Old 05-17-2013, 08:26 PM   #1
gmtcm OP
KTM RIDER
Oddometer: 315
950 se voltage rectifier/regulator
My friend recently had a voltage rectifier/regulator go bad on his 950 SE. It also took the battery with it. He has since moved the unit away from the rear cylinder exhaust pipe so it doesn't succomb to heat of the pipe. How many of you SE owners have experienced this? I have 20K miles on mine, and worry about a failure out in the middle of nowhere. Any recommendations would be appreciated.
Thanks - gmtcm
Stand Behind Our Troops or Feel Free to Stand in Front of Them.
gmtcm is offline   Reply With Quote
Old 05-17-2013, 08:38 PM   #2
brents347
Trusting my Cape...
brents347's Avatar
Oddometer: 3,735
Not me, but MANY others. 20k seems to be alot, that is where I'm at as well. Move it now, an cross your fingers?
You could move the regulator, switch it for a new one and keep the old as a spare. At least that way you don't cook a battery.
07 Yamaha R6
07 KTM 950 Super Enduro
04 KTM 250exc- plated two-stroke
01 Kawasaki KE100
74 Honda MR50
brents347 is offline   Reply With Quote
Old 05-17-2013, 09:08 PM   #3
Volke
Oddometer: 10
My VRR went at 3950km's. It took the battery with it.
I bought a Rick's Motorsports VRR and a new battery, and so far with ~2100km on them, it's working.
Volke is offline   Reply With Quote
Old 05-17-2013, 09:09 PM   #4
triplenickel
triplenickel's Avatar
Oddometer: 2,428
I swapped my good working one proactively at 60k, I'll get around to moving the new unit one of these days.
07 SE
PG007
Old 05-17-2013, 10:21 PM   #5
gmtcm OP
KTM RIDER
Oddometer: 315
What happens is there is no early warning that it has taken out the battery, until the bike quits. By then it's too late. I guess I could install a voltmeter on the dash, but would probably never watch it and it would still go out.
Old 05-18-2013, 12:24 AM   #6
randel
randel's Avatar
Oddometer: 315
My regulator went at 47000km. Surprisingly I still have working original battery, 5 years old. New regulator is relocated to left side of frame, I also installed voltmeter.
950SuperEnduroR
Beyond clouds 2011
Beyond arctic circle 2010
randel is offline   Reply With Quote
Old 05-18-2013, 01:42 AM   #7
Peanuts
Peanuts's Avatar
Oddometer: 1,598
You may hear the battery whistling after you turn off the ignition. That is the sound of gas escaping because it is boiling up inside. Catch it early enough and the battery will survive.
Peanuts is offline   Reply With Quote
Old 05-18-2013, 02:42 AM   #8
Xmoto
Death Race
Xmoto's Avatar
Oddometer: 2,107
My VRR went at 7000 miles and also took the battery with it. I replaced it with a Rick's Motorsports VRR . I had a strong sulfur smell coming from the battey as it was venting from the seems.
Opinions are like butt holes. Everyone has one and there's is the only one that doesn't stink.
Xmoto is offline   Reply With Quote
Old 05-18-2013, 04:10 AM   #9
ststrider
some guy on a bike
ststrider's Avatar
Oddometer: 379
my regulator went at 32000km and took the stator with it.
mud... its the new chrome
ststrider is offline   Reply With Quote
Old 05-18-2013, 06:43 AM   #10
gmtcm OP
KTM RIDER
Oddometer: 315
I didn't think there was much room on the left side of the frame to re-locate the VRR? Could you send me a photo of yours>
Thanks - gmtcm
Old 05-18-2013, 07:09 AM   #11
dzrtracin
ride'n 2 live
dzrtracin's Avatar
Oddometer: 2,795
Did Rick as well, 17k on the original RR & NO issues, just a precautionary measure. I kept the original mounting position as well. I figured since the original never failed from excessive heat, why on earth would the mosfet RR fail, just jinxed myself
RIDE ON!
Content, NEVER!
dzrtracin is offline   Reply With Quote
Old 05-18-2013, 07:16 AM   #12
charlie264
charlie264's Avatar
Oddometer: 8,270
07 SE, same battery, same R/R.....same location.
Old 05-18-2013, 08:32 AM   #13
dogsslober
No neck tie, Ti neck
dogsslober's Avatar
Oddometer: 875
Vrr
Getting close to 30,000 miles with Original VRR in stock location. Will prob buy a mosfet to replace sooner or later.
dogsslober is offline   Reply With Quote
Old 05-18-2013, 11:15 AM   #14
Two Moto Kiwis
Homeless Somewhere
Two Moto Kiwis's Avatar
Oddometer: 3,799
Thanks - gmtcm
Heya gmtcm
Ours didn't fizz out but we proactively relocated it away from the oven.
There is plenty of wire to bring it around to the left hand side, see toward th back of the tank and yoiu can use the same mounting plate as well.
Andi (oveja negra) & Ellen (chica amarilla)...Two Moto Kiwi Grüvers .....riding Maya somewhere ..Una Chimba
Two Moto Kiwis Home Page ..Danger Is Real ... Fear Is Optional
For More Of Two Moto Kiwis Photos
....Where The Hell Are We .. Spot Us
Two Moto Kiwis is offline   Reply With Quote
Old 05-19-2013, 08:28 AM   #15
traveltoad
Aaron S
traveltoad's Avatar
Oddometer: 6,705
Is the MOSFET Reg/Rec also sensitive to heat? Or could a MOSFET be left in the original location?
traveltoad is offline   Reply With Quote
Times are GMT -7.   It's 12:52 AM.
