Old 05-28-2013, 09:03 PM   #46
anonny
What could go wrong?
anonny's Avatar
Oddometer: 5,613
Originally Posted by sailah View Post
send me a dxf file and I'll cut whatever you want for the cost of postage. It'll be an international collaboration
Nice touch!
Kawasaki H1 build thread
71- 450 Honda CL re & re
anonny is online now   Reply With Quote
Old 05-31-2013, 04:02 AM   #47
XCgeek OP
Oddometer: 58
Hi all,
Things have been a little slower lately. First I managed to slice my wrist open on an unrelated project. That caused a 4 hr wait at the EM room for six stitches. About 2.5 hrs into the wait, the lovely nurse jabbed me with the local anesthetic. Pity that it had worn off by the time the doctor came by to do the stitching.
Not to matter, the project must go on.
The swing arm is coming along. I have all the tubs in and most of them fully welded. The jig gets in the way for some welds so now I have to pull it off the jig to finish it off. It will be interesting to see just how much the drops move once released from the jig
My welding still sucks but I can see improvement!
We then had a couple of days of rain and seeing as this is my home work space
I set out to perform other work where I was less likely to electrocute myself.
The next item on the list is the shock pivot. I decided on a linkage suspension design for a couple of reasons;
1) Most all dirt bikes use a link suspension design so there must be something in it,
2) A progressive suspension action will allow a plush initial ride while still allowing bottom out resistance,
3) I am using an air shock and air springs, unlike coil springs and very progressive. My experience with mountain bikes indicates that generally, most air shocks are too progressive and require too much sag to allow all the travel to be used,
4) My air shock (a Fox MXR mini bike shock) has an adjustable air chamber. Smaller air chamber equals more progressive, larger air volume equals less progressive. So I have some room for adjustment.
5) I am not sure what the best ratio would be. Many people assume that as an engineer, I can do some calculations and come up with the numbers. If that were the case, every bike would have the exact same design and ratios as they would be known to be the best. This is not the case because there is no “best” solution. In engineering, EVERYTHING is a compromise.
With my linkage design, I have made the linkage a falling rate as possible. When it turns out to be too falling rate (too linear or even worse, stiff early and softer later in the travel) then I can reduce my air volume. If that does not get enough progressiveness, then I can simply redesign and remake the linkage and pivot without having to change either the swingarm or main frame.
Blaa blaa Blaa all text and no pics makes this a sad thread.
And yes, despite having an offer to have these plates cut out on a water jet, I once again cut them both out by hand (grinder, drill press really).
Good news is that the shock actually fits nicely.
Next post. Lets finish that swingarm.
XCgeek is offline   Reply With Quote
Old 05-31-2013, 04:23 AM   #48
Pete-NZ
Pete-NZ's Avatar
Oddometer: 743
If you are tig welding steel.... use stainless steel filler rod...
try not to over heat the steel... all the impurity's come to the surface
as you are finding out... easyer said than done at times...
Even the steel tig filler rod has a lot of impurity's in it..
Gas filler rod..don't go near it..
Here.... my XR250 leaner side car build
http://www.advrider.com/forums/showthread.php?t=716993
Pete-NZ screwed with this post 05-31-2013 at 04:31 AM
Pete-NZ is offline   Reply With Quote
Old 05-31-2013, 04:47 AM   #49
XCgeek OP
Oddometer: 58
Thanks for the tip. I will try that. I also need to go down in rod filler size. Most of my welds are coming out to hot. The only ones that are OK are where I am not adding in any filler wire
Old 05-31-2013, 03:38 PM   #50
RedRaptor22
Oddometer: 155
Not sure I would mess with the stainless fillers, that does'nt look bad, I just see bad stacks, no burning or anything.
Drop down a size on your filler and work a smaller puddle, if your having trouble with pulling always make sure to weld the open sides of the joints first, the closed sides last and it'll pull a little less...but it'll still pull so factor that into the fit.
Sometimes if you get out of square you can do some dry passes without filler here and there in strategically placed locations to pull it back into shape, which gives you the opportunity to make the welds look a little nicer.
