Old 05-23-2013, 01:21 PM   #16
p_funk OP
Frequently Lost
p_funk's Avatar
Oddometer: 418
Originally Posted by larryboy View Post
I've seen at least 100 broken springs, 30 odd broken levers and not a single working 2008 > newer balancer lever system, NOT ONE.
So I've got the engine out. Beezer, apparently I lied to you - the piston did get walloped a little.
Pulled the clutch, everything looks pretty kosher as far as I can tell.
For shits and giggles I fished around with my magnet again and found these little gems (added to collection) Larry, make that 101 springs.
I picked up a cheapo Harbor Freight air wrench which worked great to get the clutch bolt off so... I guess I'll track down a rotor puller. These things are fairly specific, huh? Like not an autozone thing? Machine shop, eh? Sounds expensive. Forgive any ignorance, but I can't just throw these in?
AMA#2890779
NETRA#24973
2003 XR650R, 2008 Yamaha WR250R, 2003 SV1000N, 2014 FZ-09
p_funk is offline   Reply With Quote
Old 05-23-2013, 04:56 PM   #17
_ransom_
Oddometer: 11
looks like it sucks, but thanks for sharing. I know I am def learning from the pics and everyone elses comments.
cheers!
_ransom_ is offline   Reply With Quote
Old 05-23-2013, 07:00 PM   #18
Beezer
Oddometer: 5,791
ya.... looks like the spring went through the chain, I'm bettin theres more loose parts because I don't think the spring put the dents in the piston & case. moot point really.
as for the valves....I wouldn't buy a set of used valves just yet unless they were low mile & cheap. if you don't know how to do it take the head to somebody that does head work & have it checked. when this kind of thing happens it usually bends a pair.... like both intakes or both exhausts. the cast iron guides are prone to cracking too.... the exhausts are tougher than the intakes.
edit: out of that ebay pile you might use 1 or 2 valves.... the rest you have. there are apparently 3 shims along with you may or may not be able to use them... it's a roll of the dice
you will no doubt need some different shims for setting up the head after the new valves are fitted (and some later when they have broken in).
a new valve is about 25-30 bucks (exhausts cost more) shims can be had for $5-6
Beezer screwed with this post 05-23-2013 at 07:18 PM
Beezer is offline   Reply With Quote
Old 05-24-2013, 03:57 AM   #19
p_funk OP
Frequently Lost
p_funk's Avatar
Oddometer: 418
Well, F**k
Grabbed the head from the box I immediately stuffed it in after removal, and noticed something I had missed. This:
Well, shit. It's on the exhaust side, I assume it lost a battle with the decompressor, here's a photo with cam in place:
Decompressor looks ok, spring intact. Looks like steel is victorious against aluminum. This add to the jumped timing, bent valve theory?
I'll inspect the cam more after work (should have brought it with me) but I think my best move is gonna be replacing the whole engine. It's just the female stud for the valve cover bolt so maybe I can just clean it up, who knows. The only reason I'm keeping this damn bike is for a ride next month that I really don't want to bring my WR250 on (way too much road, going with 990's and 650's). I've already got a 685 on order from Eagle Mike so there's that... If I have time, I'll continue digging in order to provide yet another documentation of one of these things blowing up. I'm kind of curious how the inside of the case looks, but first priority is getting this thing going.
AMA#2890779
NETRA#24973
Old 05-24-2013, 07:06 AM   #20
Kawidad
Kawidad's Avatar
Oddometer: 4,849
Don't forget to pull the oil screen and check it out.
You can contact Engine Dynamics in the Bay Area. He does magic with damaged heads. He's expensive, but his work is beyond belief.
Quis custodiet ipsos custodes? - Juvenal
(Who watches the watchers)
Kawidad is offline   Reply With Quote
Old 05-24-2013, 09:14 AM   #21
Beezer
Oddometer: 5,791
I would think you have pulled threads or stretched cap bolts to go along with that big scrape... threads look ok in the pic but it's hard to tell.... will they take full torque (104 inch pounds)? replace the bolts, Helicoil the threads as required
was the piston divot on the right side? that would explain why only one valve hit & not both
Old 05-24-2013, 09:42 AM   #22
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 14,834
Looks like spring parts took a free ride to the top and bounced all around getting under the decomp, I'd try the valve cover on and torque the bolt, if it holds don't worry about the scrapes..doesn't really matter. Pretty sure 104 in lbs is way too much, 55 in lbs for the valve cover bolts that go into the cam caps and 69 in lbs for the other two.
