Old 06-08-2013, 11:39 AM   #16
bradluke0
Oddometer: 206
Hi all ! I have found the smoothest way to downshift is to hold the throttle steady , pull the clutch in , downshift and let clutch back out . Holding the throttle steady the whole time . Blipping the throttle and trying to time all that stuff , especially on a "non-smooth" bike is tough . Try it you'll like it .
bradluke0 is offline   Reply With Quote
Old 06-08-2013, 06:24 PM   #17
ttpete
Rectum Non Bustibus
Oddometer: 5,844
It can be done, and I do it on occasion, but not when setting up for a corner where I need engine braking quickly. Blipping isn't difficult, but it requires practice to do it smoothly. It becomes automatic after awhile.
15 BMW RnineT
09 Kaw Versys
Old 06-09-2013, 10:41 PM   #18
chorizo
Oddometer: 192
Not using the clutch
You think Im blowing it not using the clutch much at all? Times when not pushing my Uly it'll shift real smooth up or down without the clutch. Except 1st. If its not grinding, no harm right? BTW the clutch on the uly is not hydraulic.
chorizo is offline   Reply With Quote
Old 06-10-2013, 07:55 AM   #19
univibe88
Slidell4Life
univibe88's Avatar
Oddometer: 2,301
I am no expert by any means, but I don't see how downshifting without the clutch can be a good thing.
Upshifting, sure. If you are at the right shift point the transmission will easily slide into the next gear. But when you downshift the engine is immediately going to rev up and engine brake. Seems that you want/need to either blip while the clutch is pulled in, or slip the clutch after shifting.
List of my old bikes that no one cares about
Current bikes go here to make others jealous
"I like my ride plans like my women...loosely put together with a chance of getting wet."
univibe88 is offline   Reply With Quote
Old 06-10-2013, 08:56 AM   #20
bradluke0
Oddometer: 206
Hi all ! The problem is downshifting should not be used to slow down . Downshifting is done to match the engine and road speed . Slowing down is the brakes job, speeding up is the engines job . I am obviously in the engine for go ....brakes for whoa camp .
Old 06-10-2013, 09:24 AM   #21
ttpete
Rectum Non Bustibus
Oddometer: 5,844
Don't go driving in the mountains with a standard shift car or truck, then. It'll get interesting after you burn the brakes out halfway down.
15 BMW RnineT
09 Kaw Versys
Old 06-10-2013, 10:00 AM   #22
SteelJM1
Undercover KTM rider
SteelJM1's Avatar
Oddometer: 1,649
Ahh yes, nothing better than the fishy smell of fried brakes when following cars down Mt. Lemmon!
p.s. even on auto's one can hold lower gears ;)
SteelJM1 is offline   Reply With Quote
Old 06-10-2013, 02:45 PM   #23
Michael OP
Michael's Avatar
Oddometer: 211
Tried it, and it works pretty good! At least where there is time for a lesuirely shift, since it takes a half second or so for the engice to rev up after letting in the clutch.
Michael is offline   Reply With Quote
Old 06-10-2013, 03:44 PM   #24
LuciferMutt
Rides slow bike slow
LuciferMutt's Avatar
Oddometer: 11,228
I do this frequently when I'm just toodling along and am not slowing down rapidly. Works well.
However, for slowing down quickly, while riding more aggressively it doesn't bring the revs up fast enough and a "blip" is still necessary.
You couldn't hear a dump truck driving through a nitro glycerin plant!
Badasses might screw with another badass. Nobody screws with a nut job. -- Plaka
LuciferMutt is offline   Reply With Quote
Old 06-10-2013, 09:16 PM   #25
TahoeRider
Red Rider
TahoeRider's Avatar
Oddometer: 119
Upshifting without the clutch should not damage anything as long as it is done correctly. Although I still do it occasionally on the street it really doesn't serve much of a purpose there. I don't like to ride that hard on the road although I still manage to let myself slip now and then
As far as the rev matching is concerned blipping the throttle is my preferred method as well. As ttpete mentioned it becomes automatic once you have some practice, and is the quickest & easiest method to get it into gear quickly. The worst thing you can do is drag the clutch without compensating for the rpm change. Not only does it wear the clutch, but it will lock up the back tire on occasion as well. When I was a relatively new driver I made this mistake with a diesel pickup that had a manual trans. I downshifted & let the clutch out rather quickly without matching revs, and the high compression locked the back wheels & started sliding down the road sideways
TahoeRider is offline   Reply With Quote
Old 06-11-2013, 08:57 AM   #26
bradluke0
Oddometer: 206
Hi all ! ttpete ..... you have downshifting confused with being in the proper gear while going downhill utilizing engine braking . Using the engine to slow down otherwise is a risky move , lock up that back tire with a sloppy downshift and it gets interesting real quick .
Old 06-11-2013, 10:39 AM   #27
ttpete
Rectum Non Bustibus
Oddometer: 5,844
Don't do sloppy downshifts. I don't. Proficiency is a good thing.
15 BMW RnineT
09 Kaw Versys
Old 06-12-2013, 08:11 AM   #28
bradluke0
Oddometer: 206
Hi all ! Proficiency is a great thing......in the real world however , we are not perfect and by using the engine to slow down just magnifies any mistakes . Just remember we are not as great a rider as you .
Old 06-12-2013, 08:40 AM   #29
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,632
I finally read the rider's manual for my K1200RS on changing gear/shifting down. Sorry BMW......too slow your procedure.
Close the throttle first as in fully close???? Sorry again BMW that's really hard on the package that in the lower gears. Slightly better with the Corbin/Ohlins vs the OEMs but still.
Not using engine compression for some braking and speed control in them very long hills here, and I say long (up to 15 miles).....now that's funny. I must have been doing it wrong for a very long time on BMWs.
Have tools, will travel!
Old 06-12-2013, 09:13 AM   #30
erkmania
Still Adventuring
erkmania's Avatar
Oddometer: 978
For me, matching revs during a downshift becomes sloppier when I'm just tooling around town or just mindlessly going about my riding. In that case, it's easy for me to just hold the throttle steady as the clutch is released and a lower gear selected followed by slowly re-engaging the clutch. Like the others that said it before me, this method works well and if you're not in a hurry.
While hustling the bike around, I'm with the others here too. Best to match the revs as well as possible to make the ride smooth.
What I'll add here is that I don't always return the clutch lever to its neutral position immediately after a downshift. I will sometimes return the lever to a partway position so the clutch can slowly match engine speed to gear train speed. I do this particularly If I mismatched engine/gear train speed too much. I will even give a subtle throttle blip while the clutch is in the friction zone to reattempt smooth clutch re-engagement or I'll wait for the engine revs to drop if I've over revved. This has worked well when hustling the bike around and not wanting to overwork the rear tire.
I guess my main point is that you can use the friction zone of the clutch when selecting a lower gear just as you can when taking off from a stop; same but reversed. I think the biggest thing for longevity is to keep the gear train and engine speeds matched as well as possible and don't demand that the clutch transfer a lot of power when these speeds are mismatched too much.
I know, I know. I'm the master of the obvious.
-Sticks and stones, love.
-Insurmountable problems exist in the imaginations of the less traveled.
2011 BMW R1200GS, 2004 KTM 950, 1996 ATK 605 ESDS
erkmania is offline   Reply With Quote
Times are GMT -7.   It's 01:13 AM.