RedRaptor22 is offline   Reply With Quote
Old 05-31-2013, 04:07 PM   #51
Leo.G
Is still learning
Leo.G's Avatar
Oddometer: 391
Now this is a really nice build...
Please keep posting!
And hope your wrist gets better soon!
2010 Honda XR 250 Tornado
Leo.G screwed with this post 05-31-2013 at 07:42 PM
Leo.G is offline   Reply With Quote
Old 06-02-2013, 01:31 AM   #52
jesusgatos
fishing with dynamite
jesusgatos's Avatar
Oddometer: 2,390
Fuck yeah! Love it. Flew down to LA to meet the owner of FX bikes when he first brought them to the US, as I'd been wanting to design/build something similar for a long time. You did a nice job with that bike, but this one looks even better. I ended up putting together a bigwheel CR80 / XR100 hybrid, and it was a blast. Almost exactly the same size as a mountain bike, and weighed about 160lbs, but it was a full-blown mini-moto. Think you'll be pretty happy with that kitaco engine too. Had a nice BBR-built big-bore in mine and it had plenty of power for riding trails. And for a guy who started this project with a disclaimer about not being a fabricator, you're doing a hell of a job. All those hand-cut brackets look fan-fucking-tastic. Keep up the good work!
Oh, and sailah, gonna be sending you some CAD files...
GatosBros · Crux Studio · Trails Less Traveled
jesusgatos is offline   Reply With Quote
Old 06-02-2013, 01:35 AM   #53
jesusgatos
jesusgatos's Avatar
Oddometer: 2,390
Do you have any plans beyond building one of these for yourself? Any aspirations to develop something like a frame/kit/complete bike? Or maybe sharing CAD files? Any chance?
Old 06-02-2013, 06:20 AM   #54
XCgeek OP
Oddometer: 58
Building a few more is sitting in the back of my mind. I need to improve my welding before then but it is being thought about.
Old 06-03-2013, 10:11 AM   #55
jesusgatos
jesusgatos's Avatar
Oddometer: 2,390
That's great to hear. Excited to see how this turns out.
Old 06-04-2013, 05:57 AM   #56
XCgeek OP
Oddometer: 58
Things are finally starting to move along faster now. That is for a couple of reasons.
First is I quite my job. It was a good job and I mostly enjoyed what I did. It just got to the point where I did not agree with those above me and obviously, they were going no where so I did. So far, it has been the best this I ever did.
Second reason is that the tedious work of carefully coping tubes together and the finicky welding around these tube joints is done!
Welcome into existence my frame and swing arm assembled together.
Note that the shock is just temporarily bolted directly to the swing arm. I have the linkages made as per a post above but they have been painted now and I want to leave them for a couple of days to allow the point to harden.
There is still work to be done on both the frame and swing arm. Not much on the swing arm, just mounting the chain slider. More on the main frame (oil cooler mounts, hydro clutch mount, electrical components mounts, fuel tank mounts). But this is all much easier welding and I am noticing I am getting much faster at the welding with better results.
Now, reassemble the engine, turn up the rear hub axle and spacers and fit the engine into a rolling chassis so I see how all the alignments are going.
Pics of a rolling chassis next time?
Old 06-04-2013, 06:10 AM   #57
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,689
Eek
Is it hard to embalm your wife in gold? Any issues?
Bike looks great
We're not out here to rough it. We're here to smooth it. Things are rough enough in town.
Nessmuk
Old 06-05-2013, 10:11 PM   #58
KarimADV
Oddometer: 67
Really nice job!
KarimADV is offline   Reply With Quote
Old 06-05-2013, 11:11 PM   #59
MitchG
Iron Collector
MitchG's Avatar
Oddometer: 481
Following closely. Keep up the good work.
Life is short, don't waste it....now get out there!
MitchG is offline   Reply With Quote
Old 06-06-2013, 10:37 AM   #60
Lizrdbrth
Wackjob
Lizrdbrth's Avatar
Oddometer: 865
Ditto. Planning a similar (though less ambitious) project along these lines.
SUBSCRIBED
Lizrdbrth is offline   Reply With Quote
Times are GMT -7.   It's 07:23 PM.
