Old 06-06-2013, 09:52 AM   #16
bwalsh
bwalsh's Avatar
Oddometer: 11,172
Originally Posted by Paebr332 View Post
Most fuel gauges are similar to an idiot light
Fixed.
Fuel gauges aren't precision measuring devises. Just a close estimate of how much fuel is in the tank. For example, I've never had a vehicle that had exactly half a tank of gas when the gauge was at half.
My truck has a rectangular fuel tank. No weird angles. It's fuel gauge doesn't move at all until I have been 150 miles then the mileage varies between each 1/4 mark. I can get close to 550 miles between fill ups. The mileage between each quarter after the needle starts to move is different too.
In other words, you can't judge how much gas you've used accurately by glancing at the fuel gauge. You would need to fill up from each 1/4 mark to narrow it down to what the OP is looking for.
2004 XR650L
NWVA TAG NWVA TAG MAP RTE THREAD & IN LIST
bwalsh is offline   Reply With Quote
Old 06-08-2013, 12:09 AM   #17
vortexau
Outside the Pod-bay
vortexau's Avatar
Oddometer: 1,700
On a side note; has anybody wondered if their motor runs better on a rainy day?
All to do with cooling engine intake air, resulting in denser air for the mixture.
Turning Water into Horsepower
'08 Suzuki AN650A Burgman (and trailer)
vortexau is offline   Reply With Quote
Old 06-11-2013, 04:48 PM   #18
Hoppalong
Hoppalong's Avatar
Oddometer: 48
Yes, I've noticed this on a restored Triumph Bonneville that was built when 100 octane gasoline was commonly available.
I worked with a guy that had water-injection on his hot-rodded truck. The idea is that it allowed for higher compression ratios by cooling the combustion chambers.
Here's a wikipedia link:
https://en.wikipedia.org/wiki/Water_..._%28engines%29
Hoppalong is offline   Reply With Quote
Old 06-11-2013, 04:58 PM   #19
ttpete
Rectum Non Bustibus
Oddometer: 5,758
Water injection was used in WWII aircraft to retard detonation at high boost pressures. It was 50/50 Methanol/water. Straight water doesn't work as well.
15 BMW RnineT
09 Kaw Versys
ttpete is online now   Reply With Quote
Old 06-11-2013, 09:12 PM   #20
k-moe
Oddometer: 2,589
Straight water freezes at altitude. It gets freaking cold above 10,000 feet.
k-moe is offline   Reply With Quote
Old 06-12-2013, 08:39 AM   #21
ttpete
Rectum Non Bustibus
Oddometer: 5,758
And alcohol works better than water for evaporative charge cooling. Alcohol also has a significantly higher effective octane number than gasoline. So, it's really more than just an antifreeze.
15 BMW RnineT
09 Kaw Versys
Old 06-13-2013, 07:18 AM   #22
Frostback OP
Frostback
Oddometer: 232
Do I see some proponents for ethanol in gasoline here?
Lee
Frostback is offline   Reply With Quote
Old 06-16-2013, 09:38 PM   #23
DepthFinder
Portly Adventurer
DepthFinder's Avatar
Oddometer: 985
ethanol raises octane (or at least has the same effect) but the gasoline is likely at a lower pre-ethanol octane so that the finished product is the same. On the other hand, ethanol slightly leans the mixture which can have an adverse effect on detonation if not accounted for.
There are lots of folks in the forced induction auto world who run water, water/methanol, straight alky, or even e85 injection on top of their normal efi for charge cooling. Shooting e85, not as a primary fuel, but as a charge cooler, works exceptionally well from what I've seen.
Ethanol as rammed down our throats in every gas pump? Not a fan of that.
THIS PAGE INTENTIONALLY LEFT BLANK
DepthFinder is offline   Reply With Quote
Old 06-17-2013, 07:00 AM   #24
Frostback OP
Frostback
Oddometer: 232
I figured there was a rub. Still impressed with the speedway bikes that ran straight methanol (?) on ice in an enclosed arena. Slowly, heat after heat, the fog of combustion filled the whole place with an aura of bluish gray haze. It is a wonder we didn't all die on the road home, but what a fond olfactory recollection.
Lee
Times are GMT -7.   It's 02:01 PM.
