Old 05-30-2013, 10:39 AM   #46
Misery Goat
Positating the negative
Misery Goat's Avatar
Oddometer: 75,146
The OP answered for his mileage claims so now we can get back to the discussion at hand. mmmkay?
"So what you gonna do when the novelty is gone.."-- Joy Division
Same as it ever was
My Wanderlust
Misery Goat is offline   Reply With Quote
Old 05-30-2013, 12:03 PM   #47
dwj - Donnie OP
dwj - Donnie's Avatar
Location: Traveling on the Moto or Escuitla, Chiapas, Mexico
Oddometer: 14,419
Donnie - Retired & Riding - 2010 990ADV - 42,200 Miles - 1 Continent - 10 Countries
Traveling Mexico 2014 - SPOT
dwj - Donnie is online now   Reply With Quote
Old 05-30-2013, 12:38 PM   #48
Qwik
Adrenaline Addict
Oddometer: 6,678
I am at 56k miles with my 05.5 I replaced the motor at 52k due to over torquing one of the bolts on the clutch pack. It broke free about 600 miles after I installed the new clutch plates. The fault was mine. The only issues I ever had prior was a valve adjustment finally being necessary at 46k and even then I believe only two were barely out of spec . The new motor( it's an 06) runs great and has 39k on it. I have no doubt this machine will keep going for years more. The goal now is to install a sidecar ( so my four year old can ride with me) on the 05 and find either an SE or a 990Adv as a solo bike. If I could only have one bike this would be it.
Topes never seem to make me go any faster.
Qwik is offline   Reply With Quote
Old 05-30-2013, 05:14 PM   #49
dwj - Donnie OP
Oddometer: 14,419
Thanks for the info! How did over torquing one of the bolts on the clutch pack destroy the engine?
Old 05-30-2013, 05:38 PM   #50
Qwik
Adrenaline Addict
Oddometer: 6,678
It broke at the base. The spring pushed the bolt into the inside of the clutch cover and rubbed aluminum shavings that got pulled into the motor. I realize now I could've probably saved the motor with a much more thorough flushing but I am paranoid and ended up finding a motor.
Old 05-31-2013, 07:54 AM   #51
dwj - Donnie OP
Oddometer: 14,419
SPARE PARTS
Excluding normal maintenance items like oil/air filters, oil, tires, sprockets, chains, and spark plugs, I probably need to consider carrying a few spare items for extended trips into the outback. I have been reading or re-reading Ride Reports that were done on 990s to gain some insight along with info given here, plus info gained from links given here. Here is my list so far, I would appreciate input as to items that I include here that may not be necessary and/or items not included here that should be in the kit.
Fuel Filter Kit by inmate gefr
Fuel Pump Kit by inmate gefr Is this really needed?
Water Pump Rebuild Kits Supplier with reasonable prices?
Oberon Clutch Slave unit or just the O ring?
Please give me input from first hand experience with 990s. Do I understand correctly that fuel pump and water pump issues of past years have been corrected before 2007? What about the Clutch Slave issues? I don't mind buying the parts, but I will be doing a lot of two-up touring and space will be limited. Thanks!
I won't have these before my next Mexico trip in a few weeks, but I will be "assembling" my kit when I return. Thanks!
Donnie
Added: What are tools that would be essential to carrying out road side or parking lot repairs that are not included in the tool kit that came with the KTM. I have plenty of tools, but I don't want to carry anything I don't need. I will normally start work on the KTM with the supplied tools and once I establish that acceptable tools are there, I might switch over to tools that make it a bit easier, but I don't carry those tools on the road because of space and weight. Among other things, I have already added a spark plug wrench and a 19MM socket for the main oil drain plug.
dwj - Donnie screwed with this post 05-31-2013 at 08:56 AM
Old 05-31-2013, 09:00 AM   #52
MurphCO
MurphCO's Avatar
Oddometer: 378
Originally Posted by ColoradoBigfoot View Post
I must add, I was not fair or justified in my "braggart" diagnostics. It was just an unconcious "trigger" that released my inner grumpiness. Never said I was perfect. I will say this however, I will never shut-up or keep my mouth shut when I have something to say. Regardless if other posters disagree with my views.
