Old 06-21-2013, 03:40 PM   #91
PhiSig1071
What's ******width?
PhiSig1071's Avatar
Oddometer: 2,399
Subscribed, this looks cool. Makes me wish I still had my old XR100.
Which one of you FF's was it?...FOUNDER!
Entia non sunt multiplicanda praeter necessitatem
PhiSig1071 is offline   Reply With Quote
Old 07-10-2013, 01:30 PM   #92
MrPulldown
MrPulldown's Avatar
Oddometer: 3,060
What is going on with this build. Any news. Hope you did not get sucked back up into the working world.
MrPulldown is offline   Reply With Quote
Old 07-20-2013, 02:10 PM   #93
Billedale
Oddometer: 9
I've been wondering the same, this is a really cool project and it was coming along quite well!
Edit: Oooh, this is my coming out of lurkerdom on this forum! See how important your project is :).
Billedale is offline   Reply With Quote
Old 07-20-2013, 04:04 PM   #94
TangentRogers
TangentRogers's Avatar
Oddometer: 9
Its enough to finally bring me out of the shadows too!
This is an awesome build XCgeek, definitely the best and most thorough I've seen here. I wish I had your CAD skills. I'm still stuck in 2D using AutoCAD, haven't got my head around solid modelling yet.
Any updates for us?
TangentRogers is offline   Reply With Quote
Old 10-18-2013, 06:48 AM   #95
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,561
We're not out here to rough it. We're here to smooth it . Things are rough enough in town.
Nessmuk
Old 10-21-2013, 01:12 AM   #96
sonic reducer
Oddometer: 227
I love what you are doing here. a couple thoughts:
switch to a marzocchi 888 or a fox 40. you will shed quite a bit of weight and not sacrifice a lot of stiffness. the 888 is very affordable, stiff, plush, and available in several levels of trick-ness depending on your budget. the fox 40 is the stiffer fork but much more maintenance intensive, more expensive, not quite as plush, and not as reliable in the long term. FWIW I have had 3 different 888's, various boxxers, and currently run a fox 40 on my DH bike. what you have got going on with the monster T is fine, but keep in mind that you may not gain much in stiffness with that fork and certainly that is the only thing the monster will have over any other DH fork. 888's are basically foolproof, plush, and very servicable. Im not sure how easily you will find replacement parts for monsters also.
building your shock mounts to a readily available DH size like 9.5x3 would allow you plenty of economical(and not so economical)options to try out new setups.
as for your welding, keep the gas flowing higher than normal, remember the post flow, keep your arc length short, and your tungsten sharp. a corroded, irregular tungsten makes proper technique way harder especially to the beginner. grind the tungsten properly and frequently. on these thin materials it's quite easy to heat soak the part so weld smaller portions before continuing and do a bunch of practicing. keep the amps at 1 amp per thousandth of an inch or below for thin materials. ie .065 run 60-63 amps until you feel that amps are holding you back.
sonic reducer screwed with this post 10-21-2013 at 01:18 AM
sonic reducer is offline   Reply With Quote
Old 10-23-2013, 02:39 PM   #97
MrPulldown
MrPulldown's Avatar
Oddometer: 3,060
Might as well be a dead post.
Op must have scored a real job again and has left us.
Or he is dead.
Old 10-23-2013, 04:53 PM   #98
ben2go
Moto Flunky
ben2go's Avatar
Oddometer: 3,242
Or he is dead.
Let's hope not the later.
Originally Posted by bassogap View Post
If my aunt had nuts, she'd be my uncle. What's your point?
Manic Cycles=My Blog
ben2go is offline   Reply With Quote
Old 11-10-2013, 04:13 AM   #99
XCgeek OP
Oddometer: 58
Hi. Uuummmm sorry about the lack of progress reporting. Some I can blame on a month and a half holiday to Montreal, some to a month and a half motorcycle tour around New Zealand, some to getting engaged (will this mean an end to these projects?) but most to just being a slack arse that likes to do and not so much about talking.
But please rest assured I am still here, still alive and much progress has been made.
One item for the build that has been giving me nightmares and at the same time, I have been really looking forward to starting is the fuel tank.
I have always wanted to weld with Aluminium and an aluminium fuel tank makes a lot sence. Light, strong, fabricatable, corrosion resistant…..
The design is tricky. 6 litre capacity with the air box built into it. The initial design also structural tubes passing through it to allow for the throttle cable routing and airbox drain.
Here are some images of the first trail!
View from below, large tube is airbox manifold, the other two small tubes are for throttle cable and drain
Filler neck starts life as a piece of 2" round bar
Airbox cavity. The top tube interfaces with the seat, the lower tube would be the tank mount to the frame, the middle tube is that pesky throttle tube. The throttle tube will be dropped for the second try
You can see here where the airfilter attaches within the airbox
Ugly!
Damn this is difficult. The design is too complicated to start with but I also learnt a whole lot about welding aluminium. This stuff moves, pulls, melts, cracks, gets really really hot!
The fuel cap is from a Beta trials bike which has a thread that does not measure up to any thread, metric or non metric that I can determine other that it has a 2.5mm or 10tpi pitch. No worries, I have a lath so I made a spout to fit the cap.
This tank was great learning so now to make mark 2. Simpler and marginally more skill.
XCgeek is offline   Reply With Quote
Old 11-10-2013, 11:18 AM   #100
Te Hopo
AKA Deanohit
Te Hopo's Avatar
Oddometer: 1,300
Welcome back XCgeek, I look forward to seeing what you come up with for tank no.2
Te Hopo is offline   Reply With Quote
Old 11-10-2013, 07:35 PM   #101
haystack
Just ride
haystack's Avatar
Oddometer: 3,965
Indeed, This is a gentleman's game....
German W.O.D. Certified
2014 Winner of the Biggest Potato in Jersey
haystack is offline   Reply With Quote
Old 11-10-2013, 10:54 PM   #102
Luke
GPoET&P
Luke's Avatar
Oddometer: 4,158
Yes, welcome back.
I've got a couple of airbox MK1s, one's hanging on pegboard and the other's buried in a box somewhere. Yours is nicer.
Luke is offline   Reply With Quote
Old 11-13-2013, 06:55 AM   #103
aposaric
Garden mechanic ;-)
aposaric's Avatar
Oddometer: 270
Welcome back dude, hope you had a nice rest
aposaric is offline   Reply With Quote
Times are GMT -7.   It's 08:24 AM.
