Old 05-25-2013, 09:30 AM   #1
Azazel OP
Oddometer: 33
1980 CB400T Hawk, Advice needed for ADV build
Hey all!
I've been lurking for a bit, but now I need to solicit some advice. I have a 1980 Cb400T Hawk that I am in the process of "Cleaning up" so that it is a more functional ride. Ideally, I would like to make it into a capable adventure bike. Screw the Cafe, I want fun in the wilderness.
I know that this is hardly a KLR, but the bike is rock solid ('82 CM450 Engine) and I think with a tire swap and some other minor changes it could be pretty good on the logging roads based on how it handles. I wanted a scrambler exhaust but sadly it seems I'd have to custom fabricate that which is out of my budget.
What I mostly want to know is if anyone has experience fitting sidecans or a rear rack to this thing, because the square pre-sport tail doesn't seem very conducive to doing so?
Many thanks!
Azazel is offline   Reply With Quote
Old 05-25-2013, 10:07 AM   #2
dakman74
moto-butcher expert
Oddometer: 48
Post a picture so I can be sure, but I had a 78 400T and it had a factory rear rack with a backrest that was removable. I'm pretty sure it had the same design as your bike if what you mean is it's not the sportier 80 400T. The 80-81 400T came in two flavors (sporty, and standard) If I remember correctly the rear rack mounted in such a manner that you could potentially add side "cans" also.
Even if it's the sport model, they had racks available:
http://www.totalmotorcycle.com/81CB400T.htm
This is one like I had on my standard:
http://item.mobileweb.ebay.com/viewi...id=14667271790
I'm also thinking with the CM450 motor you might get an exhaust from a CL450 to fit, with a little work. Nice thigh-burning pipes!
F-it...let's ride!
dakman74 screwed with this post 05-25-2013 at 11:40 AM
dakman74 is offline   Reply With Quote
Old 05-26-2013, 05:42 PM   #3
Azazel OP
Oddometer: 33
Oh, hah, I suppose a picture would have helped a bit:
http://i.imgur.com/PIrdRj6.jpg
Old 05-26-2013, 06:22 PM   #4
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,816
We're not out here to rough it. We're here to smooth it. Things are rough enough in town.
Nessmuk
Old 05-26-2013, 06:37 PM   #5
dakman74
moto-butcher expert
Oddometer: 48
OK so the sport model. The trick is to find a factory rack like the first one I listed. Otherwise, it's fab one or have someone fab one.
F-it...let's ride!
Old 05-27-2013, 09:56 AM   #6
Azazel OP
Oddometer: 33
Sweet, the seat was really throwing me off with the way it swoops up there. Should it be fairly easy to mount side containers as well? Army surplus has some ammo on for $15/each and I'm thinking they'd be pretty handy.
Old 05-27-2013, 11:27 AM   #7
dakman74
moto-butcher expert
Oddometer: 48
Depending on how big, the ammo cans should be pretty easy to mount on a factory rack. Smaller ones you could use a few u-bolts to secure the cans to the sides of the rack. For bigger ones, I would probably fab up more support. Good luck!
F-it...let's ride!
Old 05-27-2013, 01:46 PM   #8
4play
Next?
4play's Avatar
Oddometer: 2,620
Not being a KLR is not neccessariy a bad thing. My 650 twin project came out at about the same weight with more power & very smooth. there is no reason you can't make a very capable gravel runner out of the Honda. Good luck
You don't understand, those boys killed my dog.
4play is offline   Reply With Quote
Old 05-27-2013, 03:48 PM   #9
Pezz_gs
Cant ride for crap
Pezz_gs's Avatar
Oddometer: 3,835
In Aus the CB400T was the rounder shape. The one pictured above by Saliah was called the CB400N here.
CB400T image
Airhead Tragic
I'm not a complete idiot -- Some parts are missing
XR460/4 - http://www.advrider.com/forums/showthread.php?t=497905
Pezz_gs is offline   Reply With Quote
Old 06-09-2013, 12:12 PM   #10
cody-james
Oddometer: 27
I'm going to have to watch this thread, I'm trying to do something similar with a 78 cb400. So far I've installed Renthal bars and a larger more aggressive rear tire, and just ordered a 3.50x19 Shinko 244 for the front. I'm planing on removing the stock fender and trying to fit a klr or similar one. I don't expect it to be like my klr but hopefully it will be capable of tackling dirt roads and commuting.
cody-james is offline   Reply With Quote
Old 06-12-2013, 08:49 PM   #11
Azazel OP
Oddometer: 33
What rear did you go with? I'm having trouble finding dual-sport tires for 100 90-18 rims that aren't stupidly aggressive tread to the point of being offroad only.
Old 06-12-2013, 09:04 PM   #12
4play
Next?
4play's Avatar
Oddometer: 2,620
Mefo Explorer would be a good choice, you may want to consider a MT43 Pirelli trials tire.
Old 06-13-2013, 03:30 AM   #13
lord_oblivion
lord_oblivion's Avatar
Oddometer: 142
Here in Europe, this is CB400N :
Tyres on this mine are Conti Escape 4.6-18 TT rear (mounted without inner tyre, like TL) and 100/90-19 TL front. Rear tears down in 17-20.000km, front ok.
Very well on gravel and fire roads but not for mud and send :
Added these instead of dust seals, fits from MZ 251 :
Added wider handlebars and crossbar (jet to be painted) :
Mine is 27HP one and with standard sprockets 16/36 and w10 grade oil in front shocks (a bit softy) she is decent adv ride. Problem is pretty stif rear suspension or to be honest, my weight of only 70 kilos
I have front pegs from XT600 going next and small ammo cans like these :
I'm planning a bit wider front rollbar and some on the rear because too often end up overside. And biger foot on sidestand too
Better dead than lose momentum ...
www.jawaklubsrbije.org
lord_oblivion is offline   Reply With Quote
Old 06-13-2013, 01:51 PM   #14
lord_oblivion
Oddometer: 142
Ah yes, subscribed
Old 06-16-2013, 07:00 PM   #15
Azazel OP
Oddometer: 33
Hot Damn, Lord_Oblivion, that's basically the inspiration for where I want to take this thing! Glad I'm not the only one who saw the potential for offroad fun times with this hardware.
Here's the bike with the paint finished:
Currently in the shop having the left valve cover bolt drilled out of the block after I over-torqued it, and then snapped an easy-out off inside the bolt trying to remove it. There goes my budget for a scrambler exhaust.
Times are GMT -7.   It's 08:21 PM.