This is also true in REAL LIFE with Bigfoot....
and I agree, the OP is first and foremost bragging about mileage he has ridden, over and over and over...
how it reads:
I have ridden a zillion miles on a zillion bikes, and plan to ride a zillion more, but woe is me I have no idea what to expect on a trip. Did I mention I rode a zillion miles?
that's why the OP is so defensive, he knows he is looking for credibility....and you fanboys are playing into it.
Does it matter? no, except its douchey
Bones heal, chicks dig scars, pain is temporary, glory is forever. - Evel Knievel
MurphCO is offline   Reply With Quote
Old 05-31-2013, 09:24 AM   #53
Trail bandit
Random adventurer
Oddometer: 204
990
I'm getting huge benefit from this thread. Just brought a 2007 990 and working out spares etc.
Just not sure what the point of the negatives are exactly.
Thanks to the OP.
Trail bandit is offline   Reply With Quote
Old 05-31-2013, 10:01 AM   #54
Misery Goat
Oddometer: 75,146
SPARE PARTS
Donnie
Make sure you read Vinnie's (crashmaster) RR, I think he details the parts/spares he carried on his trip.
Same as it ever was
My Wanderlust
Old 05-31-2013, 10:14 AM   #55
dwj - Donnie OP
Oddometer: 14,419
Yes, I am in the process of re-reading it now. I followed it at the time he was doing the RR, but I was not as interested in the present subject at that time.
Old 05-31-2013, 10:33 AM   #56
dwj - Donnie OP
Oddometer: 14,419
how it reads:
I have no more intention of arguing with you that I did with Bigfoot! , If you go back and read what I wrote from the beginning, you will see that I was addressing the folks that were telling me the KTM would last me forever! I did not exaggerate, I simply demonstrated with facts the mileage that the moto would see. From that, it was my hope to receive info as to what I might expect with high mileage. The facts I provided demonstrated that the KTM, nor any other moto was going to last me forever. Since that time, I have received the type info I was asking for.
I apologize if the miles I have ridden offends you! I have not ridden a zillion miles in my life time, nor have I had a zillion motos! But when I do buy a moto, I keep it a long time and I put a lot of miles on it. Which again, is what drove the original question.
Old 05-31-2013, 10:39 AM   #57
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,918
What you are looking for toolwise
http://advrider.com/forums/showthread.php?t=403562
Cheers.
Old 05-31-2013, 11:02 AM   #58
dwj - Donnie OP
Oddometer: 14,419
Originally Posted by gefr View Post
Thanks! That was exactly what I needed! I had already added everything except for the 4mm allen wrench and it is in my kit now! I will be ordering some stuff from you when I return from Mexico!
Old 05-31-2013, 11:32 AM   #59
Deviant666
Present
Deviant666's Avatar
Oddometer: 535
Then you don't have to make such a statement here for it is not the opinions of others that you care about (in this matter). Imo your original question was well founded but a bit "too aggressive" in the way it came out.
My 990 is just shy of the 50k mile mark and I suspect it burns oil like a potato fryer. I'll report back when I'm sure. Had the cases cracked after a high speed slide on some shoapy water. Had the mc failure three times (now replaced with a radial type from a SD). Had the slave cylinder failure once and 3-4 times the fuel filter clogged other than that it has been pure joy!!!!
KTM 990 Adventure White 2009 R specced
ZZR1400 ABS 2008
Deviant666 is offline   Reply With Quote
Old 05-31-2013, 11:54 AM   #60
dwj - Donnie OP
Oddometer: 14,419
Wow! Good luck with your moto! Sorry, I don't understand this: "Had the mc failure three times (now replaced with a radial type from a SD)." Is that one of the master cylinders?
Times are GMT -7.   It's 06:13 PM.
