Old 05-31-2013, 03:38 PM   #1
Michael OP
Michael's Avatar
Oddometer: 207
Downshifting & Clutch Wear Question
When downshifting I find it hard to precisely match the RPMs to the new lower gear. I have a 2008 BMW K1200S and I just can't seem to get the downshifts smooth. So, I developed the habit of pulling in the clutch, downshifting while holding RPMs steady, then letting in the clutch to get the RPMs up without making the bike jerk.
My question is - will this put too much wear on the clutch? Should I expect a drastically shorter clutch life? The bike has 33,000 miles on it now.
BTW I can smoothly upshift without using the clutch and do this most of the time.
Michael is online now   Reply With Quote
Old 05-31-2013, 03:50 PM   #2
Andyvh1959
Cheesehead Klompen
Andyvh1959's Avatar
Location: Da frozen tundra eh? 1.5 mile west of Lambeau
Oddometer: 684
Downshifting should be easy and natural, I do it all the time on my 94 BMW R1100RS (which has a dry clutch by the way). I get usual clutch life of 80,000 to 100,000 miles even though it is a single plate clutch.
Are you trying to downshift at lower rpms? That may make it more difficult. I have ridden many BMW K12 and K13 models and I've not had any issues with downshifting.
Your bike has a multi-plate wet clutch, which is hydraulically actuated. Any chance the clutch fluid is really low, air in the line, never bled/flushed? Those issues would all contribute to hard downshifting. Since you say you can upshift without the clutch, that can be done even if there is no fluid in the clutch master cylinder. But downshifting, especially on a shaft drive bike, does require clutch actuation.
I would first have the clutch master and slave cylinder circuit flushed and then properly filled/bled with new fluid. My bet is your shifting issues will dissappear.
When life throws you a curve,.....lean into it!
42+ year rider, 22+ year MSF Coach, Street, Dirt, Ice, ride em all!
Andyvh1959 is offline   Reply With Quote
Old 05-31-2013, 04:07 PM   #3
Michael OP
Michael's Avatar
Oddometer: 207
Andy, thanks for the tip - The fluid level is fine but I have no idea if there is air in there. Good idea about flushing it out.
Old 05-31-2013, 04:20 PM   #4
Andyvh1959
Cheesehead Klompen
Andyvh1959's Avatar
Oddometer: 684
The clutch on the K12 and K13 BMWs should be plenty durable and sustain a lot miles, depending on the use/abuse factor.
Given your bike has 33k on it I would definitely have the clutch circuit flushed, new fluid put in and properly bled. What you describe is not at all normal for any K bike I have ridden. Most issues of shifting relate to clutch drag, and most clutch drag is caused by an improperly setup clutch. Since your bike has hyd clutch actuation it automatically adjusts for clutch wear. But 33k on a K12 is nothing. The other factor "may" be the clutch basket fingers have developed grooves which can tend to hold the plates in place. Clutch basket grooves can happen on a clutch that is abused regularly with full throttle launches, like drag racing launches.
Old 05-31-2013, 04:26 PM   #5
opmike
Choosing to be here.
opmike's Avatar
Oddometer: 334
If ever you find it "hard" to do something (assuming you're using quality and mechanically sound equipment), it's probably a sign of needing more practice.
When I first started riding, it took me a bit of time getting smooth rev-matches. I made a point to practice it whenever possible and it became a non-issue.
"you want to fix the Pledge of Allegiance, put a disclaimer at the end: with liberty and justice for all...must be 18, void where prohibited, some restrictions may apply, not available in all states."
opmike is offline   Reply With Quote
Old 05-31-2013, 05:00 PM   #6
univibe88
Slidell4Life
univibe88's Avatar
Oddometer: 2,270
Key word being "should" but the clutch on the K12/K13 is a known weak point. There are tons of accounts of them shitting out at unacceptably low miles. Mine went out at 58k miles which is okay. But lots and lots of people had them burn out <20k miles. The K12/13 bikes have three well known weak points - clutch, FD and cam chain.
List of my old bikes that no one cares about
Current bikes go here to make others jealous
"I like my ride plans like my women...loosely put together with a chance of getting wet."
univibe88 is offline   Reply With Quote
Old 05-31-2013, 09:33 PM   #7
lnewqban
Ninjetter
lnewqban's Avatar
Oddometer: 291
Cool2
Originally Posted by Michael View Post
..........So, I developed the habit of pulling in the clutch, downshifting while holding RPMs steady, then letting in the clutch to get the RPMs up without making the bike jerk..........
