Old 05-18-2013, 05:48 AM   #1
jimbote' OP
Oddometer: 11
640e kickstand bracket....
just recently got ahold of my first ktm 640e y2k model... I like the bike aside from one feature ... the absence of a side stand ... just a few days ago I bought a ton of parts from a guy who parted out his 2002 640e ... in the boxes of stuff was a factory side stand but no bracket to attach to my frame .... can someone point me in the direction of where to get said bracket? welding is ok but I would prefer a bolt in solution.... thanks in advance
jimbote' is offline   Reply With Quote
Old 05-18-2013, 06:36 AM   #2
Grreatdog
Grreatdog's Avatar
Oddometer: 11,676
I am the opposite. I took the side stand off and put the center stand on. The stock side stand bolts on in place of the centerstand. You can't use them together. So remove the center stand and you can install it. There are also some threads on modifying the stock side stand to work with the centerstand. SWMotech makes a side stand that allows you to keep the center stand but it ain't cheap.
The high buck option to run both a center and side stand is here:
http://www.twistedthrottle.com/sw-mo...640-all-models
Pretty much everything you might want to know about a 640 is here:
http://www.advrider.com/forums/showthread.php?t=86958
And welcome aboard.
525EXC, 640 Enduro, XT200
Grreatdog screwed with this post 05-18-2013 at 06:42 AM
Grreatdog is offline   Reply With Quote
Old 05-18-2013, 07:42 AM   #3
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,255
For Adventure travel, the center stand comes in real handy... Like the G-dog I have had only a centerstand from day 1:
gunnerbuck is offline   Reply With Quote
Old 05-18-2013, 08:12 AM   #4
jimbote' OP
Oddometer: 11
And welcome aboard.
thanks for the welcome and reply....I just finished my order @ ktmworld for all the bits to fit the stock sidestand ..... I understand the centerstand can be very convenient for trail repairs while being inconvenient the rest of the time....I prefer sidestands ....prefer is the key word, as it's a matter of preference ;)
great video :) .....the centerstand shows it's usefulness .... but I'll let you have a spare one cheap !
Old 05-19-2013, 11:45 PM   #5
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,255
I have a brand new sidestand I am not using, does your center stand have a foot tab on it?
Old 05-22-2013, 02:51 AM   #6
jimbote' OP
Oddometer: 11
it does not gunner .... it's the basic low class plant your foot und pull ... have any pics of your side swiper?
Old 05-22-2013, 06:23 AM   #7
wvrocks
wvrocks's Avatar
Oddometer: 616
My 2000 640 Adv has the factory side stand on it. For some reason mine is useless. Seems to be about 3" too short or the angle on it is wrong. The bike will not stand on it at all. Haven't really tried to figure it out though as the center stand works well.
Never underestimate the power of stupid people in large groups.
wvrocks is offline   Reply With Quote
Old 05-22-2013, 09:08 AM   #8
Seikkailu_R
Seikkailu_R's Avatar
Oddometer: 839
Stock side stand for 2000 model is 407mm long.
Maybe you have shorter stand from other model, or really worn bushing/bolt on side stand?
And 2000 was last year adventure came with both, side and center stand.
Seikkailu_R is offline   Reply With Quote
Old 05-22-2013, 10:13 AM   #9
wvrocks
wvrocks's Avatar
Oddometer: 616
Thanks, I'll have to measure it. I know for sure there is some slop in the pivot, just haven't taken it apart yet to see exactly why. It would be nice to have the side stand functional if I'm going to carry the weight around.
Old 05-22-2013, 08:37 PM   #10
bmwktmbill
Traveler
Oddometer: 5,195
Is the mount loose, I had to weld mine to the frame and reman the bolt for it and for the center stand, it had snapped off.
The side stand can be customized easily with the heat wrench, must be chrome moly, I'd cool it slowly after you custom bend it.
No problems stick welding on the frame...dc the battery leads.
bill
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill is offline   Reply With Quote
Old 05-23-2013, 08:04 AM   #11
Seikkailu_R
Oddometer: 839
On 2000 model adventure r side stand bracket is weldet to frame, not a bolt on part...
Old 05-24-2013, 07:05 AM   #12
wvrocks
wvrocks's Avatar
Oddometer: 616
bill
Nope, its welded to the frame. There's all kinds of slop in the pivot though. I'm going to tear it apart tonight and see if I can tighten things up with a bushing or something.
Old 05-24-2013, 09:01 AM   #13
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,690
A little cutting, grinding and welding on the KTM bolt on sidestand bracket can get you this..
...cost me a case of beer.
YMMV
Boon Booni screwed with this post 05-24-2013 at 09:20 AM
Old 05-24-2013, 11:39 AM   #14
jimbote' OP
Oddometer: 11
YMMV
that lookin' sweet man!.... did you just grind off the mounting tabs that bolted it to the frame and move it out slightly? .... are you using the stock side stand ?.... any pics of that beast in the upright position?
Old 05-24-2013, 01:46 PM   #15
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,690
Yes, I just cut off the mounting tabs, and ground the plate to fit the contour of the frame. My friend welded a little bit back on to the plate at the bottom where I cut the tab off at a bad angle.
I don't think it's a stock side stand. It's something that was on there when I got the bike. It's got a foot that's larger than normal, and slightly adjustable (not length just rotation)
I don't have any pics of it up, I'll take some when I get home..
Times are GMT -7.   It's 07:08 PM.
