Old 05-19-2013, 01:15 PM   #16
Afry
Why hike?
Afry's Avatar
Oddometer: 610
My Rick's failed (no charge) in a few months with about 1500 miles on it (stock location) with single exhaust. I put the stock working unit back on while they replace it. They claim it is the first failure of one of these. Now I lost the confidence I thought I bought.
KTM 950 SE
Yamaha TDR250
CRF450 flat tracker
Get on with riding or get on with dying - one or the other
Afry is offline   Reply With Quote
Old 05-19-2013, 01:28 PM   #17
gmtcm OP
KTM RIDER
Oddometer: 317
I am sorry to hear about the Rick's failure. Before I committed on one, I was going to call them and ask them why theirs is better than stock. Now I don't know what to do. I just put in a new YUASA battery that I don't want to fry. I have been riding KTM motorcycles of all sizes since 1997, and the new ones just don't seem as reliable as the older models.
Stand Behind Our Troops or Feel Free to Stand in Front of Them.
gmtcm is offline   Reply With Quote
Old 05-19-2013, 01:51 PM   #18
SE Steve
Super Noob
SE Steve's Avatar
Oddometer: 229
My SE has 7000 miles on it.
I'm on battery #4 and i just figured out my Voltage regulator is letting 17+ volts through.
I checked it out a while back and it was only putting out 14v but the bike was cold and i only kept it running for a few minutes. .
Today I ran the bike for a lot longer and gave it different throttle settings as the bike got hotter the voltage kept going up.
So what is the best replacement?
SE Steve is offline   Reply With Quote
Old 05-19-2013, 05:45 PM   #19
GoNOW
Oddometer: 1,588
My ADV model R&R is seeing 17V now, so it's going out.
I just order this. http://roadstercycle.com/
GoNOW is offline   Reply With Quote
Old 05-19-2013, 06:03 PM   #20
LAKEMONSTER
Oddometer: 35
VRR relocation solution
http://motoventure.smugmug.com/Other...508862_C3CDQq/
NiceName: ? Yes, my VRR quit, and took out my Battery also, four days before the KTM rally in Oregon last year. After getting a new Reg overnight shipped, AND a new Battery, i did make it, but a day late? Not wanting this to repeat itself, i starting playing with Machining a Heat Sink, (minimal reduction in Heat) and then Testing with an Infra-Red gun, experimenting with different locations, until i found the Coooooolest? Upper Mount down to 102 Degrees, and Lower Mount down to 112 degrees from a Smoking hot 175 plus where it sits between the Headers...
LAKEMONSTER is offline   Reply With Quote
Old 05-19-2013, 09:52 PM   #21
gmtcm OP
KTM RIDER
Oddometer: 317
Where did you mount the heat sinc? How about a photo of it in place. What was the heat sinc made of? Thanks
Old 05-19-2013, 10:54 PM   #22
Afry
Why hike?
Afry's Avatar
Oddometer: 610
I wonder why they don't just make a plug n play VR for the ADV and SE...baffles me.
KTM 950 SE
Yamaha TDR250
CRF450 flat tracker
Old 05-19-2013, 10:59 PM   #23
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,997
The mosfet technolofy is supposed to die without frying other components.
So Shindengen is the way to go.
Cheers.
Old 05-20-2013, 08:33 AM   #24
triplenickel
triplenickel's Avatar
Oddometer: 2,428
Check the third picture (all the way to the right) in the link he provided.
07 SE
PG007
Old 05-20-2013, 08:44 AM   #25
LAKEMONSTER
Oddometer: 35
The Heat/Cooling sink i Machined was Mounted directly behind the VRR in it's stock location, but cost prohibitive to Machine, and didn't lower Temps to my satisfaction. Click on the Smug Mug link in my Quote, and that should open up for you? I have produced these other Mounts in a Kit form, and have shipped a number of them out already? Check out Superenduro.com Bigkuri has posted some links to them. You can also contact me through MVMOTOVENTURE.CA if you would like to re-locate your VRR, and i can send you the Kit.
Old 05-20-2013, 09:10 AM   #26
Two Moto Kiwis
Homeless Somewhere
Two Moto Kiwis's Avatar
Oddometer: 3,943
Did I read someone had used a DL 1000 reliable japanese one somewhere here on OC?
Been searching but can't seem to drag it up.
Andi (oveja negra) & Ellen (chica amarilla)...Two Moto Kiwi Grüvers .....riding Maya somewhere ..Una Chimba
Two Moto Kiwis Home Page ..Danger Is Real ... Fear Is Optional
For More Of Two Moto Kiwis Photos
....Where The Hell Are We .. Spot Us
Two Moto Kiwis is offline   Reply With Quote
Old 06-16-2013, 09:01 PM   #27
SE Steve
Super Noob
SE Steve's Avatar
Oddometer: 229
So I bought a new regulator from ricks. I decided on a ricks because it had the plug already on it. I put it in the stock location checked the temp. And the bottom side got up to almost 200 degrees. I'm thinking about putting pipe wrap on the crossover. The crossover was getting up to 400+ sitting.
I know there is other threads that say don't wrap the exhaust because it will rust out. But the heat from these bikes exhaust is crazy.
Old 06-17-2013, 12:26 AM   #28
mousitsas
mousitsas's Avatar
Oddometer: 2,856
The regulator can get super hot by its own means, not sure the exhaust has much to do with this.
I have relocated mine on the rear shock nitrogen container at an angle towards the airstream. Its the only reasonable place (without cutting expanding and slicing) where it can get some air cooling. I Have no pic right now, but to give you an idea, the cables are on top right next to the compression screws. I have used a piece of an old tyre tube to rest upon and fixed it with cable ties. It is a five minute job.
Old 06-17-2013, 01:34 AM   #29
Vicks
I love sand !!!
Vicks's Avatar
Oddometer: 3,155
Most of the Japanese litre bikes (R1, V-strom, GSXR etc) use the Shindengen FH020 R/R unit.
I bought mine from the local Yamaha dealer and found out that its used on all their 600-1000cc bikes (FJR, R6/R1 and several cruisers). The stock part is FH022 which has now been superseded by the FH020-AA with a new heat sink design. I posted the YAMAHA part number in one of my posts....
'07 KTM Adv990S - Gone, to a good home , '12 KTM 990Adv, '10 KTM 530Exc-Rally
No myriad hues of laser lights, no bottles that are oozing with nectars from heaven, No beautiful body soft and warm to the touch but, i have a very small desire, Give me a dark....long....winding road, three gears to go and my Hellas on fire !!
Vicks is offline   Reply With Quote
Old 06-17-2013, 09:37 AM   #30
GoNOW
Oddometer: 1,588
The FH020AA is the same unit they sell here. http://roadstercycle.com/
Only Roadstercycle sells it for $100, Yamaha wants over $200.
I got mine installed on the bike and the voltage never goes past 14.2V. Most of the time it's at 13.8V.
Times are GMT -7.   It's 10:37 PM.
