Old 05-10-2013, 05:49 PM   #1
WonTian OP
WonTian's Avatar
Oddometer: 19
Severely Damaged Engine Case(Threads)
So my inspection plug was very badly sized so I first cut a slit in it with an angle grinding and hammered at with a screw driver for a hour with no luck. Pieces of the plug were cracking and breaking off. So I broke out the drill and started drilling some holes thinking it would relieve some of the pressure, it didn't work. I stared hammering the holes with the screw driver again until enough of the plug had broken off to actually unscrew the plug. This is where I notice I messed up...bad. What are my options? I'm thinking if I just put a new plug in with RTV in the massive pits and it might be okay. or do I need a new side case?
WonTian screwed with this post 05-10-2013 at 06:37 PM
WonTian is offline   Reply With Quote
Old 05-10-2013, 06:13 PM   #2
rpeterk
Oddometer: 535
Judging by the looks of the mess you need to take the side cover off anyway to be able to adequately clean. Depending on the number of threads that are left you might be able to have the the surface welded enough to get a sealing area. You wont have threads there as that would be very time consuming to restore. Unless this is some vintage with parts that are very hard to get or its very expensive the best would be to replace it. If you have no way to get a new one I could make that one look like new but it is allot of work and time consuming. Where are you located? What kind of bike? A better pic of the whole area would also help.
bob
609-851-2810
TAG PICS http://photobucket.com/rpeterk
Life is not about how many breaths you take, but about the moments that take your breath away.
OCCR Ocean County Competition Riders
http://www.occr.net/
rpeterk is offline   Reply With Quote
Old 05-10-2013, 06:13 PM   #3
74C5
74C5's Avatar
Oddometer: 1,011
Not sure what I'm looking at. If the female threads are fooked, pull the cover and either replace it or, see if a Devcon titanium putty patch will fix them. Put wax or teflon tape on the new plug and insert then apply the devcon. That will allow later removal.
R1200RT (R1100RT gone)
KLR650 - gone
Don't be the guy who needs to pee on the fence to figure out that it's electrified.
74C5 is offline   Reply With Quote
Old 05-10-2013, 06:29 PM   #4
WonTian OP
WonTian's Avatar
Oddometer: 19
bob
609-851-2810
I'm in North California
Its a 01 DRZ400S, nothing special. I just don't to shell out the bucks for another engine case
Old 05-10-2013, 06:32 PM   #5
WonTian OP
WonTian's Avatar
Oddometer: 19
Where can I find this Devcon? I've never heard of it before
I actually am trying to get the side cover off but the starter gear screws are stuck...
Old 05-10-2013, 06:34 PM   #6
two40two
two40two's Avatar
Oddometer: 53
Is this a DR or KLR? Replace it- looks very eph'd. In addition to the metal fragments everywhere and inside i imagine- it looks like there is a hefty crack/fracture right before the first thread. Hammers are my favorite tool but they can wreak havoc on cast alloy pieces. Peace of mind is cheap when the alternative is sitting on the roadside with a defunct machine.
nothing to see here.. move along now
two40two is offline   Reply With Quote
Old 05-10-2013, 06:36 PM   #7
speedracertdi
speedracertdi's Avatar
Oddometer: 985
Wow! Somebody needs to take your tools away.
Roads? Where we're going we don't need roads.
-Doc Brown
speedracertdi is offline   Reply With Quote
Old 05-10-2013, 06:38 PM   #8
WonTian OP
WonTian's Avatar
Oddometer: 19
I know, right??
How would you have dealt with the problem?
Old 05-10-2013, 06:40 PM   #9
WonTian OP
WonTian's Avatar
Oddometer: 19
This is my 01 DRZ400S I just picked out a few weeks ago. The side cases are actually magnesium. The previous owner dropped in a deep mud puddle, so he was selling it cheap. This also probably explains why are all the bolts on this bike are sized.
My KLR on the other hand has been a rock these past years
Old 05-10-2013, 06:49 PM   #10
haggeo
haggeo's Avatar
Oddometer: 919
i had the same problem with my DR350 and this is what i did.
laid it on it's side
drilled 4 holes in (not through) the cap then used a castle nut socket to turn the wrench while standing on the wrench/socket/cap with my motocross boots on.
no damage to the threads or shavings in the hole.
i put the new cap in with anti seize compound and did not tighten the piss out of it like the PO did.
When the facts change, I change my mind. What do you do, sir? John Maynard Keynes
Faced with the choice between changing one's mind and proving that there is no need to do so, almost everyone gets busy on the proof." John Kenneth Galbraith
The object of life is not to be on the side of the majority, but to escape finding oneself in the ranks of the insane. Marcus Aurelius
haggeo is offline   Reply With Quote
Old 05-10-2013, 06:50 PM   #11
two40two
two40two's Avatar
Oddometer: 53
Best of luck with this. Do you have a quality extendable small magnet? Have you pulled the side cover off yet? I'm worried about debris in the crank case. A magnet may at least get the bolt fragments out of the engine, I don't know how much Fe is in the side cover. I'd plan on a few very short interval oil/filter changes after this.
Old 05-10-2013, 06:54 PM   #12
WonTian OP
WonTian's Avatar
Oddometer: 19
I wish I had seen this before I assaulted my DRZ with a power drill..
Old 05-10-2013, 06:56 PM   #13
WonTian OP
WonTian's Avatar
Oddometer: 19
Thanks. I'm still trying to get the side cover off, the starter gear cover screws are sized. I the bike on the lift right now tilted to the right so the shaving fall on the flywheel instead of down into the crank case. Thanks for the tip
Old 05-10-2013, 07:07 PM   #14
WonTian OP
WonTian's Avatar
Oddometer: 19
Originally Posted by AnnieGS View Post
Overnight treatment with PBlaster, judicious use of a torch, large allen key w/cheater bar...a drill should have been your last resort.
If you don't have (or can't correctly use) an impact driver, please don't try to remove the siezed bolts.
I also found a replacement side cover for my trail-damaged DRZ for about $30 on eBay.
Thanks for the input!
My first attack was WD40 overnight, heat gun, and 1/2 breaker-bar with a allen head, and it totally stripped it clean out. I think the plug is a soft aluminum
I might just start peeking around on ebay if I can't get this sorted out.
I'm going out on my KLR to pick up an impact driver right now, more updates later tonight
Old 05-10-2013, 07:19 PM   #15
haggeo
haggeo's Avatar
Oddometer: 919
If you don't have (or can't correctly use) an impact driver, please don't try to remove the siezed bolts/screws.
i used PBblaster (heat gun too) and could swear (in my case) it didn't get past the o ring down to the threads on the cap. the first attempts were with a pin spanner but it was a harbor freight cheapie that bent right away but it gave me the castle nut socket idea. laying the bike down is also key to getting enough pressure on the cap with my foot, otherwise the pins just spin off of the holes.
Times are GMT -7.   It's 03:48 AM.
