Old 05-15-2013, 10:51 AM   #16
ToPointsUnknown OP
Oddometer: 39
Time to start the front end!
I needed to mount the front tire so I could figure out how I'd line up the frame. The biggest issue was that the Lambretta originally had 8" wheels and I planned to use 12" wheels originally intended for a pitbike.
http://tboltusa.com/store/piranha-al...set-p-343.html
I had two sets of forks for the Lammy so I set about gettig a little extra length.
Welded a brace on
Chopped one set long from the bottom, the other long from the top
Welding them together to get about 2 extra inches of length in total
And mounted the front wheel!
ToPointsUnknown is offline   Reply With Quote
Old 05-15-2013, 11:16 AM   #17
ToPointsUnknown OP
Oddometer: 39
Shorten the swingarm!
I didn't take a ton of pics of thise but here you can see the line where I cut the swingarm to shorten it
And here it's welded back together, about 3 inches shorter
Here's a test fit of the new wheel on the swingarm, didn't have much more room to go shorter so this will have to do
Old 05-15-2013, 11:19 AM   #18
ToPointsUnknown OP
Oddometer: 39
Time to build the frame!
I chopped the front off one of the frames and stuck the front wheel on it
Pulled the ninja guts onto the lift and started playing with alignment
This was the first frame I built, I ended up changing it a couple days later (see below)
Those braces were going to get in the way of the side panels so I put the piece of the ninja frame back on that I had cut off previously and removed the side braces.
I chopped up the seat area form both frames and started lining up the pieces
I think there's enough side panel to cover the length (hopefully)
Welded the pieces together to make sure the whole thing would fit together.
Started lining up the tail of the Lammbretta to get welded on
more bracing
little note here- I had to put that tube going up in the picture below because that's where my VIN is!
That's all I have time for right now, I'll be back soon to post more!
Old 05-15-2013, 05:27 PM   #19
k-moe
k-moe's Avatar
Oddometer: 2,905
That is interesting. With that much modification to the frame I'd have thought you would need to have it registered as a special construction and get a new VIN.
k-moe is offline   Reply With Quote
Old 05-15-2013, 07:39 PM   #20
Salsa
Oddometer: 421
That is NOT a modification, that is a
SAFETY IMPROVEMENT !!!!!!!!!!!!!
Don
Salsa is offline   Reply With Quote
Old 05-16-2013, 05:02 AM   #21
ToPointsUnknown OP
Oddometer: 39
What are you, the Fun Police?
I think that falls under "don't ask, don't tell"
Old 05-16-2013, 05:11 AM   #22
Mr. Magoo
n/a
Oddometer: 4,977
I want to hang out in your shop! Great build!
Mr. Magoo is offline   Reply With Quote
Old 05-16-2013, 06:01 AM   #23
ToPointsUnknown OP
Oddometer: 39
The brakes!
It's much easier to push the scooter around the garage when you can stop it easily.
I made a plate to get the front disc mounted
The hole is for the axle, the slot hooks onto a tab on the wheel cam (the little silver arm) to keep it in place
Here's it's mounted with the caliper in place I had to cut and reweld it a couple times to get it to fit just right.
Onto the rear brake-
Here's a test fit, I wanted to be able to reuse the brake mount from the ninja, that wasn't going to happen
So I made another plate to attach the mounting bracket that came with the caliper
And shortened the arm that attaches the new bracket to the swingarm.
Old 05-16-2013, 06:12 AM   #24
ToPointsUnknown OP
Oddometer: 39
Just checked the info on the pictures I'm uploading into this post, these were taken in the beginning of May, so we're about 2 months into the build already. I really want to ride this to a rally the first weekend of June so I start putting in lot's of night and weekend hours in the hopes that I can get it done in time.
Got to get the exhaust mounted!
Why did I leave that arm sticking down at the rear of the frame?
Because that's where the exhausts are going to attach!
It was a really tight fit to get the exhaust headers mounted.
I had to cut the cross tube out of the header and cut, bend and weld the headers into shape.
Maybe not perfectly in line but close enough for this build
Old 05-16-2013, 06:31 AM   #25
ToPointsUnknown OP
Oddometer: 39
Pedal Power!
I had two rear brake pedals from the Lambretta purchase, why to cut the head off one, reverse it, build a mount for it and use it as the shifter?
Here you can see how I mounted the rear brake and attached it to the pedal
For the shifter I had to make an arm to bring it outward and downward. Outward to clear the engine and downward so the pedal would shift gears before bottoming out
One really long shift linkage later and it works!
Bonus shot- Here you can see the reservoir for the rear brake fluid (blue cap) and the radiator mounted
Old 05-16-2013, 06:32 AM   #26
ToPointsUnknown OP
Oddometer: 39
If you ever find yourself in Brooklyn PM me, the motorcycle garage that I've been wrenching at always has beer in the fridge
Old 05-16-2013, 08:28 AM   #27
Skibikejunkie
Skibikejunkie's Avatar
Oddometer: 73
Brilliant.
Can't wait to see how the story ends.
I brew the beer I drink.
'05 Husky TC 250 (Marianne)
'05 VStrom 1000
Skibikejunkie is offline   Reply With Quote
Old 05-16-2013, 10:21 AM   #28
MacNoob
MacNoob's Avatar
Oddometer: 1,674
Nuts.
"Persuade thyself that imperfection and inconvenience are the natural lot of mortals, and there will be no room for discontent, neither for despair."
MacNoob is offline   Reply With Quote
Old 05-16-2013, 03:13 PM   #29
Contevita
Cigar Adventurer
Contevita's Avatar
Oddometer: 3,000
We need video of that!
Nice build.
Contevita is offline   Reply With Quote
Old 05-16-2013, 04:11 PM   #30
k-moe
k-moe's Avatar
Oddometer: 2,905
Of course it does. But some municipalities, states, and insurance companies, are very good about asking.
k-moe screwed with this post 05-16-2013 at 04:33 PM
Times are GMT -7.   It's 06:53 AM.
