Go Back   ADVrider > Bikes > Orange Crush > Ridiculous streetbikes with 6 CPUs and too much horsepower (1050/1190/1290cc)
Old 08-19-2013, 05:50 PM   #346
Two Tigers
Oddometer: 101
Any word on the carbon fibre stuff?
Originally Posted by mcguyver View Post
Joe Brazier currently has my 1190 and is working on a carbon fibre bashplate complete with tool,box.. Should look fantastic when its done.
He is also looking at carbon frame guards/ heat shields.
I will post pics as soon as possible.
Two Tigers is offline   Reply With Quote
Old 08-20-2013, 06:00 PM   #347
hahnelw
Just Mapping Another Ride
hahnelw's Avatar
Oddometer: 593
Originally Posted by Burren Rider View Post
G'Day Pete,
I think Rod was talking somewhere between $800 - $850 for the pipe? I guess that may change depending on the dollar though. Don't know what the thickness of the plate is but if it is anything like the B & B plates I have used in the past it will be well built and stout.
Hi Pete,
Below is an outtake from the B&B website. 5mm should do the job!!
Cheers WH
B & B Off Roads Ktm 1190 Bash plate is made from 5mm thick 5083 structural alloy plate. Rear mounts are 5mm stainless steel with a rearward facing lug that rests on the rear frame rail to prevent rotation of the bracket. There are 6 32mm hole in the underside to help flush debris and minimise noise. There is also a rubber damper glued inside to help reduce noise. If so desired b & b off road can supply the bash plate with motofoam to further reduce noise and mud build up. Bash plate can be fitted with or without genuine crash bars. All necessary mounting hardware for this is supplied.
Mile marker 203 The gas gauge leanin on the edge of E and I'll be damned if the rain ain't pourin down Theres somethin smokin underneath the hood Its a bangin and a clangin and it cant be good And its another 50 miles to the nearest town
hahnelw is offline   Reply With Quote
Old 08-20-2013, 06:02 PM   #348
hahnelw
hahnelw's Avatar
Oddometer: 593
I haven't seen a high fender kit for it. Looking at the bottom clamp and clearance to the radiator, I suspect it won't be straight forward process? At this stage, I am just going to lift the standard guard with a set of Touratech Risers. I wouldn't mind having a tinker with a high guard option somewhere down the track though.
Hi Burren Rider,
Looking at the Touratech site it looks like they only make a riser for the Standard, not the R??
Cheers WH
Woops you obviously worked this out on a later post....
hahnelw screwed with this post 08-20-2013 at 11:48 PM
Old 08-20-2013, 10:19 PM   #349
speed_racer
speed_racer's Avatar
Oddometer: 707
Originally Posted by FuTAnT View Post
Try Hepco Becker, local distributor in Dayboro QLD. Very good price normally.
http://www.motorcycleadventure.com.au
Update: Here you go!
http://www.motorcycleadventure.com.a...th=101_165_946
They do look a little 'high' though.
You could also contact Dalby Moto and see if they have anything in the works.
Sent from my Nexus 4 using Tapatalk 4
Thanks for that. yeah they do look very high.. I wonder why that is..
speed_racer is offline   Reply With Quote
Old 08-21-2013, 07:23 AM   #350
Bonsai Elephant
Bonsai Elephant's Avatar
Oddometer: 18,756
Very high.
Not ideal for serious off road traveling.
Bonsai Elephant is offline   Reply With Quote
Old 08-21-2013, 10:25 PM   #351
hahnelw
hahnelw's Avatar
Oddometer: 593
Originally Posted by Bonsai Elephant View Post
Very high.
Any pillion would need to be seriously skinny.....
Old 08-21-2013, 10:29 PM   #352
mousitsas
mousitsas's Avatar
Oddometer: 2,771
they are narrower though by being placed above the exhaust?
Old 08-22-2013, 12:51 AM   #353
Burren Rider OP
Aussie Adventurer
Burren Rider's Avatar
Oddometer: 1,819
A few 1190's in Australia are having big issues with dust getting past the stock paper filter. With a decent ride coming up where I knew there were going to be plenty of bikes and dry powdery conditions, I was starting to get paranoid so I contacted Uni Filter to see how progress was going on their filter kit. They were incredibly good to deal with and managed to get me a pre-production version air freighted in time for the ride.
The kit consists of:
1) Some coarse pre-filters for the intake snorkels
2) A foam gasket for the airbox lid (which seems to be the source of the problem)
3) A decent two stage foam filter (all oiled for maximum dust retention).
I really can't see any dust getting past this setup and the added advantage is that the paper filter won't be around to get wet and dissolve.
I have no affiliation with Uni (apart from using their filters over the past 20 years) but I was amazed at the lengths they went to work out a solution and get it to me in time for the ride. That kind of service is pretty rare these days so no doubt I will be safely using them for another 20 years.
Burren Rider is offline   Reply With Quote
Old 08-22-2013, 01:31 AM   #354
Katoom72
Katoom72's Avatar
Oddometer: 884
Impressive service from unifilter! Got a pic of how the stock filter looks like when mounted? (just curious)
Now:
'03 KTM 250sx -- '05 KTM Adventure 950
Before:
'00 KTM 250sx -- '03 KTM 450sx -- '03 Yamaha R6 -- '08 KTM SuperDuke R --- '13 KTM 690 enduro R
Katoom72 is offline   Reply With Quote
Old 08-22-2013, 01:55 AM   #355
PPiA
Pete
PPiA's Avatar
Oddometer: 1,182
... and managed to get me a pre-production version air freighted in time for the ride.
Any idea when they will be in production?
PPiA is offline   Reply With Quote
Old 08-22-2013, 02:13 AM   #356
seppami
990 Adventure
Oddometer: 66
I took some pictures of my friends bike to Finnish forum: http://www.matkaendurot.net/forum/vi...0831&start=390
7000km, airbox first time open.
seppami screwed with this post 08-22-2013 at 02:21 AM
seppami is offline   Reply With Quote
Old 08-22-2013, 02:38 AM   #357
PPiA
Pete
PPiA's Avatar
Oddometer: 1,182
That's concerning.
Old 08-22-2013, 04:08 AM   #358
Katoom72
Katoom72's Avatar
Oddometer: 884
That's very concerning. :/
Now:
Before:
Old 08-22-2013, 07:13 AM   #359
Jaimoto
Spaniard in Chile
Jaimoto's Avatar
Oddometer: 1,256
The UNI filter looks like the part!
People are reporting the same findings in the south African forum
Linky
http://www.wilddog.za.net/forum/inde...topic=128906.0
Jaime
Big, Loud and Orange KTM 990 Adv
Jaimoto is offline   Reply With Quote
Old 08-22-2013, 08:35 AM   #360
Bonsai Elephant
Oddometer: 18,756
Is it my imagination, or looking at BR's most recent post have they narrowed the frame down compared to the 9X0?
It looks all slim, slinky, and great for knee gripping.
P.S. Love the Unifilter sticker placement!
Times are GMT -7.   It's 05:34 PM.