When you split the cases you want to pay special attention to the needle bearings on the ends of the shafts, you can see one in the pic I posted. When debris goes between the gears it will spread the shafts apart and the needle bearing is the weak link. Fiddle around with them, spin, wiggle..if any needles fall out they're bad. I would be replacing every bearing in the entire engine plus the oil pump, there are a couple of bearings in blind holes that are hard to get out, a welder helps or take it to a machine/engine shop.
larryboy is online now   Reply With Quote
Old 05-24-2013, 01:08 PM   #23
Tsotsie
Semi-reformed Tsotsi
Oddometer: 1,841
Originally Posted by p_funk View Post
That looks like the coil transmission spring behind the ratchet - or parts of it.
Tsotsie is offline   Reply With Quote
Old 05-24-2013, 04:28 PM   #24
Beezer
Oddometer: 5,791
... let me rephrase that.
the holes for the bolts that hold the cover look fine (and ya, 50- 60 inch is right, depends on your source)
the ones you are worried about are the ones that hold the caps on the cam journals.... those are 104 in/lb
and I meant left side for the divot (left when sitting on the bike). what I think may have happened is the spring going through the chain cocked the gear & shaft so it hit the side or the head.... the only way that could happen (I think) is the cam cap bolts either stretched or the threads got pulled. so again.... replace the bolts & helicoil as required.
and if the divot is on the right side Larryboy may be right & the spring went through the decomp lever
(trying to figure how only one valve gets hit)
but pretty sure thats not what put the chunks in the case & piston.... something else. in fact mebby a couple
and btw... the cam chain should probably go in the dumper too
Beezer screwed with this post 05-24-2013 at 06:19 PM
Old 05-24-2013, 05:52 PM   #25
jdwxly
Oddometer: 15
Marknet says the rotor puller tool is a 22 x 1.5 mm bolt. You might be able to find one locally instead of buying a puller. But the Motion Pro tool is less than $10.
http://www.klr650.marknet.us/Doohickey.pdf
Don't forget to buy a replacement bolt for the rotor. It's a one-time-use bolt.
jdwxly is offline   Reply With Quote
Old 05-25-2013, 09:55 AM   #26
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 14,834
The decomp only cracks open that one valve under normal conditions and at low rpm starting speed it doesn't hit the piston...crack that valve open at idle or higher and it will tap the piston. It only took a few seconds to carve out the gouges we can see and that's when the valve met piston.
Old 05-26-2013, 03:32 PM   #27
p_funk OP
Frequently Lost
p_funk's Avatar
Oddometer: 418
Update
So I've been insanely busy with work. Also, not a single place within 50 miles of me sells anything 22X1.5 as far as I can tell. I refrained from ordering a puller online because I wanted to get on it right away. Would've totally arrived by now. Bottom end should be apart Tuesday. Anyway, I figured I'd educate myself on what the hell goes on with valves. Had a hell of a time getting the shim bucket out on the one in question. I figured what you guys have been telling me: bent valve - maybe pinning the bucket against its' "sleeve." Finally got the bucket out by spinning/pulling. Pulled the valve, but it looks pretty normal (compared to others, google image searches for 'bent valve') and slides with absolutely no problem.
In an ideal situation, I'd send this thing out to some adv reputable head guru who would make it sparkle, but I still have the unlikely prospect in my mind of getting it going by 6/7. I'm actually ok with pulling it apart later and sending it out as long as it doesn't explode on this trip. As far as I can tell the only problem (which may be fairly serious/I have no fix for) is that the shim bucket won't slide very well on the valve in question. There is no visible scoring or anything on the outside of the bucket or inside of the sleeve thing. the bucket appears to still be round (I know, tiny differences) so I'm not too sure where to look. I know they're not supposed to be swapped, but I tested it in the other sleeves and it slides no problem. I assume the correct answer is port and polish? I still await what lies at the bottom of that engine...
AMA#2890779
NETRA#24973
Old 06-15-2013, 12:48 PM   #28
Distantrider
Oddometer: 1
Thumbs down Shifting Problem
  • I have a 2011 KLR 650 that locks up almost every time when down shifting from 5th to 4th. You have to be very aggressive on the downshift and if your real lucky it may go into 4th. Most of the time it hangs up so you have to upshift back into 5th then really shove it back down. I've replaced the clutch pack and clutch cable so far. I ordered new shift rod, pawl, spring clip and shift rod spring. They will be here Monday. If these don't fix it then I'm getting rid of it. I've put 1000 miles on it since I bought it. It's been down more than it's been on the road.
Distantrider is offline   Reply With Quote
Old 06-16-2013, 08:25 AM   #29
Kawidad
Kawidad's Avatar
Oddometer: 4,849
Not the norm for this bike. Other faults, but not this one.
Old 06-16-2013, 08:40 AM   #30
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 14,834
That won't fix it, you have a bent shift fork on the drum, split the cases to fix it. The only way a shift fork gets bent is by the operator. May as well sell it now.
Times are GMT -7.   It's 01:23 PM.
