
Old 05-08-2013, 08:05 AM   #3
XCgeek OP
Oddometer: 58
Ok,
One of the things I do for a job is to create CAD models. Well, I did in a previous job. So I used a CAD system to layout the design for my bike also.
I create the bike frame, swing arm and sub frame as one part that I can then subdivide out into all of the individual components necessary for the build. I then get all those individual components, add all the cuts, threads and hollows and reassemble them into assembly files.
Solid model including jigs from the frame and swing arm ready to be subdivided out into separate components
Now, to make any given component, I can go to the individual components part file and make a drawing of that part.
And now all the individual components are added back into an assembly file.
This process takes many hours, many changes and lots of design decisions.
Also, because I am building my frame from scratch, I will make jigs that will position the critical components and hold them while the interconnecting frame members are added and join everything together
The almost complete assembly file of the whole bike. I won't be bothering to include items that I won't be making or that do not interface with items that I will be making such as the handle bars and controls
last pic for today
When designing the FX Bikes, we did a link-less rear suspension design. It caused some design decisions that I was never happy with so I have made mine with a linkage to drive the rear shock. This will also allow a measure of tune-ability by being able to change the geometry on the linkages. Much more complicated but it's my bike and I want it.
XCgeek screwed with this post 05-25-2013 at 05:07 AM
Old 05-08-2013, 09:00 AM   #4
andyhol
volcano rider
andyhol's Avatar
Oddometer: 152
Just what I've been thinking about making for the super tight trails here in Indo. Too cool.
current rides: tiger 200 and cb200 scrambler in indo
90 yamaha xtz750 super tenere, 98 honda vtr 1000 firestorm in the uk
andyhol is offline   Reply With Quote
Old 05-08-2013, 10:15 AM   #5
Salsa
Oddometer: 389
Sounds like what I built a few years ago.
138cc Pitbike motor
Downhill Bicycle Forks
Bicycle rims
8" Double disk front brakes
8" Disk Rear brake
Fabricated bicycle hubs
Stainless Spokes
Adjustable Head angle
Competition Motocross Air shock (1)
Street Legal with License Plate
130 Pounds plus Gas
So then I wanted one that was more suited for offroad.
160cc YX160 Pitbike motor
KX85 Forks
17" & 19" Alloy rims
8" Disk Rear brake
Fabricated bicycle type hubs
Stainless Spokes
Competition Motocross Air shock - Under Seat
A little heavier - forks, rims, tires
Don
Salsa is offline   Reply With Quote
Old 05-08-2013, 11:48 AM   #6
sanjoh
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,134
Welcome to ADV!
Do you have a budget in mind?
Old 05-08-2013, 03:35 PM   #7
ianmp
Oddometer: 105
Fox air rear shock,
CR 125 seat,
A Clake. www.clake.com.au to operate the rear brake and clutch in one unit,
I love this idea, and have been toying with one of my own. I have designed and fabricated a bunch of downhill bikes, so this piques my interest in many ways. I don't want to question your intentions at all, just curious about part spec:
Why a Monster T? Is it because you have one laying around? Furthermore, why a fox air shock? Same as above?
If you already have them I understand that. If you were starting from scratch I would consider more modern fork options; A Rockshox Domain, for instance, has the durability of steel stanchions, coupled with all the spring and damper options of a Boxxer (including 3rd party like Avalanche). It would weigh much less than a Monster T, and even less still with the air spring.
The air rear shock is a head scratcher... While there are several nice options out today (CCDB Air, RS Vivid), the only fox offering suitable for speeds is the RC4 air and they are unreliable. The rear shock is not somewhere to cheap out for weight's sake, and (personally) I would choose a coil every time. Even if the intent is to reconnoiter, a bike with an xr100 motor will be capable of sustaining 30+ mph speeds on dirt, and a platform valved air shock (rp23 etc) just won't cut it. From an engineering standpoint, the less leveraged the shock is the better it will perform as well, so if you are putting 8" in the rear wheel to match the front, a 10x3.5" stroke shock would be best. 9.5x3.00 is the most common on DH bikes, and I'm pretty sure platform air shocks are usually in the 1.5-2" stroke range tops. Sorry for using imperial.
Well free advice is worth what you paid for it. Good luck, I'm subscribing to this and anxious to see your CAD drawings!
Edit: pics just loaded up of the bike drawings. Very interesting-- I have more free advice but I think I'll shut my mouth for awhile ;)
ianmp is offline   Reply With Quote
Old 05-08-2013, 04:23 PM   #8
Rebuilder
Rebuilder's Avatar
Oddometer: 205
Well this should be good. An engineer with limited build skills. Usually, at least in my case, it's build "skills" with no formal engineering knowledge.
Good luck.. I love the idea.
Rebuilder is offline   Reply With Quote
Old 05-08-2013, 04:28 PM   #9
MrBracket
MrBracket's Avatar
Oddometer: 261
Exciting! I'm watching this thread for sure!!!
MrBracket is offline   Reply With Quote
Old 05-08-2013, 04:40 PM   #10
MitchG
Iron Collector
MitchG's Avatar
Oddometer: 482
If the honourable MrBracket is in then so am I! (actually I subscribed earlier today) Been waiting for my FX for too long and no end is in sight yet, so it's do it yourself time....
Life is short, don't waste it....now get out there!
MitchG is offline   Reply With Quote
Old 05-08-2013, 05:00 PM   #11
XCgeek OP
Oddometer: 58
Originally Posted by sanjoh View Post
Welcome to ADV!
Not really. It would be nice if it came in a half the cost of something new but things like the Kitaco kit are not cheap. I'll keep track of the costs.
XCgeek screwed with this post 05-08-2013 at 05:14 PM
Old 05-08-2013, 05:13 PM   #12
XCgeek OP
Oddometer: 58
You are right, I had both items already so I used them BUT..
The Monster T fork, while heavy, is ultra reliable and has a nice damping systems. I like the Aluminium stanchions as my experience with every steel stanchion is that they end up rusting. However, I have not kept up with the latest fork offerings for DH bikes.
On the rear shock, I am using a Fox MXR with 76mm (3") of stroke designed for motorcycles. I had the same concerns that you have raised.
Old 05-08-2013, 09:01 PM   #13
JagLite
JagLite's Avatar
Oddometer: 1,246
Thumb Light is Right!
Great build plan.
I'm in!
Salsa, those are a couple of interesting bikes.
Thanks for posting the pictures.
Attitude ~
The difference between
Ordeal and Adventure
James
JagLite is offline   Reply With Quote
Old 05-09-2013, 01:44 AM   #14
Aussie Bruce
Oddometer: 3
Ducati concept maybe ?
Yep im in and i like the concept
food for thought maybe
http://www.motorcycledaily.com/wp-co...062104pic3.jpg
I had a ducati cucciolo on a mountain bike frame 1951 /52 t2 model but always wanted more
Bruce
Aussie Bruce is offline   Reply With Quote
Old 05-09-2013, 08:39 AM   #15
bk brkr baker
bk brkr baker's Avatar
Oddometer: 5,709
I picked this one up on E-bay. DRZ 125 with a modified frame , warmed over motor , 17" wheels , etc. Set up as a flat-track bike.
Little remains of the stock frame , just the steering tube and downtube plus the the tube where the footpegs and swing-arm attach.
It's a fun little bike, but, the gas tank is only about 1/2 gallon so no long range travel.
Good luck with your build, the frame looks strong enough for 500 cc of hot motor !
bk brkr baker is online now   Reply With Quote
Times are GMT -7.   It's 06:12 AM.
