Old 05-12-2013, 09:02 AM   #1
MAXVERT OP
Rough Rider
MAXVERT's Avatar
Oddometer: 1,047
JB Weld Removal
While on a CDR ride, I fixed a small leak on the radiator of my KTM 690.
It looks like the leak is getting worse and I'd like to remove ( dissolve)
the JB Weld I used for the repair and send the radiator out for proper
repair.
What, if anything, will remove the JB ?
Thanks, Max
Da oggi la strada
senza limiti
MAXVERT is offline   Reply With Quote
Old 05-12-2013, 10:03 AM   #2
Cogswell
Spudly Adventurer
Cogswell's Avatar
Oddometer: 4,677
A grinder or wire wheel, very carefully !
Mike
Cogswell Rides To Big Bend
See my airhead project here
Time Warp Vintage Motorcycle Club
The good thing is, your damn motor can't read. If it says oil on the container, it's pretty much OK to dump in there.... ED.
Cogswell is offline   Reply With Quote
Old 05-12-2013, 10:35 AM   #3
redprimo
Oddometer: 553
Heat will soften/weaken it. a good heat gun or propane torch in a well ventilated area should do the trick. But you might check with the radiator repair shop first, their dip tank might take care of it.
redprimo is offline   Reply With Quote
Old 05-12-2013, 11:00 AM   #4
kubiak
Oddometer: 4,845
i had good luck with chipping it off with a hammer and flatblade screwdriver. need to be careful though.
Old 05-12-2013, 11:03 AM   #5
_cy_
Oddometer: 6,437
repair.
Thanks, Max
call the radiator shop ... they've got heated tanks full of caustic dip designed specifically to clean radiators. certain metals react differently to chemicals .. radiator shop should know what to do...
Old 05-12-2013, 11:14 AM   #6
Hurricane Bob
formerly: Bomber1965
Hurricane Bob's Avatar
Oddometer: 2,945
Quote
If it's a piece of metal or something that won't burn you can place it in the oven on 500 and let it sit for 15 minutes. Place the object ontop of a pan. Be very cautious when doing this and stay close to the oven. The JB Weld won't ignite but make sure the object has nothing flammable.
After the 15 minutes remove the item with tongs and place on a cutting board or something that can't burn. Using a chisel it will come off like butter.
Or
Use a solder gun or solder stick. They are about 20 dollars at home depot/lowes. Use the chisel attachment and let it get real hot then press it to the JB Weld. It will cut through it like butter.
Unquote
From a boating forum.
Hurricane Bob is offline   Reply With Quote
Old 05-12-2013, 12:20 PM   #7
Maggot12
U'mmmm yeaah!!
Maggot12's Avatar
Oddometer: 6,075
Dremel and try any of there small griding tips/bits.
Maggot
Don't sweat the petty things; Pet the sweaty things !!!
Maggot12 is offline   Reply With Quote
Old 05-12-2013, 02:09 PM   #8
qkenf4u
Oddometer: 201
Cool2
it will melt after 400-500* so a propane torch will melt it off . just hold it upside down and let it drip off .... calling the rad shop and seeing if their tank will eat it is a good idea also....
qkenf4u is offline   Reply With Quote
Old 05-12-2013, 03:20 PM   #9
speedracertdi
speedracertdi's Avatar
Oddometer: 985
Talking
Originally Posted by bomber1965 View Post
Quote
Or
Salt and pepper, season to taste.
Roads? Where we're going we don't need roads.
-Doc Brown
speedracertdi is offline   Reply With Quote
Old 05-13-2013, 08:23 PM   #10
Flashmo
Whatever...
Flashmo's Avatar
Oddometer: 2,623
Heat. You can break any epoxy bond with the right amount of heat.
Flashmo is offline   Reply With Quote
Old 05-14-2013, 05:33 AM   #11
dirty_sanchez
Dirty_Sanchez
dirty_sanchez's Avatar
Oddometer: 3,025
Yep, epoxies are nothing more than really strong plastics.
Plastics soften and even melt when you add heat.
Heat it up and scrape off the JB Weld with Moms best kitchen knife.
Dirty
No, really, the mustache means I love you.
dirty_sanchez is online now   Reply With Quote
Old 05-14-2013, 09:50 AM   #12
Tsotsie
Semi-reformed Tsotsi
Oddometer: 1,952
Before applying heat- what is the radiator made of? I am not familiar with how KTM make them. Many are plastic and AL composite or AL based.
A pic and patience.
Tsotsie is offline   Reply With Quote
Times are GMT -7.   It's 10:30 AM.