That is a bad habit, you need to blip the throttle in order to increase engine's rpms' before shifting down.
This video explains it much better:
http://www.youtube.com/watch?v=0ABNrYzqJgI
lnewqban is offline   Reply With Quote
Old 05-31-2013, 09:37 PM   #8
RockinTheRVA
RockinTheRVA's Avatar
Oddometer: 105
I once had an 07 K1200R. I found the bike in general to be much more difficult to cleanly shift(up or down) than every other bike I've had. My current Honda 919, my previous ZX6R, FZ6, Ninja250's, etc were all very easy to smoothly upshift and downshift. The K12 with its shaft drive never quite felt natural when shifting. I'm sure many people can shift them smoothly, but I got frustrated that it wasn't second nature as with my other bikes. Your experiences sound very similar to mine.
For what it's worth, in my opinion, not meant to be offensive, I think part of your frustration comes from the nature of that bike.
*thinking back, I do remember that bike behaving much better at higher RPMs...even though you could easily ride it under 5K rpms all day
-- '07 Honda 919 --
VA to Vermont 2013 - http://advrider.com/forums/showthrea...6#post21280046
Blue Ridge Parkway and The Dragon 2012 - http://advrider.com/forums/showthread.php?t=837836
RockinTheRVA is offline   Reply With Quote
Old 06-02-2013, 09:40 AM   #9
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,544
You got that right and especially on a BMW, you kind of have to preload the whole drivetrain, all of them have a fair amount of "lash". Holding steady or decreasing the RPMs too much and you'll pick up the lash. Makes things......unsmooth.
Altough I know that some of the K1200s slant do have shifting problems. Some have gone the long and rather expensive way of having the transmission rebuilt and all the gears undercut for smoother shifts.That's something BMW seems to have cheapened out on.....undercutting the gears.
Blip UP!
Have tools, will travel!
Old 06-02-2013, 11:45 AM   #10
74C5
74C5's Avatar
Oddometer: 948
Maybe try not completely dis-engaging the clutch and blipping just a bit.
R1200RT (R1100RT gone)
KLR650 - gone
Don't be the guy who needs to pee on the fence to figure out that it's electrified.
74C5 is offline   Reply With Quote
Old 06-04-2013, 09:32 AM   #11
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,544
And that also, BMW levers are adjustable. Don't know about the wet clutches but on the dry ones, I just blip the clutch.Shifts much better than bringing the lever all the way back to the grip. Just for the kick yesterday I did a few things I don't usually do......definitely unsmooth.Not a big fan of hydraulic clutches, always liked more feedback at the lever from a clutch cable.
I was also playing with the suspension setups, wrong compression and rebound dampening will also affect the shifting to some extent.Again don't know much about them newfangled wet clutches on BMWs but over 30 years met way too many complaining about the BMW clunkiness, never really had that problem. Preload the shifter....blip clutch and throttle keeping the drivetrain loaded....away we go, up or down.
Old 06-04-2013, 03:44 PM   #12
Michael OP
Michael's Avatar
Oddometer: 207
Thanks for all the thoughtful comments. I have been practicing the techniques yall recommend - am not real smooth yet but at least it gives me something to do while riding in dense DC traffic........
Old 06-04-2013, 08:33 PM   #13
PT Rider
Oddometer: 687
Adjust your throttle cable for the minimum slack. That'll make the blipping work well with less wasted wrist movement and the associated wasted time.
It's not what you look at that matters, it's what you see.
Henry David Thoreau
PT Rider is offline   Reply With Quote
Old 06-04-2013, 09:07 PM   #14
car94
What's this Box for?
car94's Avatar
Oddometer: 3,605
205
Never ever short shift!
Ride Your Own Ride
car94 is offline   Reply With Quote
Old 06-05-2013, 09:57 AM   #15
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,544
And that....I know the BMW tolerances for cable play, there shouldn't be much of that 2mm I think on my bike altough I do it by feel, no need for a feeler gauge. And 2 cables, push and pull for the cruise equipped bikes. If not adjusted exactly the same makes the cruise engagement iffy sometimes. But sure jerks them bikes on accell/decell, no smoothness there. Ouch my first ride in the curves on my used K was painful just because of that. Couple that with their infamous slippery seat.....painful for the "package" that is.
I checked about 15 bikes at a shop a couple years back, not one of them were adjusted correctly or even the same and looks like quite a few escaped a proper pre-delivery inspection and were delivered to a customer that way.
All the Ducatis/Triumphs and others at that shop were well adjusted, probably right at the factory.
Times are GMT -7.   It's 04:46 PM.
