Old 05-11-2013, 04:08 PM   #16
Twilight Error
Going nowhere slowly
Twilight Error's Avatar
Oddometer: 22,715
Originally Posted by andrewsclues View Post
Thanks for the info Moto and Medic... when I do get a AmpMeter that works, what is the max drain or draw allowable?
I prefer Fluke multimeters, I use a 289 at work and have a 73 in my toolbox. There are plenty of decent options for the home mechanic, but Fluke is generally considered the standard.
An acceptable draw depends on the size of the battery. The ECU sips from the battery, that load takes much longer to drain the battery than your 5 day timeline, which suggests you're seeing an amp or so leaking somewhere. It could be as simple as a relay coil that's remaining energized.
Twilight Error is offline   Reply With Quote
Old 05-11-2013, 04:35 PM   #17
Motomedic
Motomedic's Avatar
Oddometer: 2,486
If you're seeing more than a .2 amp draw, find the culprit. An easy way to start eliminating circuits is with the ammeter (no P in ammeter ) connected, as per TE, start pulling fuses. When the draw goes away, you've found your suspect circuit. Using a wiring diagram (you DO have a manual, right?) the draw will be easier to find from there.
Feike
I don't have to agree with you to like you or respect you. -Anthony Bourdain
Motomedic is offline   Reply With Quote
Old 05-11-2013, 06:04 PM   #18
andrewsclues OP
andrewsclues's Avatar
Oddometer: 100
Thumb
will do.... i do have a manual. thanks!
1987 Suzuki Savage(sold)
1981 Suzuki GS750L
2002 GSX-R600 Telefonica (sold)
1987 Yamaha TW200
2007 Suzuki Bandit 1250s
andrewsclues is offline   Reply With Quote
Old 05-13-2013, 04:56 AM   #19
Yamarocket630
Honey Badger
Yamarocket630's Avatar
Oddometer: 533
That should be more like 0.010A or less. 0.2A will drain a moto battery in a matter of days.
Yamarocket630 is offline   Reply With Quote
Old 05-13-2013, 09:05 AM   #20
Motomedic
Motomedic's Avatar
Oddometer: 2,486
ECM memory, clock, etc. .01 amps? yeah right. Maybe on a older points equipped bike w mechanical gauges. Checking the manual is the best way to determine how much it should be pulling w ign off.
Feike
Old 05-13-2013, 06:46 PM   #21
Yamarocket630
Honey Badger
Oddometer: 533
You're right, as a matter of fact. I was WAY TOO HIGH on my estimate. I just checked a modern fuel injected, digital cluster bike. 0.000217 amps. (that's 0.2 miliamps) It actually varied from 0.000210 to 0.000268a. Modern cars with 30+ control units draw 0.01 to 0.025 amps. And don't try to tell me my meter isn't working right. Go check a modern bike for yourself.
Old 05-13-2013, 07:39 PM   #22
Motomedic
Motomedic's Avatar
Oddometer: 2,486
For the record Mr. Yamarocket, I DO check modern bikes all the time. I've been a motorcycle mechanic (notice the username perchance?) for about 20 years now.
I really wasn't trying to be specific on exactly how much a bike draws. We're trying to troubleshoot here, not quantify the exact draw. Sure, my modern KTM 950 (or is a '04 not "modern" enough?) probably draws less than .01 amps, but do I really care? No. If the battery goes dead, I start looking for issues. I know there's going to be some draw for the clock, etc, but I'm more interested in finding a short, not worrying about a milliamp or two here and there. .2 amps is a decent GENERAL starting point, and usually within a cheap meter's resolution. No offense to the OP's tools, his meter isn't exactly a Fluke. With an average moto battery being around 14 amp/hours, a .2 amp draw will kill that battery in about 70 hours, give or take a few minutes (or in your case, seconds )
In hindsight, I suppose my sarcastic remark about points bikes was a little off the cuff, but again, we're troubleshooting a bike on the internet, not the lab. My bad.
Once again, every manufacturer is a little different. That's why the manual, which I do believe I mentioned, is the best reference for how much the bike should draw with the key off.
Feike
Old 05-14-2013, 04:46 AM   #23
Yamarocket630
Honey Badger
Oddometer: 533
Edit... Not going to argue
Yamarocket630 screwed with this post 05-14-2013 at 06:41 AM
Old 05-15-2013, 04:01 AM   #24
andrewsclues OP
Oddometer: 100
Update... I picked up a new meter at Home Depot... a Klein MM200. And the ammeter function works. I am on the right track regarding that.
The bike's battery would not charge above 11.5 volts. I have two, older and cheaper chargers. One told me the battery was fully charged and the other gave me an error light. Could both chargers be faulty? Possible, but I am leaning toward a bad battery. I returned the battery to the store where I bought it and they happily gave me a new one.
I won't have time to connect the battery and look for "parasitic draw" (I learned a new phrase!) until Friday or Saturday.
Again thanks everyone for your help. Electrical stuff is really Greek to me so it is really appreciated.
More updates to come...
1981 Suzuki GS750L
1987 Yamaha TW200
Old 05-15-2013, 01:40 PM   #25
BossMaverick
Oddometer: 231
There was a recall on the '08 and '09 model year Bandit 1250's like mine (good choice of bike by the way). There is some info on it here: http://www.motorcycle.com/news/suzuk...les-90452.html
According to that article, Bandits made from July '07 on had the defective part so your bike may have somehow got the bad part depending on your build date. If you find a parasitic draw, you might want to check the regulator/rectifier to see if it is the culprit.
'09 GSF1250SA Bandit
BossMaverick is offline   Reply With Quote
Old 05-15-2013, 04:18 PM   #26
andrewsclues OP
Oddometer: 100
I will definitely check the rectifier.... that's some good info.
1981 Suzuki GS750L
1987 Yamaha TW200
Old 05-18-2013, 07:56 AM   #27
andrewsclues OP
Oddometer: 100
I just installed the new battery.... reads 12.71 v on the meter.
There is 0.014 amps of key-off parasitic draw when tested. I cannot find the spec in the bandit shop manual as to what this reading should ideally be. From reading comments from you guys, 0.014A should be OK.
Anyone disagree?
1981 Suzuki GS750L
1987 Yamaha TW200
Old 05-18-2013, 10:18 AM   #28
Motomedic
Motomedic's Avatar
Oddometer: 2,486
.014 should be okay as far as parasitic draw. Have you checked the rectifier?
Feike
Old 05-18-2013, 10:24 AM   #29
Twilight Error
Oddometer: 22,715
Anyone disagree?
.014A is fine, it should take a month in cold weather to pull the battery down like you're experiencing. The next suspect is your charging system, start with the R/R, those are easy to replace and less expensive than a new alternator.
Old 05-18-2013, 11:29 AM   #30
andrewsclues OP
Oddometer: 100
Charging system seems fine... 13.8v at idle, doesn't go above 14.3 when I rev the throttle. I'm hoping it was a bad battery. I will test voltage tomorrow morning to see if I lost any juice in the battery.
thanks.
1981 Suzuki GS750L
1987 Yamaha TW200
Times are GMT -7.   It's 12:02 AM.
